Back to:
Tags:
Garmin GPSMAP 276C GPS Receiver
Downloading mapsets
posted by dumela on Feb 24, 2008
I have different mapsets for my 276c garmin. Each time i select mapsets from mapsource to download it erases the previous mapset. How do i download different mapsets without erasing other mapsets.
I hope this makes sense.
Ian
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Feb 26, 2008
Not Rated (0)
hydetech
Rank:Wiz Wiz
Rating: 82%, 155 votes
Every time you download it wipes the entire memory card. You have to select all the maps you want stored on the card each time you add a new map. To keep from selecting all the maps everytime you want to download you can save the file in your mapsource software then just add or delete maps from your original map list.
All the mapsets that are installed in your PC should appear in the menu bar on a dropdown list. If you click on it you should see "bluechart" city navigator" etc, if you installed them correctly.
Choose one of the map sets, such as bluechart, from the dropdown list and all the maps from that set should appear on the screen.
As you select individual maps from the map set they will be loaded onto a maplist wich should appear under a tab on the left side of your computer screen.
Then go back to the menu bar and pick your next mapset, such as city navigator. A new map set will appear on the screen but the maps you selected from the previous set will still be on the map list on the left side of the screen.
I hope this helps. Please reply if you have questions about my response.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Downloading mapsets:
I don't want to Accept this solution
Can you Help with these GPS Devices problems?
GPS Devices
I have the Magellan 3000T I clicked on the - button at the...
hi despite of having a brand new battery,i still have...
My 276c do not wan to scroll the map even though the...
When I turn it on it won't go to any other screens and...
i have a 32mg memory card its empty , but when i try to...
Loading problems.
Repair Service
Find GPS Device Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
