Question about Samsung SGH-D900 Cellular Phone
D900i display crack - repair instructions / manual
My display broke on a skiing trip and before deciding to buy a spare display i want to be sure about the effort necessary to replace it. As far as display traders assure no soldering is necessary.
How do you open the phone to replace the display. The two screws on the right and left side of the camera won't open the phone entirely. Are you aware of instructions or other sources where the proper way of opening is desceribed?
Thanks for helpful comments.
Did you allready fix it? i have te same problem.
Posted on May 19, 2008
Earphone not work
Posted on Apr 28, 2008
How to get rid of the crack on my ipod?
Phone repair shops can replace the screen. But it will cost. Knowing Apple is lowering the price for the new iPod Touch, I think you should try to fine out what a repair will cost and then decide to a repair or buy a new one.
You also could visit ifixit.com, because they show how to repair yourself. They also know what a new screen will cost and sell tools and spare parts if you need so.
Jul 12, 2014 | Apple iPod touch
Tip
Re furbushing / Repairing a cracked above ground spa
<p>Unfortunately, there are only a few ways to treat the cracks once they have occurred in the shell of the spa. Most repairs offered by "do-it-yourself" products are temporary and will only lead to additional frustration. <br /> <p>This is where years of experience can help out! <br /> <p><br /> <p>Spas are usually molded as a compete unit and then the jets are either cored into the completed shell or are part of the moulding process. Either way, the majority of all acrylic or above ground spas are a single piece. <br /> <p>What this means, is that in order to make a "solid" repair, you will need to treat the entire shell interior.<br /><br /> <p>One of the first real repairs we learned about that is not only affordable, but fairly consistent came from a boat/jet ski repair shop. I had a set of jet skis in the shop and one of them was really damaged. The repair tech had to cut out an entire side of the ski and rebuild it. When complete, you would never know that anything happened! <br /> <p><br /> <p>A lot of these businesses have mobile repair technicians who will actually do the repairs on the spot and are already familiar with various resins, polymers and color matching. The are also great at improvising the repair as they go, because rarely does damage to a boat or ski be consistent with other repairs. <br /> <p><br /> <p>Be sure to ask about the cracks. Cracks usually occur because of shrinkage and if they can separate the areas that are shrinking/have shrunk and then rebuild these areas, you probably won't have a problem again. <br /> <p><br /> <p>We have made similar repair to more than 500 spas and have had issues with less than 1% of the repairs failing. Pretty good odds, if you ask me!<br /> <p><br /> <p>If you are unable to find a boat/jet ski repair guy, you may trying looking under bathtub refinishing. A lot of bath tub refinishing technicians are familiar with working with fiberglass and custom working as you go. <br /> <p><br /> <p>In order to extend the life of the interior of your shell, you should be diligent in cleaning the spa a couple of times a year. Most pool supply stores have a citrus cleaner that works great at cutting through the body oils, lotions and other that may become attached to the spa.<br /> <p><br /> <p>If your fiberglass is starting to feel a bit worn, find out about we sanding and sealing, this will ensure that your spa lasts you many, many years!<br /> <p><br /> <p><br /> <p>Your feedback on thisr is appreciated!<br /> <p> <br /> <p>Brian Morris, The Ugyl Pool Guy<br /> <p><a href="http://www.WeFixUglyPools.com">www.WeFixUglyPools.com</a> <br />
on Dec 12, 2010 | Pool & Spa
Not getting gas to fuel pump
Make sure your hose inside the tank is not broke or cracked.
Mar 21, 2014 | Ski-Doo 2005 Summit Fan 550
My RC snowmobile has a broken ski axle and the track is broke in two.
buy a new ski axle and track...
Lokks like you were having TOO MUCH fun with her!
Mar 24, 2013 | Toys
Frost cracked housing, are spare PBT-GF20 AVAILABLE
Open following link for some Gardena resources, including manual and link to gardena site.
http://waterheatertimer.org/How-to-program-Gardena-C1060.html
Gardena certainly has a glossy site, but I have been unsuccessful trying to contact the company.
Their products come with warranty and they show parts, but no hint where you can buy parts.
If frost crack the device, then it means the whole device was pushed out of shape until something broke. Frankly, I would not spend money trying to fix a cracked piece of plastic.
Apr 23, 2011 | GARDENA Water Timer
Lcd cracked on sgh d900i how to fit new one?
hi,it could be fixed,just kindly take it to a mobile phone engineer to fix it up for you.you will needto buy a new lcd before it could be fixed.and also its a hardware problem.thanks.
Mar 08, 2010 | Samsung SGH-D900 Cellular Phone
Hello, I tripped over the power cord and the Acer Aspire One fell to the floor from the fireplace so about 3 1/2 feet. Now it will not show anything on the screen but green power light does come on and if...
My thoughts is that one if not a couple of the PC boards inside is cracked or broke. More than likely you broke the inverter power board which lights up your display.
May be a time for a new laptop. Would cost more to repair than to buy you an new laptop.
My thoughts is you may find another one on E-bay that has some minor issues or in need of a hard drive and you could take the hard drive out of yours and put it in the new/used one.
Blessings,
A/V Media Guy
Nov 23, 2009 | Acer Aspire One Netbook 8.9" Notebook
Mitsubishi WT-A42
I repaired a convergence problem on this model by locating IC8C01 and IC8C02, the two large convergence chips on the main pcb(center board) and solder all the leads making sure not to leave any solder bridges! The unit was over 4 years old and used often. Those chips get pretty heated and make the solder brittle and crack around the leads.
Dec 30, 2007 | Mitsubishi WT-42315 42" TV
Samsung SGH-D900 Cellular Phone Logo
456 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
