Question about Panasonic DMR-EZ47V DVD Recorder/VCR
Stuck dvd disc.
Have a DVD disc stuck and the open/eject button does nothing when pressed. The screen claims no disc but it's in there. I've pushed the reset button several times but all it'll do is make some winding noises then it quiets down. Shall I attempt to pull out the tray lightly or take it in?
  • jjrdr3362 Feb 25, 2008
    Hi Palmbeach, I tried your suggestion but it didn't work. I do have the manual and read in the troubleshooting guide how to eject but nothing happens. I'll take it in for repair this morning.
    Thanks for your time.
    JR
  • jjrdr3362 Mar 05, 2008
    I tried that also exmarine but it was hopelessly stuck. I had to take the unit in for repair, They replaced the dvd mod board which went bad. Got it back yesterday and all is well again.
    Thank you all for taking the time to help. God Bless you all.
    jjrdr3362
  • 185 Answers
Hi there
Page 80 in the instruction manual tells you how to do this.
In case you don't have a manual, do the following:
While the unit is off, press and hold the stop key (shown on the unit as a button with a small black square on it) for about 5 seconds. It may take longer to eject depending on the disc.
Hope this helps
Posted on Feb 24, 2008
  • sweetpea240 Mar 20, 2011
    Brilliant....Thank you so much, just about to throw the VCR out the window.
    Worked like a charm....Have a great day.
  • 47 Answers
It is actually a combination of the STOP and CH-UP button for five seconds while the unit is in standby. If this doesn't work, simply try to press the OPEN/CLOSE button while the unit is off - it should power up and try to eject the disc. If not, something else is wrong.
Posted on Mar 05, 2008
Is there a way to get the disc out without dismantling the entire TV? Disc is stuck, lock icon shows when eject button is pressed. Can TV be reset to factory specs?
Try the following. kindly update result here in comments
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons.
If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
Mar 21, 2016 | Toshiba Televison & Video
DVD is stuck in player. It will not eject.
Make sure it is powered on. Press power-on button then try to eject. If not, then press the power-on button and try to eject. If neither works, return to the sore or website where you bought it and ask for replacement.
Dec 26, 2017 | Insignia NS-24LD120A13 24in 1080p LCD HDTV...
Dvd will not eject
Jammed.
Straighten one end of a Norwegian paper-clip.
Insert that end into the small hole in the face-plate.
Push until you feel resistance.
Firmly push another 5mm to "unlock" it.
Then, press OPEN.
Jan 01, 2014 | Sanyo DVW-6100 DVD Player/VCR
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
The dvd drawer on my BD-HP16U is stuck in closed position. The screen display "hold" when I push the eject button.
Try inserting a small pin through the hole beneath the insertion cabin, after pressing the eject button. If you don't have such a hole, Push the eject button and tap hardly on the top of the player. The drive will come out in two or three attempts.
Apr 13, 2010 | Sharp AQUOS Blu-ray Disc Player
Will not eject DVD is working is stuck I think I might need to open laptop
Power down the laptop and restart it. As soon as it restarts press the open button on the dvd drive and it will open. You may have to try a few times but it will work.
Sep 29, 2009 | Dell Studio 1737 Laptop
DVD stuck in MacBook Pro but my laptop registers nothing...
If you look on the dvd drive there is a little round hole. Just get a paper clip and straighten it out and stick it into that hole. There is a little button that you push with the paper clip that is a manual eject button for cases like this.
Aug 22, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Nav system
Installing the DVD Map Disc Your dealer/retailer may have installed the map DVD. If the map DVD was not installed, do the following to load it:
Read the following steps completely.
  1. Turn the ignition on. The vehicle must be in P (Park) to perform this operation.
  2. Press (power) to turn the navigation system on.
  3. Press the NAV hard key.
  4. Touch the Insert Map Disc screen button. The screen opens to access the map DVD slot.
  5. Load the map DVD partway into the slot. The system pulls it in. The screen cannot be closed until a double beep is heard.
    Notice: Pressing directly on the navigation screen may cause damage. Repairs would not be covered by the vehicle's warranty. Do not press directly on the navigation screen.
  6. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
  7. Set the search area. See "Setting the Search Area" earlier in this section.
Ejecting the DVD Map Disc The navigation portion of the system cannot be used if the DVD map disc is not loaded.
  1. Press the MENU key to enter the Menu options, then press the MENU key repeatedly until Nav is selected or touch the Nav screen button.
  2. Touch the Map Database Information screen button.
  3. Touch the Eject Map Disc screen button. The screen tilts, exposing the map DVD slot.
  4. Press the eject button, located next to the DVD map disc slot, and the disc ejects. Pull the disc out. The screen cannot be closed until a double beep is heard.
  5. To close the screen, slightly push up on the two outer corners until the screen is in position. Then push the screen in by pushing on the four outer corners until a click is heard.
Oct 07, 2008 | 2007 GMC Acadia SLE
Help ejecting dvd
I had the same problem and tried for ages (even tried forcing the door open thinking I could just tape it shut) without luck.
Then my very clever wonderful husband had a go (I know i'm crawling and yes my knees hurt).
Any way to the relevant bit. If you hold the eject button down and at the same time slide a knife or similar object round the edge of the door where the screw is near where it says photo/select you'll find that the door opens as this is an override mechanism.
Feb 22, 2008 | Hitachi DZ-GX3200A DVD Camcorder
Panasonic DMR-EZ47V DVD Recorder/VCR Logo
373 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
