Question about Magellan Maestro 4040 GPS Receiver
Magellan 4040 charging issue
Just bought a 4040 (used) that is in excellent shape. I have charged the device over night but it still says that battery is low and goes into sleep mode. How can I tell if its the charger or the battery that is not working properly
  • 2 more comments
  • Rudy615 Feb 24, 2008
    when I plug it in there is no indication that it is charging, should there be
    went through the manual, nothing in there as far as troubleshooting goes
    what I triesd was using the car adapter in my car. I could clearly see that it was charging. I will need to buy a new charger. I believe that will solve mny problem. If not I will be back in touch. Can I get the chargers at a local store or do I have to order on line?
    Thanks, Tom
  • Rudy615 Feb 25, 2008
    was able to purchase one at Radio Shack, works perfectly now. Thanks for your help.
    Tom
    President:
  • 1,944 Answers
Chances are it's the battery that needs to be replaced.
Posted on Feb 24, 2008
    Genius:
  • 3,422 Answers
Click HERE for the user manual and go through it carefully you will find the solution.
Goodluck..
  • 4 more comments
  • Priya darshan Feb 24, 2008
    But first i suggest you to go through the manual you will know when to replace the battery and also find some troubleshooting steps regarding the battery,and then if your problem is not still solved you will have to buy a new battery.
    I hope you are satisfied with my solution.
    did you refer the user guide which i gave you please go through it you will find a solution.
    alright then switch it off and then charge it and see if you get any indication.
    Let me know the result..
    Yes even i believe the problem is with the charger please give me 5min. i'll let you know from where to buy.
    Hi again.
    Please click HERE to buy the charger
  • Priya darshan Feb 25, 2008
    Your welcome..
    Thank you for using fixya.
The battery for my magellan maestro 4040 went dead. Bought a new battery charged it and it still doesnt work. Says battery critically low. what do I do. SQ
see my previous answer to the same question i have answered hundreds of times on here..
http://www.fixya.com/support/t5106611-loose_part_power_input_point_need
bill
Sep 13, 2010 | Magellan Maestro 4040 GPS Receiver
Won't turn on.
if you still have an issue with this, ill be glad to help you..just reply to this post ..(see my feedback)
YOU CAN NOT CHARGE A MAGELLAN 4040 WITH A USB CABLE!
if the green light is on, on your car charger, the charger is working..if its on (the green light) and still wont start after holding the power button for up to ten seconds, let me know and i will help you further.
May 06, 2010 | Magellan Maestro 4040 GPS Receiver
Installed a new battery in my magellan maestro 4040. battery has been charging for over 12 hours. only 2 bars like original battery.
with the 4040 plugged in to the charger, wiggle the cord to different positions and see if it loses contact (stops charging)
this model has a very common problem with the power port failing..iif it loses contact by testing it in the manner i suggested, it will require either a new one install or at the very least, resoldered,
let me know what you find and ill help you further.
bill
Apr 24, 2010 | Magellan Maestro 4040 GPS Receiver
Gps trouble
hi miguel9374,
check and see if its charging. turn on your 4040 and go to the mail menu, the use the arrow on the right and scroll to the next page, then go to the options tab, now the power tab..with the unit hooked up to a known good charger (the car charger should have a green or red light on, if its on, its working) in the power option tab youll see a battery meter, it should be moving left to right if its charging.
if its not, its probably the power port, which is a very common problem with this model and other magellan gps.
let me know if its charging or you might just need a battery, which i can point you to.
bill
Feb 27, 2010 | Magellan Maestro 4040 GPS Receiver
Have maestro 4040, its dead battery will not charge
Change the battery before giving up, also when put new battery charge it up from wall charger for about 8 hours before using.
Feb 19, 2010 | Magellan Maestro 4040 GPS Receiver
Will not charge thru the USB or the car charger. Is the battery replaceable?
a magellan 4040 can not charge through the USB port and if it wont charge with a known good car or home charger, then read below.
This is very common problem with this and many model of magellans.
Try the car charger.
Make sure
green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
The following Magellan 2000, 2200t, 2500, 3000, 3100, 3140, 3000, 3050, 4000, 4040, 4050, 5310 and the 6000 are known to have faulty dc connectors...if your Magellan
gps is not charging or will not power up, its most likely the dc power port...
You can
buy the port or get it repaired, HERE
if the links dont work or If you need further help, just let me know.
Jan 18, 2010 | Magellan Maestro 4040 GPS Receiver
Does not charge,problem with the plug in piece for charging battery
this is very common problem with this and many model magellans.
the following magellan800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get help to repaired it, here
or buy the port here
bill
Dec 27, 2009 | Magellan Maestro 4040 GPS Receiver
Does not charge
the power port is broken...very common on that magellan and others..i have the ports if you are capable of resoldering it yourself..
Jun 21, 2009 | Magellan Maestro 4040 GPS Receiver
I have a Magellan Maestro 4040. It is about 3 years old.
Magellan has to change the batteries But they will probably just sell you a refurbished unit.
BUT if your good you can take the thing apart and try to locate a replacement battery
Three years old? I'd try to find a battery
Which unit did you get last night?
Dec 10, 2008 | Magellan Maestro 4040 GPS Receiver
I have a Magellan Maestro 4040 That will no longer pingower on.
this is a very common problem with these magellan 3140 and also the 3100,2000,2200t,2500,4000,4040 and the 4050 most likely the power port is damaged and needs replaced.i have these power ports but often they just need re soldered..i can repair these magellan gps if you need help. if i cant fix it there is no charge.wmetz@comcast.net ... to open the case on a 4040 you must start on the power button side, otherwise youll break the unit
Nov 12, 2008 | Magellan Maestro 4040 GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
89 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
