Stacic route I require to add the following ip route 192.168.225.65 255.255.255.255 160.123.229.115 ip route 192.168.225.65 255.255.255.255 160.123.229.103 which value sho be add here
  • kaasmat Feb 25, 2008
    Sorted thanks did had to add an value on the 2nd static entry.Cisco router.
  • Jocelyn Viau
    Jocelyn Viau May 11, 2010
    What are you trying to do? On what kind of router? I see that you want to add 2 routes for the same host IP address?
    Problem Solver:
  • 10 Answers
The 192.168.225.65 is the IP address or default Gateway
The 255.255.255 is the Subnet Mask
And the other no idea but maybe is from you ISP.
Bye
Posted on Feb 26, 2008
Static route for two different subnets
You did not say where are your two computers. Anyway, computers should work on most subnets routes except between 10.20.30.0 and 10.20.40.0 subnet.
Static routing should be set on two computers not on routers.
Assume computer A is connected to 10.20.30.252 Router A and Computer B is connected to router B.
On Computer A, you need to add route to -inet 10.20.40.0/24 via GW 203.187.106.147, and on computer B to set rotue to -inet 10.20.30/24via GW 203.187.106.138. That is all you need.
Apr 04, 2014 | D-Link Computers & Internet
Tip
OpenBSD Change Default Gateway
Add route from a command prompt: All You need to know is the network block you want to route, netmask for that block, and the IP address you want them routed to:
# route add 192.168.1.0 -netmask 255.255.255.0 192.168.1.254
on Jun 25, 2010 | Computers & Internet
How configure proxy on mp114 fxs
Download your INI config file and search for ISPROXYUSED under [SIP Params] block, if is not there add the line as follows:
ISPROXYUSED = 1
Then search for ProxyIp 0 under [ProxyIp] block and if there is no line add it as follows:
ProxyIp 0 = your.proxy.ip.address, -1, 0;
This will set a unique proxy IP address for all the SIP outgoing traffic of your MP, if you wish to use more than one SIP Proxy you may want to consider setting IP address on Routing menu.
Feb 15, 2011 | AudioCodes MediaPack MP-114 FXS
How do I add a static route
using DOS type the following cmd:
add ip route ip_adress mask
Jan 07, 2010 | Computers & Internet
I want to add new ip route. I can not. AP_600_Bukhara> add ip static-route.192.168.9.0 mask.255.255.255.0 tos.0 next-h op.195.69.188.92 AP_600_Bukhara>
Hi
hey you can try this command
router(config)# ip route 192.168.9.0 255.255.255.0 195.69.188.92
Might it helps you
Thanks
Harmeet :)
Oct 29, 2009 | Lucent Access Point 600 Router
My machine displays on the LCD: "machine error 68"
First, I would recommend NOT trying to manually install this printer by using the add printer wizard in windows and selecting the the port and drivers to use. I would use the install cd to set this all up, it makes setting up this printer MUCH easier. If you are unable to use the install cd then get the IP address for the printer from your router admin page then with the printer "installed" go into the printer properties, go into the port, add a port, and instead of using a printer name just type the IP address for the printer in. Also for any networked printer make sure you don't have a firewall blocking it (this would include making sure that if the printer requires a port opened in the router that all requests for that port are routed to the IP address of the printer).
Jun 18, 2009 | Brother MFC-8820D Laser Flatbel...
Routing vlans on 3com switch 4500
i can't set ip address over 4 vlans. the 3com switch 4500 always give error message "there's not enough routing resources available".please help....
Oct 28, 2008 | 3Com 4500 24-Port Ethernet Switch
Automatically ping and trace disabled after PBR
please add me on yahoo messenger or mail me , let me know when ur online , my id is samrat101@yahoo.com and we will be able to resolve it sooner,,, mails takes time.
Samrat
Feb 20, 2008 | Computers & Internet
Route-map policy block the ICMP
honestly, I dont think anyone here will know how to handle this problem. Try to show this problem to a trained professional.
Feb 18, 2008 | Computers & Internet
ICMP blocked automatically
return, cut this configuration, but put route the her isp´s.
You can ping after this?
Can´t ping you has other problem.
Computers & Internet Logo
329 people viewed this question
Alun Cox
David Payne
David Payne
