Question about Dell E151FP 15" Flat Panel LCD Monitor
White screen i have a e151fp flat screen and after about ten minutes of use the screen goes white can you help thanks
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After they shut down on their own, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 25, 2008
Milk white screen.
HELLO!!!
Try updating the display drivers ... Hope it turns goos after the update ...
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Ten year old emerson 27" flat-screen tv has multiple thin white horizontal lines and has audio
Backlight CCFL lamps fault. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience.
http://electronicshelponline.blogspot.com/ Pull up older posts.
Mar 30, 2014 | Emerson Televison & Video
Hi there the problem is, The techwood 42" tv that we have is ok for the first ten minutes. Then after that the tv screen goes white. Then after about another ten minutes the picture is fine.Do you...
Hi, i think there is a loose or bad solder. try to inspect the power board for loose solder or in the area of the inverter board, resoldering some capacitors may electrecute you . leave the set unplugged for an hour before resoldering to allow discharging. you may replace some capacitors that seems slightly become fat..
Mar 06, 2011 | Televison & Video
Monitor goes to white
If I remember correctly on some version of this model uses male/female connector on the logic board directly on top of the LCD panel, if you press on the logic board, the problem will go away, it jsut bad design, later model uses rinbbon cable instead. You can try reseating the board to see if it will work OK.
http://s807.photobucket.com/albums/yy352/budm/LCD%20panel/
Mar 27, 2010 | Dell E151FP 15" Flat Panel LCD Monitor
Dell monitor white screen
Some people have disassembled the LCDs, and resoldered all cracked or corroded solder joints to get them to work again.
Oct 12, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Blinking Orange LED light on E151FP monitor
This monitor is know for a lot of parts that go bad, luckily they are usually the same ones.
If you are a technician or know one who can help you. Below is a list of part to repair/replace once the case is opened. (dont try this if your unfamilier with working on electronics.
1) F601= 2A Fuse
2) C605= 68uf 400v (must change)
3) R615= 0.68ohm 1watt
4) Q601= SSS6N60A
5) R613= 1Kohm 1/8watt (value changed to 2.3Kohm or higher)
6) R623= 4.7ohm 1/8watt (value changed to 7.2ohm or higher)
7) D604= 1N4148
8) IC601=UC3842B
9) C707 & C703= 1000uF 16V (must change, because of bad ESR value) secondary filter capacitor.
This problem of dell e151fp lcd monitor, you just need to resolder the inverter section (bad points or dry joint) and also check the capacitor value with ESR meter. It will solve your problems.
Sep 14, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
White screen
Hi...there,
It's seems your AD Board is defective. Need to updated a bios or replaced a new AD Board. If that still doesn't work... then your panel it damaged. Good lucks!
Jun 26, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Dell E151FP 15" Flat Panel LCD Monitor Logo
247 people viewed this question
Alun Cox
