Question about HP Compaq nc6000 Notebook
FUNCTION KEY:( Hi, I am using an ASUS A6VC notebook.I can not use any of the function key shortcuts like Fn+F10 anymore. I really don't understand how I turned it off..How can I enable it again? Thanks, Denisse Hi, I have the same problem with my compaq nc6000
    President:
  • 778 Answers
You didn't state which Operating System you are running, so if Windoze Vista is your OS, this is a known issue and I'm sure that Asus support/download site will have an updated driver for you soon. If not? let us know if you made any hardware changes or installed any software before this issue occurred? If so, you might want to try to remove them and see if that gets your function keys working again.
Good Luck.
Posted on Feb 24, 2008
My FN keys are backwards
Normally you can do that in the bios
Sep 21, 2017 | Toshiba Satellite L305-S5933 Notebook
How to turn off the fn key
1 - Function Keys f1 through f122 - Configurable Function key fnDisable fn in the BIOSTo disable, or enable, the function key (fn) in the BIOS, do the following steps.
  1. Press the power button to turn on the computer.
  2. Press the f10 key to open the BIOS setup window.
  3. Use the right-arrow or left-arrow keys to navigate to the System Configuration option.c02035200.jpg
  4. Use the up-arrow or down-arrow keys to navigate to the Action Keys Mode option, and then press the enterkey to display the Enable / Disable menu.
  5. Select the desired mode:
    • Disabled : Requires pressing fn key + f1 through f12 to use the action as indicated on the action key.For example, if Disabled , pressing fn + f11 will mute the sound as indicated on the key on this model PC. Alternatively, pressing f11 only will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
    • Enabled : Requires pressing only f1 through f12 to use the action as indicated on the action keys.For example, if Enabled , pressing f11 only will mute the sound as indicated on the key on this model PC. Alternatively, pressing fn + f11 will minimize and maximize a web browser if open.The action keys may vary depending on the model of notebook.
  6. Press f10 key to save the selection and restart the computer.
The function key (fn) option can be reset at any time.
May 22, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Disable short cut key on function key
I understand that you want to disable the function key( action key). The action key feature is enabled at the factory. You can disable this feature in Setup Utility. If this feature is disabled in Setup Utility, you will need to press fn and an action key to activate the assigned function. Refer to the "Setup Utility (BIOS)" chapter for additional information. Refer the page 101 of the user maual for the information on Using Setup Utility http://h10032.www1.hp.com/ctg/Manual/c02092591.pdf
Also refer the following links for the information on
Disable The Fn + Function on HP Laptops
http://h20435.www2.hp.com/t5/The-Next-Bench-Blog/HOW-TO-Disable-The-Fn-Function-on-HP-Laptops/ba-p/77527
Disable The Fn + Function Key Combination on Certain Models
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=c02035108
Feb 17, 2012 | HEWLETT-PACKARD HP Pavilion dv6-3025dx...
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
Hi i have the asus n53jg laptop. absolutly amazing laptop cant nock it i just have a little problem that i want to get sorted see the laptops function keys that run along the top have shortcuts on them...
The function keys that you have works alone and in combinations. You can press and hold Fn key then tap on any of those keys to get the short cuts. You can also press and hold Alt key and any of those to get another short cut. It actually depends on what you want to do.
For example:
Using single key:
F5 - it will refresh a window
F11 - try it in internet explorer to see the result
Using Combination:
Alt + F4 - it will close an open window
Fn + F3 - it will lock or disable your touchpad
I hope I understood your concern and helped. Goodluck
Jul 17, 2011 | ASUS Computers & Internet
(Fn) key function
Fn or Function key is used for your F1 up to F12 keys. Ex. Fn+F5 is to turn on the wireless capability. Fn key is like a shortcut for the functionality of the machine. You can also adjust brightness by pressing Fn+Up or Down arrow and for the Volume Fn+Left and Right arrow.
Apr 29, 2011 | Lenovo IdeaPad Z360 Notebook
Hi! I can't find any way to get my Advent 4211-C (Windows XP OS) webcam working on Skype (the only webcam function I currently use). Cyberlink says there's "No available Captured Device". I don't...
Advent 4211 always require you to enable it everytime you turn the laptop on. it is Fn key + F10 I think. Look for the Function key at the top of your keyboard which has a picture of a webcam. Hold down the FN key at the bottom left, and then click on the correct 'F' key. You should see a little picture come up on the screen to say you have enabled your webcam. That should work.
Jun 01, 2010 | Advent 4211c Notebook
Some of my function key shortcuts have stopped working
go to asus website and click support. after that click download and find the ATK file...I tried both, but I believe the larger file is the one working
Oct 19, 2009 | ASUS Eee 4G Notebook
FN + F2 did not function in my ASUS laptop.
Restart> press F2 on boot = BIOS
Wireless device > ENABLE
Mar 14, 2009 | ASUS WL-330G 802.11g/b (wl330g) Wireless...
FUNCTION KEY:(
try, right click on my computer icon>properties>hardware tab>device manager>, then look down the list to your keyboard, click + sign, right click on keyboard select uninstal and then reboot notebook and keyboard will self install. If still not working your drivers may be corrupt and will need to be downloaded from the Asus support website.
Oct 05, 2007 | Computers & Internet
HP Compaq nc6000 Notebook Logo
147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
