  • 1 more comment
  • Anonymous Mar 25, 2008
    Mine was doing the same thing, now I have sound but no picture.
  • Anonymous May 01, 2008
    I have the same problem - need to unplug the tv before it will turn on. The standby light just blinks. Has anyone been able to fix this problem? The suggestion listed here seems to make sense.
  • Drf8069 Aug 10, 2008
    I have the same problem, What was the fix?
Could possibly be a bad Solder Connection (Cold Solder Joint)
Posted on May 17, 2008
  • 8,617 Answers
Sounds like something minor in the standby voltage circuitry, However it will eventually prevent the set from working. I would check the voltage regulators and capacitors in the power supply.
Posted on Feb 24, 2008
Toshiba color
How many times do it blinks? Count it. These blinks are called blinking codes, and is fault indication. From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit side inside the TV. If you wish to get more details about Toshiba Blinking codes, and other details, check the site linked here. Pull up previous posts there, either by its left side bar, or view it in Timeslide option.
Jun 30, 2013 | Televison & Video
Conia buttons work on the tv and the picture does not appear when you turn it shut of one day.the aerial works and the tv has power.
How long have you owned the television. What is the exact model of the television. Once I have more information I can help you further.
Aug 26, 2008 | Televison & Video
How to hook up cable box to model tz55x71 manufactured 2000 diagram please
You can Google the model number of the Toshiba for a 'manual" or owner manual which will show your set.
Usually with a cable box in goes to box and out to cable fitting on rear of set and set to channel 3. Output of a box with audio/video cables is same except they connect not to the cable fitting but to the rear inputs on back of set.
FYI most cable companies will come out, connect it and hook it up for little or no charge.
May 20, 2012 | Toshiba 50 Inch Big Screen Flat Tv Theater...
I have a hp dv5 1040e when press power key after 2second it turnoff before turnon cpu fan
In this case the problem may exist in two spots:
- Faulty motherboard
- Faulty power supply jack
Try turning your laptop on with the battery pack NOT attached.
Does it behave in the same way? If not then your battery is to blame. If it behaves in the same way, I'm afraid it'll be a costly fix.
Jul 04, 2011 | Computers & Internet
My phone keeps shutting off by itself and when it I turn it back on all of my settings have been reset to the original phone settings. Is it a battery problem?
Its no a battery problem. Mobile phone also have a mini ram inside the circuit board. That ram may damaged. And that's why its auto turnoff and when you turnon its come in original setting as default. Thanks.
Mar 24, 2010 | LG enV Touch VX11000 Cell Phone
Toshiba 50hp95 will not respond and has flashing red power light. It seems many people have this problem, what's the solution? We have tried all the Toshiba suggestions.
My 50hp95 had the same problem; the red power light is flashing and the tv will not turn on. I unplug the power and plug it back in and the TV clicks, but the power light continues to flash red. My problem was a bad Seine module which you can bypass if you do not need to watch HD off air programming. Since I get my HD from the cable, I can bypass it. All you need to do is remove the back panel from the TV (unplug the TV first) and on the main circuit board unplug the white connector labeled PJ63A. The main circuit board is the one in the center of the TV and the PJ63A connector is the bottom white connector on the left side of the main circuit board (the label is printed in white on the circuit board under the connector). Once I plugged the TV back in it worked immediately.
Sep 09, 2009 | Toshiba 50HP95 50 in. Plasma Television
Toshiba tz55x71 won't turn on
If you are a little handy, there is alot of information here.
If not, I will dig for info.
Mar 04, 2008 | Televison & Video
TZ55X71 screen and protector broken part #'s??? How to clean lenses???^CG7^xdm524&s1=adwords-22e539d9e6369d28d62ae4a9a56a40ce&s2=5498ad8d4dd2413b934ce0ce75dd43fa5a5a4bdd&s3=&s4=&s5=&utm_source=adwords&utm_campaign=808986899&utm_term=segment+ski+8933745652033491368&mt=&network=d&kid=kwd-10009911&aid=41398201826&
Jan 13, 2018 | Televison & Video
Toshiba TZ55X71
It really depends. If the board is cracked or broken then I would say no, if it is something more simply repairable then sure, call a repair shop to get an estimate then go from there. With the price of TV's these days it may not be cheaper to replace, but then again your current one may not even be repairable.
Jan 27, 2008 | RCA P46810LV 46" Rear Projection...
Televison & Video Logo
379 people viewed this question
Top Televison & Video Experts
