Matsui LM37NS1 37" tellvision that goes on to stand by after about 2 hours as if it over heating, i switch it back on and the time is reduced it well then last for about an hour and switch itself off to standby and solutions
  • Anonymous Sep 05, 2008
    same problem hoping someone has a answer
There is a modification on this set you need to fit a fan on top of this power supply to keep it cool because it over heats design problem it works you never have power problem with it again
Posted on Sep 28, 2008
I had the same problem
Posted on Jun 10, 2010
Heat Pump will not shut off
flow switch timer in the unit. its a part on the pcm board. tell the pump to stay on for 10min after heat up. and does other times as well depending on setup... its not really a switch its a chip but it works as a switch.
Mar 08, 2014 | Honeywell Programmable Thermostat Heater
CREDA FLASH PROGRAMMER 2S, I can programme the current time and the comfort / reduced mode, however when i set the slide switch to 'auto' all that is shown is 2 moons. According to the manual
Reset digital timers before programming to eliminate trace testing memories and restore full functionality
Make sure you're in correct mode fro programming: Time setting mode, with selector moved to top next to clock symbol
Compare your timer manual with Hagar manufacturer's generic manual for the 2-channel: English on page 3.
http://waterheatertimer.org/pdf/Hagar-monotron-200-2-channel-manual.pdf
http://www.credaheating.co.uk/assets/kb/operating_instructions/0/Flash_2S_Programmer_Instructions_Issue_1.pdf
Contact Creda
www.creda.heating.co.uk
Mar 18, 2013 | Hardware & Accessories
Ce32ld33 tv sanyo turns on stays on for couple hours then turns off and stays off until an hour or 2 then switches on .i try to switch it on after about 20 mins but the little blue standby light goes...
There is a high possibility that the components over a period of heating and cooling, tend to bring on a problem of dry soldering. So my advice is to check the set for some loose joints that have played on to give you these erratic shut downs or poor performance. The best way to check for loose connections is to tap lightly when the set is powered on, if there is change while tapping then it seems that there are DRY solder joints. Remove main plug, the covers - with caution of high voltage, check for dry joints, and use a good soldering iron to solder all suspected points. Sometimes the fault occurs when the set warms up; if so you can simulate the heat using a hair dryer on the suspected areas, try with the power supply, distribution, Processor controller, driver controllers on the A/V related sections. Also the use a FREEZE-IT spray can simulate the components to cool and show up the fault. It can also be related to WEAK ELECTROLYTIC capacitors as the value can reduce in time.
Oct 04, 2011 | Sanyo Televison & Video
Fridge not cooling,unfortunately collected by car and the fridge was transported on its side.Its been off and standing for days but still not cooling when switched on,is there a remedy
It is possible that the compressor oil had pumped into the system and is thereby causing problems in the heat exchange cycle.
Put the fridge off and keep it standing for more than 24 hours to allow the oil to come back to the compressor.
After the time limit put the fridge on and watch the noise of the compressor to be pumping earnestly with a good whining. If not check onthe main capacitor or relay( if clicking).
If there is no ICe formation in about 2 hours, it is possible that the compressor is weak , gas is leaked and needs an overhauling.
Sep 16, 2010 | Refrigerators
New refrig deliverd today told not to turn on for 2 hrs to let gas settle as it reduces the lifespan. true or false.?
False . If it was delivered laying on its' side , back , or front , 24 hrs is necessary . If delivered standing up , no need to wait .
Nov 13, 2009 | Belling BE808 Compact Refrigerator
Creda Night Store Heater model 79154
The dial on the wall with 1-24 on it, with the red pins, is the timeswitch to turn the heater on for night-rate hours (when the electricity is cheapest). Hour 1 is 1am --> Hour 24 is midnight.
Set the red pins to turn the heater on from 11PM (23) to 7am (7). The 'on' symbol is normally a '1', with off being '0'. Otherwise, on can be symbolised with a staright line with circles on it, while off is like a little barrier-arm part up.
As for the knobs on the heater, one is for the amount of heat which goes in (how much the heater 'charges'), and the other is for how much it lets out.
Genrally in winter you set the input (nite-store, second knob) to full (6), but in spring or autumn you may reduce this as required.
The other knob (room temp) is for how much heat comes out of ther heater. If you work during the day, you will want to conserver the stored heat in the heater.
Turn the room temp knob down to about 3 when you leave for work, and wind back up to 6 when you get home. This will stop all the heat leaving the heater during the day (and maybe use less power to recharge at night).
Good luck with the time switch. Check your night-rate hours on your power account.
Apr 03, 2009 | Heating & Cooling
Lcd tv turns off after 5 mins, leave 2 mins comes on to stand by
Swollen ( bad ) caps in power supply first place to look.............T.
Dec 17, 2008 | Samsung DLP HL-P5663W 56" TV
Matsui plasma tv
Hi.
What is the model number of your matsui tv. ?
http://dysonmanuals.inc.io/
Oct 15, 2007 | Televison & Video
MATSUI MP3
i have a MATSUI mp3 but after i put in songs in mp3 it dont showe up and the stand no file
Sep 19, 2007 | iLO (2 GB) MP3 Player
Televison & Video Logo
200 people viewed this question
Top Televison & Video Experts
Electro Med Services...
