Back to:
Tags:
Vacuums
Generic problem for all Vacuums
Sucking up liquid
posted by waldo3 on Feb 24, 2008
my steam vac will apply the liquid but it will not suck it up. I have misplaced my manual
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Feb 24, 2008
Helpful (85)
domvac
Rank:Guru Guru
Rating: 88%, 155 votes
check the tank lid. It is very common for people to install the lid and not engage the front tabs that hold the lid in place at the front. The lid must be fully down on the tank for suction to get to the floor. Try to lift the front of the lid. If it comes up slightly, then it is not properly attached. Also, make sure that the removable duct is in place. You remove it to use the hose and replace it to go back to floor.
Rating Locked! (?) waldo3 has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on sucking up liquid:
I don't want to Accept this solution
Can you Help with these Vacuums problems?
Black & Decker SV1000-4 SteamBuster Vacuum
I purchased this machine approx 4 years ago. It has sat...
Hoover F5835900 Upright Steam Vacuum
will not extract water from carpet. model 5835-900....
Vacuums
new charger and battery
Vacuums
I managed to break the handle off my vacuum and the three...
Bissell 6594 PowerForce Bagless Upright...
I was vacuuming and it shut off like it had come...
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
