Question about Hotpoint WMA58 Front Load Washer
How do i get into the machine to change the door to tub seal
The grey rubber seal was a little dirty so my wife decided to clean it. later on in the day whiles the machine was running water began to leak from underneath the washing machines approx the centre a few drips at a time. i guess my wife has damaged the seal somehow and any ways with it being drity it could do with replacing it just to not know how. thanx for any help Dan.F
  • 156 Answers
Dan some of the washer are easy to change some are not need model no
Posted on Feb 25, 2008
Mold and mildew and a musty odor. I can see black mold around the door seal, primarily at the lower side of the door seal. Can I attempt to clean by using bleach? What are your recommendations to correct...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((^^&&
Sep 05, 2010 | Maytag Neptune MAH5500B Front Load Washer
Whites are grey
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@**
May 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do I clean the front seal most efficiently? There is an odor and other junk that really needs cleaning.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^
Apr 27, 2010 | Frigidaire ATF6000ES Front Load Washer
Washer Odors of Mildew
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Constant mildew smell in my front load washing machine Have tried running bleach thru an entire cycle , also have cleaned door seal throughly
Dec 08, 2009 | Kenmore Washing Machines
Beko sma 510 washing machine clothes smell when cycle is finished
Oct 16, 2009 | Washing Machines
Musty odor removal; also "mold" black in color around rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$^*#
Sep 22, 2009 | Maytag Neptune MAH5500B Front Load Washer
I have a front end kenmore washer- it was spinning and then made a loud noise. Will spin a little but makes a load noise. Is this a belt or motor? I bought it in May of 03
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a “Clean Cycle” available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
Jun 23, 2009 | Kenmore 42822 Front Load Washer
Musty smell from rubber seal
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.&&&&
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
120 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
