When using my fujitsu-siemens amilo notebook, the monitor suddenly shuts down. It's not all black as you can sense a little backligt. However, only way to wake up the monitor/computer again is by shutting it all down using the power on/off button and turning it on again (which of course results in a message that windows was not shut down properly). The problem both occurs when using a programme and when no programmes are running (except for Vista). Any ideas what the problem may be?.
Comments:
Feb 24, 2008
- Shut down also occurs when there is key or mouse activity, thus not only when the computer is idle. And it is not possible to wake the computer again (unless you shut it completely down) as it should be if it had somethin to do with power saving
-   mine is bad enough as well! the fujitsu siemens at the beginning lights up but later when it shows window xp the light goes away and you can't see anything unless you put it in the sunlight. a little help here please!-   mermaidsreal
Jul 07, 2008
-   Hi I have the same problem with the monitor but this one is more worst i cant even solve it. the problem is no display on monitor its all black only but only the light from the screen. is there any code to press here? i think that the monitor is locked. can u help me with this.
usually shut down when idle(idle means no key or mouse activity).........left click mouse in any space on desktop,select properties,in properties window select screensaver and lower in the screen youll see power settings..select it...in power schemes change time best suited or select never.
Comments:
Feb 26, 2008
- you could check the bios at startup power settings can also be found there if thats any help
I am looking for a TRUE desktop-replacement.
I am looking for a quad-core min 4. GB of DDR3...
(More)
I am looking for a quad-core min 4. GB of DDR3 RAM.
I also want a better GPU then just the intregrated one so that I can truely play games hi-res, just search me the best laptop you can find, but not from dell, that includes Alienware.
Thanks in advance
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and...
(More)
Ive got a toshiba 2455-s305 laptop that won't turn on. I've tried it using the power cord, with and without the battery, and when I plug it in it start's flashing in the front, but won't turn on.
I have an Everex stepnot nc1500 series which was give to me. Is there a way i can restore this...
(More)
I have an Everex stepnot nc1500 series which was give to me. Is there a way i can restore this computer to factory setting?
when i plug in my hp nx 5000, they turn it on automatically even i didnt push the power button yet,...
(More)
when i plug in my hp nx 5000, they turn it on automatically even i didnt push the power button yet, and then before they boot up they read some sort of memory?
