Question about Microsoft Xbox 360 Console
Wireless adapter My Xbox 360 adapter flashes red once when plugged into my console and does not work. I unplugged it and tried another USB port (on my computer) to see if it was a power supply from the console or the adapter. When plugged into the computer, the adapter light stayed on - orange. There is only one usb port on my console, I have read to try another port on the console but can't find one. Thanks in advance for any help, Cody
    Genius:
  • 1,019 Answers
What exactly are you refering to Here ( adapter ) The Power Brick, A wireless or wired Controller ?
There are 2 USB Ports on an XBOX 360 same place Front R/H/S Slot Side By Side.
Mike @ Compurepair.
If it,s Orange ( whatever it is youre refering To ) then it,s in standby Mode. Red ( error/Fault ) Green working OK.
Hope this helps.
Posted on Feb 24, 2008
Older XBox 360 with wireless antenna - can't connect to network - why not?
What color does your wireless adapter (xbox) turn when you power on your xbox? Green, Red, or Grey (No light)?
If it's grey(no light), try connecting the adapter into one of the USB ports in front of the console(the usb ports are behind that flap)
If it's red, it's a hardware problem and you should try and repair it.. or replace it (xbox antenna).
If it's green, then it's something to do with your network settings.
Good Luck
Jan 12, 2013 | Video Game Consoles & Games
Tip
Setup your Xbox to a Wireless Network
Xbox game consoles can be connected <span style="text-decoration: underline;"></span> to a router<a href="http://compnetworking.about.com/cs/routers/g/bldef_router.htm"></a> for wireless access to the Internet and Xbox Live. Follow these instructions to set up the Xbox or Xbox 360 connections to a wireless home network.<br /><br /> <ol> <li>Connect the appropriate wireless network adapter<a href="http://compnetworking.about.com/od/hardwarenetworkgear/g/bldef_adapter.htm"></a> to the console. On the Xbox, a Wi-Fi adapter that connects to the Ethernet sometimes also called a wireless network bridge must be used. Alternatively, the Xbox 360 is also designed to work with certain Wi-Fi <i>game adapters</i> that connect to a USB port.<br /><br /></li> <li>Turn on the console and navigate to the wireless settings screen. On the Xbox, the menu path is "Settings -&gt; Network Settings -&gt; Advanced -&gt; Wireless -&gt; Settings" On the Xbox 360, the menu path is "System -&gt; Network Settings -&gt; Edit Settings."<br /><br /></li> <li>Set the SSID (network name) on the Xbox to match that of the wireless router. If your wireless router has enabled SSID broadcast, the SSID name should appear pre-selected on the Xbox display. Otherwise, select the "Specify Unlisted Network" option and enter the SSID there.<br /><br /></li> <li>Specify "Infrastructure" as the Network Mode. (Infrastructure is the mode used by wireless routers.)<br /><br /></li> <li>Set the Security Type to match that of the wireless router. If your router uses WPA encryption and the type of adapter connected to the Xbox does not support WPA, you will need to change your router settings to use WEP encryption instead. Note that the standard MS Xbox Adapter supports WPA while the standard Microsoft Xbox Wireless Adapter (MN-740) only supports WEP.<br /></li> <li>Save your settings and verify the network is functional.<br /><br /> On the Xbox, the Wireless Status screen displays whether a connection has successfully been made with the wireless router, and the Connect Status screen displays whether a connection has successfully been made through the Internet to Xbox Live.<br /><br /> On the Xbox 360, use the "Test Xbox Live Connection" option instead.</li></ol> Tips: <ol> <li>Even when your wireless connection between the Xbox and the router is working perfectly, you may still experience difficulty connecting to Xbox Live. These issues can be caused by the quality of your Internet connection or the firewall and Network Address Translation (NAT) settings of your wireless router. Additional troubleshooting may be required in these areas to achieve reliable Xbox Live connections.</li></ol><span style="font-weight: bold;">Troubleshooting</span><br /><br /> The built-in diagnostic of the Xbox can help with any falure.Navigate to the <i>System</i> area of the Xbox Dashboard, select the <i>Network Settings</i> menu option, then select <i>Test Xbox Live Connection</i> to run the test at any time. If the Xbox 360 built-in network diagnostic fails with the following message: <br /> <ul><i>Technical configuration error. Please contact Xbox Customer Support.</i></ul> This indicates a network issue requiring further investigation. The Xbox 360 network diagnostic contains the following tests run in the order listed below. Steps for troubleshooting Xbox 360 connectivity issues depend on which test reports the failure. <br />If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /> <b>Note</b> You can use an Xbox 360 Wireless Networking Adapter with the Xbox 360 S console. If your wireless router is not near your console, you may get a better wireless signal by using a wireless networking adapter. When you connect an Xbox 360 Wireless Networking Adapter to an Xbox 360 S console, the console will automatically use the wireless adapter instead of the built-in Wi-Fi.<br /> If you have an original Xbox 360 console, you need to attach an Xbox 360 Wireless Networking Adapter before you can connect your console to a wireless network.<br /><br /> Step 1: Attach an Xbox 360 Wireless Networking Adapter to the back of your Xbox 360 console.<br /> Step 2: If a network cable is plugged into the back of your console, unplug it. Step 3: Check the light on the Xbox 360 Wireless Networking Adapter.<br /> If you're using the black adapter with two antennas:<br /> <ul> <li><b>No light:</b> The adapter is not receiving power. Unplug the USB connector, and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.</li> <li><b>Green:</b> The adapter is connected to a wireless router, gateway, or access point.</li> <li><b>Flashing green:</b> The adapter is attempting to connect to a wireless network.</li> <li><b>Red:</b> The adapter is not recognized. Try plugging the adapter into a USB port on the front of your console. </li> <li><b>Flashing red:</b> There is a problem. The adapter might be experiencing a hardware failure.</li></ul><br /> Configure your wireless settings Go to <b>My Xbox,</b> and then select <b>System Settings</b>. <br />Select <b>Network Settings.<br /></b>Select <b>Configure Network</b>.<br /> <ol> <li>On the <b>Basic Settings</b> tab, select <b>Wireless Mode</b>. <br /> <b>Note</b> If Wireless Mode is still not available, there might be a problem with your hardware. <br /></li> <li>Select <b>Scan for Networks</b>. </li> <li>Select your wireless network name. <br /><br />If your wireless network is not listed, try either of the following:<br /> <ol> <li>Try improve the router signal by moving the router position.If you are not broadcasting your wireless network name, select <b>Specify Unlisted Network</b>, and enter your wireless network name and security type. </li></ol></li><br /> <li>Enter your wireless network password, and then select <b>Done</b>.</li> <li>Press the <b>B</b> button on your controller, and then select <b>Test Xbox LIVE Connection</b>. If you successfully connect to Xbox LIVE, you'll see this screen:Choose <b>Yes</b> when you are prompted to update the console software. <br /></li></ol>
on Jan 18, 2011 | Video Game Consoles & Games
Tip
How to set up the Xbox 360 Wireless N Networking Adapter
Overview
If you connected to Xbox LIVE after October 28, 2009, a software update was installed on your Xbox 360 console to support the Xbox 360 Wireless N Networking Adapter. If the update was installed on your console, all you need to do is to configure the wireless settings. To learn how to do this, please see the following article:
908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
If you have not connected to Xbox LIVE since October 28, 2009, you will need to use the installation disc included with your Xbox 360 Wireless N Networking Adaptor to install software on your Xbox 360 console.
To install the software for a Wireless N Networking Adapter
1. If an Xbox 360 Wireless N Networking Adapter is plugged in to your console, unplug it.
2. Insert the installation disc included with the Xbox 360 Wireless N Networking Adaptor into your Xbox 360 console.
3. Turn off the console.
4. Turn the console back on.
The software update should start automatically. If the update does not start automatically, the software might already be installed.
Note If you receive a mixed media error message, please see the section titled "Mixed media error message" below.
5. When you are prompted to install the software, select Yes, update now.
6. If a network cable is plugged in to the back of your console, unplug it.
7. Once the installation is complete, plug the Xbox 360 Wireless N Networking Adaptor into the USB port on the back of your console.
For information about attaching and configuring your wireless adapter, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
8. Remove the installation disc from the disc drive.
9. Turn off your console, and then turn it on again.
If you receive a mixed media error message, auto-play might be turned off. Here’s how to turn it on:
1. On your console, go to My Xbox, and then select System Settings.
2. Select Console Settings.
3. Select Auto-Play.
4. Select Enable.5. Repeat the steps for installing the wireless adapter (above).
Next step:
For information about how to configure the wireless settings on your console, please see the following article: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 consoleDo not try to repair the wireless networking adapter.
Do not take your Xbox 360 console or accessories to a retailer for repair or service unless an Xbox support agent instructs you to do this.
Do not try to disassemble, service, or modify the Xbox 360 console, the power supply, or any accessories. If you do this, you might put yourself at risk of serious injury or death from electric shock or fire. For your own safety, such actions will void your warranty.
on Mar 04, 2010 | Video Game Consoles & Games
Wont stop flashing green and I can not connect to xbox live yet I used to be able to Any Help Thanks, Paul
IF The LIGHT IS FLASHING GREEN then there is something wrong with your wireless network
Check your network settings and Retry connecting
Check the adapter's status light loadTOCNode(2, 'moreinformation'); The adapter's status light can tell you a lot about the state that the adapter is in. Here's what the different lights mean:
  • Steady green light: The adapter is connected to a wireless router, gateway, or access point. The adapter is ready to use.
  • Steady red light: The adapter is not recognized. Try plugging the adapter into a USB port on the front of the Xbox 360 console.
  • Flashing green: The adapter is attempting to connect to a wireless network.
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support at http://www.xbox.com/support/contact (http://www.xbox.com/support/contact) .
  • No light: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console
Jan 10, 2011 | Microsoft Wireless Network Adapter Xbox...
I have an ac adapter for the new xox 360 250 gb , that has the red light lighted up that means false alarm what should i do to get it back to green its been 1 week?
Check the status light on your adapter The state of the adapter's status light indicator can tell you the status of the Xbox 360 Wireless G Networking Adapter. Here's what the different lights mean:
  • Steady red light: The adapter is ready to be configured. For information on how to do this, please see: 908877 (http://support.microsoft.com/kb/908877/ ) How to configure wireless settings on your Xbox 360 console
  • Flashing red light: There is a problem. The adapter might be experiencing a hardware failure. Contact Xbox support.
  • Not illuminated: The adapter is not receiving power. Unplug the USB connector and plug it in again. Still no light? Try plugging the adapter into a USB port on the front of the console.
  1. On the console, go to My Xbox, and then select System Settings.
  2. Select Network Settings.
  3. Select Configure Network.
  4. On the Basic Settings tab, select Wireless Mode.
    Note If wireless mode is not available and you are using the black Wireless N Networking Adapter, try using the software installation disc included with the adapter. For more information about how to do this, please see the following article:
    977641 (http://support.microsoft.com/kb/977641/ ) How to set up the Xbox 360 Wireless N Networking Adapter
  5. Select Scan for Networks.
  6. Select your wireless network name.
    If your network is not listed, try the following:
    1. Select Specify Unlisted Network, and enter your wireless network name (also referred to as your Service Set Identifier [SSID]).
    2. Select your wireless security: WEP, WPA, WPA2, or No Security (if your network doesn't have a password).
      If you can't connect to your wireless network, try improving your wireless signal using the tips in the following article:
      909336 (http://support.microsoft.com/kb/909336/ ) Your Xbox 360 console receives a weak wireless signal
  7. Enter your wireless network password, and then select Done.
    Note Make sure that you have entered the correct password. An incorrect password might allow your console to connect to your wireless network, but you might receive an IP address error when you test your Xbox LIVE connection.
  8. Press B on your controller, and then select Test Xbox LIVE Connection.
    If you receive an error message, please go to www.xbox.com/networkhelp (http://www.xbox.com/networkhelp) for further help.
Dec 03, 2010 | Microsoft Wireless Network Adapter Xbox...
How to setup xbox live
To set up the connection via a router unplug the router and the modem and turn off the 360. Connect an Ethernet cable to one of the out ports of the preexisting router then connect the cord to the back of your 360. Plug everything back in and turn and give the modem and router about 3 minutes to reboot.
Once you have given everything a few minutes to reboot you can turn the 360 back on. If you have already set up a gamer profile you will see the Xbox Live screen. If you have not set up an account you will be prompted to do so. All you need to do is follow the on screen instructions. It is a pretty cut and dry process and should not take more than 10 minutes of your time.
If you want to go wireless or you must go wireless you will need to get the Xbox360 wireless network adapter. The adapters are available at most stores that sell 360 games or you can order it online. Once you have the adapter unplug any Ethernet cable you might have plugged into the 360 then clip the Network adapter to the back of the 360. It is really easy to see where it belongs, but just in case, the adapter will sit right alongside the USB port which is right above the Ethernet port. Once you have clipped it in plug the USB cable that is attached to the adapter into the port on the Xbox 360. Flip up the antenna that is laying flat against the adapter and you are set, well almost set.
Turn on the 360 and head into the System tray. You will see Network options, go ahead into that screen and follow it through to the "Edit Settings" subcategory. The Network name should appear on a list of available networks. Select your network and enter the password, if there is a password. Exit out and you should be ready to play.
Nov 27, 2010 | Microsoft Xbox 360 Elite Console
My Microsoft Xbox 360 Wireless Network Adapter stopped working.
Shut off your console and unplug everything.
Connect the adapter then connect the console back together...Turn on console......Go to network configuration...Make sure u are connecting the adapter from the back!
If you are not able to achieve a connection for several attempts this means your should check warranty status for the adapter also.........If you unplugged it while the console was one you could of shocked the cable an blew the fuse.......Normally when u detach any components with a usb port u should alway make sure every thing is shut off before so.
Jan 14, 2010 | Microsoft Wireless Network Adapter Xbox...
Wireless 360 Network Adapter won't turn red
This can actually happen quit a bit but it sounds to me like the usb jack may be dieing or not producing enough power. This can be caused if for instance you use wired controllers. Have you tried using the front usb ports.
Oct 12, 2009 | Microsoft Wireless Network Adapter Xbox...
Msg on xbox says ''not connected''
sure, the usb port must be the back port, when you plug it in the light on the wireless adapter should be red. Once you turn the xbox on, the wireless should turn green. Go to test xbox live->test xbox live->edit settings-> the wireless settings should be at the bottom (the 3rd one down) click on it, (here if you have a password for your network insert the password. -> (press b to back out once) and test xbox live again. It should work if it doesn't please let me know, i'm doing the settings off the top of my head.
Hope it works.
Nov 23, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
116 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Stormi  Paulk
Stormi Paulk
Stu Morris K
shaun taylor
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
