Texas Instruments TI-86 Calculator Logo
Eugene Blackman Posted on Feb 12, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fractions why i canot do fractins on my t-86 caculator
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Texas Instru... Master 102,366 Answers
  • Posted on Feb 12, 2010
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10441420
Points
622693
Use the >Frac command in the MATH MISC menu to convert a value to a fraction.
What are rational numbers
Use the words: decimal part, not decimal fractin
Any number whose decimal part is periodic (has a recurring pattern that repeats indefinitely) is equivalent to a rational number, IS a rational number
0.345 345 345 ... =345/999=115/333
In the following screen captures, discard the last digit if it does not belong to a period. It is the effect of rounding up of the calculator
Period is 345
Period is 1
Period is 09
Period is 79
In general, if you have a decimal part of the form 0.d_1 d_2 d_3....d_n d_1 d_2 d_3 ...d_n ... where d_1 is the first digit of the period, d_2 is the 2nd digit of the period, ..., d_n is the n-th digit (and the last one) of the period, then the fraction representation of
0.d_1d_2...d_n d_1d_2... d_n ...=(d_1d_2...d_n)/(99...9) where the number of 9's in the denominator is equal to the number of digits in the period.
Once the fraction is found, one should reduce it to its simplest form.
7helpful
I need a caculator that you can change a fraction to a decimal
On the fx-115ES, to convert a single result to decimal press S--D. To have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
6helpful
Not sure on how to get a decimal into a fraction on the TI 86
The >Frac command on the second page of the the MATH/Misc menu will display the current value as a fraction.
WHY CAN'T I ADD FRACTIONS ON MY TI-86.
Because the TI84 does supports fractions in a funny way. Tap (3/4+1/2) then tap MATH and tap ENTER twice and you get the answer 5/4.
The TI 89 has a MODE called exact/approximate. In the exact MODE it does fractions; 3/4 + 1/2 = 5/4. In the approximate MODE it does decimals; 3/4 + 1/2 = 1.25
1helpful
Fractions on my texas tI-83
You get access the command by pressing [MATH][1: |->Frac].
If you want enter a fraction and keep it as a fraction (albeit a reduced one)
key in the number then the sequence [MATH][1: |->Frac]., then [ENTER].
Practice : 27/48 [MATH][1: |->Frac] [=] gives the reduced form 9/16.
While this fraction is still in [ANS] memory, you can press [MATH][2: |->Dec] [=] to get the decimal value 0.5625
Hope it helps.
2helpful
How to change decimals to fractins
MATH 1 gives you the ->Frac command, which converts a decimal number to a fraction.
1helpful
2answers
HOW DO I USE TI-86 FOR FRACTIONS
surround the fraction in parenthases.
1/64
would read (1/64)
Thanks for using FixYa - a 4THUMBS rating is appreciated for answering your FREE question.
4helpful
Decimals to fractions
Use the [2nd][MATH] keys. Scroll right [F6] to the softmenu [->Frac or To Frac].
Hope it helps.
20helpful
Fractions
When performing the calculations, put the fractions in parentheses. Then once you get your answer, press 2nd and Math (above the times button). Then press F5, MORE, and F1. It will have Ans Frac>. Then hit Enter and it'll change it to a fraction.
2helpful
6answers
Dividing fractions
well I`am having a promblem with fractins and its hard for me to divid a fration
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Jerry Naidoo
Paul Bade
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
