Question about Garmin StreetPilot C330 GPS Receiver
Sp330 Screen froze. I let the battery die and then hooked up power, Screen came back but it says it can not unlock the maps? Please advised.
    Novelist:
  • 113 Answers
Gently pry off the grey face plate and underneath you will find a reset button. Try that and let me know if it helps.
Posted on Feb 26, 2008
Mother's scooter keeps dying
How old is the battery they don't last forever and they are not cheap
Sep 28, 2015 | Pride Go-Go Elite Traveller 4-Wheel Travel...
My screen is froze
Hi, you have to turn off your phone and then turn it back on. If the power button doesn't work then you can wait for it to die or simply take out the battery. Once restarted the problem should go away.
Oct 09, 2013 | Samsung Montage Virgin Mobile
Garmin froze with a "Map Update Notice" the screen
The unit isn't frozen. If you tap the power button you will hear it beep and change screens. What has happened is your touchscreen has failed. This is a common problem. Your touchscreen needs replaced. If you want some troubleshooting info, please see this link. There is just too much info to retype here:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Mar 20, 2011 | Garmin Nuvi 660 GPS Receiver
While using my Magellian GPS 1200 the screen froze up and when I went to restart it the following messang appeard.SD card has been removed.Program will restart.Please insert SD card with map. I tried re...
More then likely when the screen froze up on you it it had a little power glitch as well, nothing serious but it did wipe out some of the information in it's memory about the SD card.Power the unit up and let it come up with the error, then use the reset button. Might be hard to find since it's just a little hole with the word reset around it, using a paperclip push in the button and see what happens. If the error comes up again then i am thinking that you will need a new SD card. Quick test for this, remove the SD card from the gps unit and try rebooting, it should come up with an error, no SD card or no map, stick in an SD card from another device, 2gb, see if the gps can find the card, it should give you an error that says unable to find maps. If you get these error codes then most likely the gps unit is fine but it pooched your programs on the SD card.
Hope this helps
Apr 27, 2010 | Magellan Roadmate 1200 Car GPS Receiver
Screen frozen, button and power button do not operate,
Just unplug it and let the battery die out. Then after is shuts off plug it back in and start it up. Annoying process but it's all that will work at this point.
Feb 06, 2010 | Garmin nuvi 255W GPS Receiver
Frozen Screen
I had this problem and the only way to solve a frozen screen is to let the unit run out of battery and bring it back to life. Battery will die out on you for 6~8 hours. Once battery is dead you must do the following.
Waking up your c330...
If you left your Garmin c330 on running the battery will have 1% life left. If you turn c330 back on again, it will flash screen for 3 seconds then die, even charging it at this point will not wake it back up. TO BRING IT BACK TO LIFE... plug in the power home or car into Garmin c330. There is a tab in the front Garmin gray frame of your screen. You must take like your fingernails and under the logo "GARMIN" pull the whole gray plastic frame off. Underneath the plastic frame to the right hand side. There is a "RESET" button. Make sure power is plugged in while hitting reset. Your battery should come back to life. Cheers
Mar 28, 2009 | Garmin StreetPilot C330 GPS Receiver
My GPS froze
its the battery problem as its getting drained and near to getting weak.
Mar 02, 2009 | Garmin Nuvi 660 GPS Receiver
Street pilot is dead
It took a nap...
Aug 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Frozen screen on Magellan RoadMate 2200T
Press the button to turn it off but hold it for about 10 seconds. Let go and then press it to turn it on. This resets it.
May 22, 2008 | Magellan RoadMate 2200T GPS Receiver
Garmin StreetPilot C330 GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
