Question about Bose LifeStyle 50 System
Bose system (Lifestyle 50)
The music center does not communicate with the multi-room interface. It keeps flashing "NO RESPONSE". Everytime I plug the power in, the CD changer comes on but goes off in 3 seconds.
  • 2 more comments
  • fomuki123 Feb 24, 2008
    I left it unplugged for days and it still didn't make a difference.
    The NO RESPONSE massage on the remote keeps flashing throughout the 3 seconds.
  • fomuki123 Feb 25, 2008
    Yes, there a disc inside the tray.
  • Nikki Luebke
    Nikki Luebke Jul 10, 2014
    did you ever figure out what was wrong with it?
    President:
  • 1,944 Answers
Did you try leaving it unplugged for a few hours?
Posted on Feb 24, 2008
  • Damen Wong
    Damen Wong Feb 24, 2008
    I see.
    So you say that as soon as you plug it in the power, the CD changer turns on and then turns off after 3 seconds? During these 3 seconds there is a NO RESPONSE error message? Did I understand you correctly?
  • Damen Wong
    Damen Wong Feb 25, 2008
    Say is there a disc inside the tray?
The remote does not communicate with the amplifier
[PDF]The Bose® Lifestyle® SA-2 and SA-3 Stereo Amplifier
https://worldwide.bose.com/.../en/owg_en_sa2_sa3.PDF Bose CorporationWARNING: To reduce the risk of fire or electrical shock, do not expose the product to.... ence to radio communications. ... Note: Unauthorized modification of the receiver or radio remote control .... Thank you for purchasing a Lifestyle® SA-2 or SA-3 stereoamplifier. ... Left and right channel line inputs for a local audio device.
[PDF]Owner's guide - Bose
worldwide.bose.com/axa/assets/pdf/owner.../og_sa1.pdf
Bose CorporationJan 4, 2002 - WARNING: To reduce the risk of fire or electric shock, do not expose the.... may cause harmful interference to radio communications. ... Connecting theLifestyle® stereo amplifier to a Model 5 music center . ..... Lifestyle® SA-1 stereoamplifier rear panel ... Setting up the RC-20 remote control for Zone 2.
[PDF]BOSE® Link AL8
Dec 29, 2015 | Bose Lifestyle SA-2 2-Channel Amplifier
I BOUGHT A BOSE P1 REMOTE ON EBAY BECAUSE THE BACKLIGHT WASN'T WORKING ON MINE. GOT THE IT IN PUT BATTERIES IN AND TURRNED IT ON AND IT IS FLASHING ON REPONSE. I DONT HAVE THE OWNERS MANUAL SO...
Hi Kimberly,
Here is a link to manuals Bose offers for one of many systems. In it you will find the instruction Bose Support Owner Manuals for Home theatre systems and speakers
Here is a brief from the lifestyle 50 system. Lifestyle 50 System Bose Product Support .At the site you can navigate until you find your desired hardware. Take a look.
Ah yes a video of the P1 to watch and adapt too
Bose Model P1 Personal Music Center remote
Fare. Well.
Jan 07, 2015 | Bose Televison & Video
Remote shows no response
I have just had a major problem trying to get the handheld (touch screen) music centre to communicate with the multi room interface. It took over a week to sort out by trial and error, but here is the solution :
1. Disconnect everything from the multi room interface apart from Room A and the CD player (blue connector).
2. Turn off the electricity supply at the wall (turning off any in line extension lead is not good enough - it needs to be at the wall socket). Leave turned off for at least 2/3 hours.
3. Turn back on and then leave it again for 2/3 hours.
4. Touch the music centre and you should find that it has now registered with the interface unit.
5. Connect the other rooms and input sources with the power switched on (contrary to instruction manual which advises you connect everything before powering up).
6. Test each input systematically as you connect them.
Hope this helps. I was on the verge of buying another multi room interface (I have 2 music centres and neither worked so assumed in was the interface at fault), at a cost of £200, so now glad I persevered with resetting the system !
Mar 03, 2014 | Bose LifeStyle 50 System
Lifestyle 50 not responding
Reconnect the Bose link connection at the Multi room interface and at the Acoustimass Module.If this doesn't help,change the remote control batteries.If the it still display "no response",it means either the interface or remote is bad
Jul 28, 2013 | Bose Lifestyle 40/50 Music Center Used...
Bose lifestyle 50 "no response"
You can find a bose M1 on amazon already refurbished
Apr 13, 2013 | Bose LifeStyle 50 System
We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Bose lifestyle 48 says format unsupported for audio cds
Everytime I want to play an audio cd, it says format unsupported. This is happening very often. And I have also cleaned the cds,but still there is no difference. What is the solution?
Apr 08, 2009 | Bose Lifestyle 48 System
Bose lifestyle model 5 music center
Bose lifestyle 5 series III does not play any CD or DVD, it keeps saying unsupported formated . Can anyone offer suggestions.
Dec 01, 2007 | Bose LifeStyle 5 Series-III CD Shelf...
Lifestyle 12 by Bose
No sound ? Make sure the audio input cable is connected to the music center FIXED outputs, the black connector is fully seated in the music center SYSTEM CONTROL 1 jack, and the multi-pin connector is firmly seated in the Acoustimass module jack. ? Turn the music center off for ten seconds, then on again, to reestablish communication between the music center and the speakers. ? Check the connections for any external components. Make sure to select the correct source for the desired input. ? Check the speaker connections. ? Be sure the CD is placed correctly, label-side up, in the music center, and the cover is closed. ? Increase the volume. ? Check to see if MUTE is lit in the display. Press the MUTE button on the remote to unmute the sound. ? Disconnect any headphones. ? Connect the FM and AM antennas , and last but not least. Make sure there is power going to the remote speakers or the unit will not communicate with them. Good Luck
Jun 14, 2006 | Bose Lifestyle 12 System
Bose LifeStyle 50 System Logo
1,566 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
