HOW CAN I RESET MY NETWORK KEY PASSWORD ON MY BELKIN OR HOW CAN I FIND IT.
Steps to find a WEP key:
1. Open a browser (the program used to access the internet).
2. Type the following into the address bar of the browser. If using a Belkin router type "192.168.2.1". The address bar is the area where webpages are typed. It is important when typing in that there is NO www. before the numbers, but do put http://
3. If all has gone well this should open a page that says Belkin.
3. There may be the need to login. When using a Linksys if you don't know what the username and password are it may still be the factory settings, and so enter in "admin" for the username and "password" for the password. If using a Belkin router, the factory settings often come with no password, so just click submit without typing in a password.
4. Click on a) "Wireless" or b) "settings".
5. Click on a) "Wireless security" or b) "wireless settings".
6. There should be a page with a WEP key listed.
7. Write it down/copy and use as you wish!
We will give you full guidance how to install Netgear N300 wireless.
There are following steps
Step1: Unplug the power to turn off your modem
Step2: Connect one end of the yellow Ethernet cable to your modem and the other end to the internet port on your router.
Step3: Plugin, then turn on your modem
Wait approximately 2 minutes, if your modem has a battery backup, first remove and reinsert the battery before connecting your modem to power.
Step 4: Connect the power adapter to the router, then plug it into an outlet. Wait until the wireless LED turns solid green.
Step5: Connect the router to your computer
To know more information
Belkin Range Extender Won Connect to Wireless Router TechVaidya
SOURCE: network key for belkin router
are you referring to the Encryption key - the WEP key? You need to get that from the person who takes care of the router. If YOU are the person who administers the router, then you need to reset it to the default factory settings.
SOURCE: Forgot my security password (network key)I need to
Logon to your router from your computer using your browser and going to http://192.168.1.2/. If it wants a username, the default username is blank and the default password is either blank or "password".
The Belkin management tool will come up. From there, go into your security and look to see if your passphrase is visible. If it is, you're good to go. If not, you can change it on that page save it and close out.
Don't forget to change the passphrase on any wireless devices you are using connected to the Belkin wireless router.
Are you looking for reset your network key password? We are available for you. If any problem or fix issues related network
rourtlogin.net
routerlogin net
routerlogin
