Hello :) We have a frigidaire 12000 btu in wall unit. It was working fine lastnight but when we got up this morning (we had it set to heat -on 69 degrees) it was making a buzzing sound. I have tried turning it off for a few then turning it back on. It seems as though the fan will blow slightly but the heat ,compressor nor the air will kick on. what do I need to do?? Thanks for your help !!
  • 160 Answers
1. Switch off the AC first for a few hours
2. Remove the power connector
3. See that the Compressor is cool first
4. check the air tube and the blowers
5. Reconnect the same and connect the power cables
6. Swith on the AC then
If your problem solved plz rate me
Posted on Feb 24, 2008
What does H1 code indicate?
Hello E, I appreciate your post!
I see that your Frigidaire air conditioner is displaying an error code of "H1". I have reviewed the air conditioner and the "H1" error code could be an "HI". The "HI" error code means that the room temperature is above the display range. I would recommend performing a reset on your air conditioner. In order to reset the air conditioner you need to unplug the power cord you can press the reset button and then the test button that should restart your air conditioner. If that does correct your issue I would recommend seeking assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful for you. -Matt
Jan 22, 2016 | Frigidaire FRS12PYS1 12000 BTU Split...
Its a saftey in the heater the thermostat is probably fine
Jan 05, 2014 | Sanyo STW0923H2 Thru-Wall/Window Air...
Where does the water drain out of the unit on the frigidaire 10000-12000 btu and the 22000-285000 btu units?
The unit should be angled back to the outside. The water will run thru a tube from the indoor coil to the outdoor coil, then most fan blades have a slinger on them that picks up the water and throws it on the out door coil, which makes it more efficient but after time the water and dust will pile up on the coil and require cleaning at some point. If you clean the coil you can extend the life of the unit quite a bit. So you may not get any water to drip outside.
Jul 02, 2011 | Frigidaire Wall Room Air Conditioner...
How many tons is my unit?
divide your btu rating by 12000. (1 ton = 12000 btu)
For example - a 24,000 BTU Air Conditioner is a 2 ton unit. 24000 divided by 12000 = 2
A 18000 btu air condtioner is a 1 1/2 ton unit 18000 divided by 12000 = 1 1/2
you can find out your btu rating by looking on the tag on your unit.
Jun 07, 2011 | Heating & Cooling
Kenmore 12000 btu turns on fine but after a few minutes fans shut off and compressor keeps running this is a heat and air model
First replace fan capacitor and try, if not, bearings worn out in your fan motor. Replace bearings or motor with new capacitor.
Jan 14, 2011 | Kenmore 76081 Wall/Window Air Conditioner
Can a 12000 BTU thru the wall AC be installed as a
Yes... no problem... just need to use cardbord of something to seal off the open spaces around it...
Jul 21, 2010 | Frigidaire FAH106N1 Wall/Window Air...
Frigidaire fac127p1a 12000 btu compressor
The compressor is probably going out on either a pressure related or heat related overload. Both are a result of low refrigerant. There may be a low pressure safety swich that protects the compressor. Otherwise it may be an internal thermal overload that is tripping. It resets itself and comes back on. The thermal overload heats up and shuts off the compressor to protect it from too much heat which is gernerated by not enough refrigerant in the system to keep the compressor cool. It may be cheaper to replace the unit than have someone try and fix it. It is pretty time consuming and you cannot try it yourself unless you have an EPA Certificate to buy the refrigerant. Check with your local appliance repair man to see if he will tackle it.
Jun 04, 2010 | Frigidaire 12,000 BTU Compact II Room Air...
Installed Amana 12000 BTU wall pack type airconditioner yesterday. How do I get machine not to turn off and on during operation? Do I set it to run automatic? If I set it "cool" low stetting at 69 degrees,...
You definately want the compressor to shut on and off with the demand set by the thermostat. It is no different than a full size home split heating and cooling system. You set the thermostat for the temperature you want and then you let the system decide when to run the compressor
Mar 09, 2010 | Heating & Cooling
Heating & Cooling Logo
135 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
