Question about Vacuums
Kenmore Whispertone model 116, 29512991
I have a vaccum purchased around 1998 - the vacuum has stopped working - I have checked the continuity of the house (so I know the on/off switch works) - looking for recommended troubleshooting steps - also, how do I get into the vacuum to check the motor? Pull the retractor lever (I think there are screws under there)? could the motor have worn brushes?
thanks!
  • Anonymous Mar 22, 2008
    suction power turns off
  • Anonymous Jun 20, 2008
    I turned on the vac only to discover I had absolutely no pull whatsoever. It had worked fine, then nothing.
Unfortunatly what happens is the dirt that gets sucked up goes over the moter and ruins the motor. the fact that it lasted this long is suprising. the motor should be right behind the bag the only one that ive seen that isnt there is a kirby! I hope this helped you!
Posted on Feb 27, 2008
Manual for kenmore whispertone 300
Which specific model in the WhisperTone line do you have? The manual may be available from Sears Parts Direct. Start here: http://www.searspartsdirect.com/partsdirect/user-manuals .
The manual for the Kenmore 116.27512790 canister vacuum is available here: http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0807641.pdf . This may be useful if the vacuum is similar to yours.
I hope this helps.
Dec 21, 2014 | Kenmore Vacuums
Was using kenmore whispertone stopped suddenly disconnected brush unit will not switch on ????
if you took the hose out of the wand assembly then it may not turn on as the hose handle has a power button on it and must be connected to turn on the unit.Also check the powerhead for a reset button (small red / or black button on the back of the head){back of head not the bottom}
Oct 05, 2010 | Kenmore 23313 Whispertone Bagged Canister...
I have a Wisperingtone Cannister 100 purchased in early 80sbeater bar won't turn...something may be stuck...how do I remove cover plate? Thanks.
Take the pwerhead off your vac.
Face the beater bar upwards toward you.
Remove 4 Philips screws.
Remove the plastic shroud from the bottom of pwerhead.
Carefully remove one end of the beater bar, (the end opposite to the belt)
Remove the belt end.
Now depending on your model... you should be able to remove both ends of the bar.
usually there is thread or carpet fiber wrap around the bar.
You mention the 80,s,which also tell me they had a copper fitting where the axle of the beater bar meet. Trying to relace the end pieces may be a task and a half... So purchase the whole unit from the manufacturer.
Have fun vaccuming
Jul 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore whispertone 100 model 116. powerhead no
  • The motor / cord compartment cover must be removed to access the cord reel. There are four screws that hold the cover to the chassis. Two of the screws are found under the cord-retractor-foot-pedal on the top back of the canister. To access these screws the pedal must be removed. To do this, press the pedal down and look (from the top) for the four plastic clips that attach/hold the pedal hinges to the cover. There are two at the end corners and two in the middle. Using a long, thin flat-head screw driver (or similar instrument) press each clip to unhook/popout the hinges. Note: the foot pedal spring will also come out when the pedal is removed.
    The other two screws are found under the curved hinges of the vaccum bag compartment cover. To access these, lift the cover as if accessing the vacuum bag. Keep pulling the cover back until the hinges release from the motor cover. Don't worry, it is disigned to do this and will not break but it may require a little force. A long phillip-head screw driver will be needed to access and remove each screw
Jul 18, 2009 | Panasonic Kenmore Canister Vacuum Vacuum
I have a kenmore whispertone 5.1 and need to find out if it has a hepa filter. I don't think so..... Thank you!
Hi If its the same as the one shown here:
http://cgi.ebay.com/KENMORE-WHISPERTONE-12AMP-HEPA-VACUUM-WARRANTY-AVE_W0QQitemZ310151428708QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4836773a64&_trksid=p3286.c0.m14&_trkparms=65%3A12%7C66%3A2%7C39%3A1%7C72%3A1205%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
That model has a HEPA filter.
Otherwise the older models don't have them and rely purely on Allergy bags that you can buy for your vacuum.
Jun 27, 2009 | Kenmore Whispertone 23312 Bagged Canister...
While using the vacuum, the brushes stopped turning.
check the drum. Hair will rap around the axxel and stop the brush from turning. Cut this hair with a razor and place a small drop of oil on the end of the axel.
May 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Whispertone 100 connection issues
find a used one at a vac repair shop, its just worn out
Aug 01, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Replace Kenmore Vacuum Hose
check out this solution http://www.howtomendit.com/answers.php?id=25754
Jun 07, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
479 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
