Question about Refrigerators
Refrigerator freezes food
We have a Magic Chef refrigerator that is about 15 years old. The refrigerator side is freezing everything. We had a repairman come out yesterday and he told us that we had to freezer control too warm and therefore it was blowing too much cold air into the refrigerator side. I understand the concept of how it works. However, he set the controls to approx. the middle range and said that should work. We put about 1/2 gallon of milk back into the refrigerator to test it and a few hours later it was frozen. We put a thermometer in it and it read 28 after a few hours. We set the freezer control to a higher temp (which should make the refrigerator warmer, right??) No difference, the refrigerator doesn't seem to ever go off. It is constantly running. What else can be wrong with it?
  • Anonymous Jun 28, 2008
    Our Whirlpool refrigerator is about 4 years old and the refrigerator side has started freezing. A brand new gallon of milk is frozen, while some stuff (like tortilla's) in a drawer are not. Both the freezer and refrigerator are on the lowest temperature settings. The water on the door won't even work now.
    President:
  • Refrigerators Master
  • 2,651 Answers
Sounds like might be a cold control issue, not cyclying on/off. if correct you dairy is good judge, so id assume that your ice cream is FROZEN SOLID. try turning down refrig temp control this will reduse run time(if working at all)
Posted on Feb 24, 2008
Magic Chef mini frig freezing everything.
The thermostat is part of the temperature control found on page 6 here=> MCBR445S1_Parts_List Parts can be found here=> MCBR445S Parts If you have questions please let me know, Thanks Sea Breeze
RF-7350-59 Temperature Control Thermostat
Dec 09, 2012 | Magic Chef MCBR445S1 Stainless Steel...
Magic Chef fridge too cold - defrosted it unplugged it - set the control to 1 and it still is freezing things
On the MCBR170 refrigerator the plastic clip the holds the the temperature probe to the bottom of the freezer compartment will break off and allow the probe to hang freely in the back of the fridge. This could be the problem with the refrigerator. I had this problem and used zip ties to hold the probe in the proper position. (see attached pics). magic-chef-fridge-cold-defrosted-3xqyivebcuprbty0n3yvm4ul-2-0.jpg magic-chef-fridge-cold-defrosted-3xqyivebcuprbty0n3yvm4ul-2-2.jpg
Aug 25, 2011 | Magic Chef MCBR170 Compact Refrigerator
A while back the refrigerator was freezing everything even though it was set on low. Even the veggies in the veggies drawers would freeze. Now, it stopped doing that but once in a while it will start...
Hi, There can be many reasons why your refrigerator is freezingyour food. To see what could be happening and to figure out how to possibly fixyour problem. Take a look at this tip which contains many of the causes andsolutions to fix the problems.
Refrigeratoris Too Cold and Freezing Food
heatman101
Jul 26, 2011 | Magic Chef CTB1722 Top Freezer...
Fridge is freezing all liquids freezer is turned down as low as possible and liquids are freezing
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Feb 24, 2011 | Magic Chef CTB1922 Top Freezer...
I have the Magic chef 18EYW-2 1.7 refrigerator and everything is being froze when set on 1. I have even tried setting on the preferred setting. Everything is still frozen. HELP! Thanks.
heatman101
Jan 05, 2011 | Refrigerators
Magic Chef MCBR445W1 seems like it dosen,t stop
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Check on the cold control if faulty, replace the cold control, not having found any other problem, do check on plastic air deflector at the top rear of the frig had been knocked off. replaced it if faulty. As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control, which is now functioning properly.
Good luck.......
Aug 01, 2010 | Magic Chef MCBR440 Compact Refrigerator
I have a Magic Chef refrigator and it freezes up
A bad defrost timer located on the right rear.
A bad defrost heater located in the freezer under the freezer floor panel.
Jul 07, 2010 | Magic Chef CTF1826AR Top Freezer...
Fridge keeps on freezing everything inside of it
This refrigerator only has one thermostat located in the fresh food compartment it is designed to activate the sealed system (cooling) until it reaches approximately 37 deg f in the fresh food compartment. The damper controls how fast the cold air can move from the freezer compartment to the fresh food compartment. Allowing you to control the temp in the freezer by controlling the flow of cold air to the thermostat.
You have one of two problems.
#1 your thermostat is no longer opening when it achieves set temp. fix = replace thermostat pn 61005798 $35
#2 your damper arm or assemblie has broken. Fix = Replace damper or broken arm and actuator.
damper assembly pn12001377 $44
damper actuator pn 61002000 $2
damper arm pn 61001999 $2
thermostat actuator arm damper arm
damper assembly both pics
Apr 06, 2009 | Refrigerators
Fridge is not cooling or freezing
can you tell me the model # on the fridge please? the motor is running continuously because it's trying to cool the fridge. it may be a few things, the defrost thermostat, the fan motor itself or the compressor.
Sep 13, 2008 | Magic Chef Refrigerators
Refrigerators Logo
691 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
