Question about Maytag MDE16CS Electric Dryer
Timmer Maytag Commercial Dryer
Hi
My name is Jorge and i have a Maytag Commercial Dryer model number MDE10CSACL but the problem is i need i need lower the time cycle, actually the time is 60 minutes and i need chenge at 30 minute. How i do that?
  • Anonymous Mar 10, 2008
    we have an MDG21pndww how do I set the codes, what is the code translation.
  • 550 Answers
The maytag timer for MDE10 should be a multi vertical slide in type. If so under the keyed panel on the top of the dryer, is an electric control with a grey knurled knob facing the front of the machine.
This grey knurled knob is the time set.
The knob rotates clockwise (from front) under motor control while the dryer is running, and jumps back to starting position under spring control when the slide is pushed in.
There is a single grey stud moulded into the front of the knob, that is the sixty minute mark, and a number of slots before the stud, that take a nylon peg. they are 6 minutes apart 54 48 42 36 30 minutes. Inserting a nylon peg in the slot at 30 minute will do what you want.
Most service guys drop the peg in the bottom of the control when they remove it, makes it easier to find, next time, so if there is not a peg in any slot, examine the floor if the enclosure, A short nut n bolt will accomplish the same result if the peg is not there.
If the original multicoin push in has been replaced with a newer single slot device I dont know how the change is made, none of my dryers are that new.
Posted on Jul 28, 2008
No heat
While your model number is not listed on the Service Manual at the link below, you will find information on how to check out the heater on page 8-6.
Good luck
http://www.servicematters.com/maytag_library/docs/16023110.pdf
Sep 29, 2009 | Maytag MDE16CS Electric Dryer
Timmer running but dryer wont do anything.checked switch on door
Depending on how old the unit is and the model number.
I would say the need to replace the thermal fuse kit.
Part# LA-1053
Sep 03, 2009 | Maytag Dryers
HiMy name is Ray and i would like to increase the drying time on a maytag commercial dyer model lde19cs
i just got off the phone with Maytag Commercial Laundry customer service, because i needed to know how to adjust the run times on this dryer model. here is what i learned:
there are slots in the timing cam into which fit a white pin for adjusting the run time. the letter settings on the cam are set at 12 minutes apart:
E = 12 minutes
D = 24 minutes
C = 36 minutes
B = 48 minutes
A = 60 minutes
if your dryer is running 48 minutes, that pin is likely in the 'B' slot. remove the pin. the built-in stop at the 'A' position is for 60 minutes.
May 28, 2009 | Maytag Dryers
Maytag commercial dryer rejects all quarter
Take out the coin slide and inspect for any worn parts. You can replace it for about $40
May 14, 2009 | Maytag MDG16PD Gas Commercial Dryer
Hi My name is Ray and i have maytag commercial electric dryer model LDE19CS but the problem is i need to increase the time cycle,from 48 to 60 minutes. How i do that. I need manual
You either change the timer motor or you change the
Timing cams. Contact Lobright manufacturing in Queens village new york 888 - 829 - 0009
I do not know if my friend Bob Pinkney is still there but ask for him and tell him JW said hi. Ask him to send you a catalog. In it you will find all sorts of laundry matt stuff plus those cams and motors.
May 11, 2009 | Dryers
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Noisy dryer , rough sound sometimes knocking
start by pulling up the top more than likely it is the drive wheel or possibly the belt has come loose but there is a spring on the drive belt tension arm that gets worn or the plastic wheel that rides on the drum that needs replacing
Dec 11, 2008 | Dryers
Maytag MDE16CS Electric Dryer Logo
288 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
