Question about Emjoi Gently Gold Caress AP-9GAR Epilator
Emjoi gently gold caress
Tweezer head not rotating
  • Anonymous Apr 27, 2008
    The blades are not rotating; happened suddenly whilst in use.
Its not the actual emjoy that has the problem! Its the cord thats faulty. The cords are substandard and Emjoy relies on these becoming faulty to drive up re-sales! I have already been through two cords
Posted on Jun 15, 2008
Emjoi light caress epilator jammed
The major reason that epilator shavers stop working is because of hair that is caught inside the machine. If you have taken the top off and cleaned it out thoroughly using the brush, then this likely isn't the cause.
Is it still under warranty? if so, i suggest that you contact the manufacturer and ask where you can send it for fixing. if your warranty has run out, you can still ask the manufacturer for a list of approved repair shops.
Feb 26, 2013 | Emjoi Light Caress Gold Corded Epilator,...
Silk Epil 5376 Rotators are too slow and it doesn't work like it used to. When you take the head off the spinner spins fast but when you put the head back on it is slow and then the tweezing heads do...
You will need a star-shaped bit to remove the 2 screws. I would imagine they’re metric as it’s made in Germany. Barring that, a small flat head screwdriver used for eyeglasses will work. Remove the screws over a bucket or something so you don’t lose them, because they’re specific to the SilkEpil and can’t be bought at the hardware store.
When you remove the screws and take it apart, you’ll see the gears inside are clogged with hair. The flaw with the design is that the gear mechanism will suck in a few hairs every time you use it, which build up over time.
Remove the gear unit and use tweezers to pull out all the hair. You can rotate the gears to get it all. On the underside of the tweezer section, there’s a little recessed gear that’s probably clogged with hair too. Rotate the tweezer barrel to turn the little gear, and pull out the hair.
Give everything a good rinse, put it back together, and let it dry overnight. Presto, good as new!
I plan on doing this once a year as regular maintenance.
Aug 13, 2011 | Braun Silk-epil 3370 Epilator
How to clean a remington EP6010 epilator?
AFTER EACH USE
CLEANING THE EPILATION HEAD Ensure the epilator is turned off and disconnected from the mains. Press the head release button/s and open the head assembly. (Diagram G) Turn the head assembly upside down. Using your thumbs, push the small sides together and push the epilation head upwards. This releases the curved epilation head. Brush the accumulated hair from the tweezers by turning the barrel manually. NOTE: The body of the epilator is not washable. Do not submerge in water.
TO REMOVE RESIDUE To remove residue from the stainless steel tweezers, dampen a swab with alcohol. Gently run the swab over the tweezers until the residue has been removed.
Online Manual: http://uk.remington-europe.com/pdf/ep6010_user_manual.pdf
Feb 28, 2011 | Remington Health & Beauty
My Mom order this product and never used it. She
This interchangeable tweezers device (pat. pending) will do wonders for the way you feel about yourself. When you follow these simple instructions, Emjoi Beauty Forever will rid you of unwanted hair for the long haul! You can decide whether to use the coil-tweezers or the gold-plated tweezers based on these broad criteria:
The coil-tweezers enable you to clean out at a time a multiple number of unwanted hair (most notably, at the bikini line and some facial hair).
The gold-plated tweezers are intended to remove individual unwanted hair (like those on the eyebrow or on the breasts).
To use Emjoi Beauty Forever efficiently, please read carefully the enclosed Instruction Manual and pay a special attention to the following:
Clasp the unwanted hair with the Emjoi Beauty Forever's coil tweezers or gold-plated tweezers. At the same time, press the handle button for 15-20 seconds. The indicator light on the inside panel (near the adapter outlet) lights more brightly and will remain so during the application.
Slide the hair out gently in the direction it grows. If the hair doesn't slide out easily (some hair is more stubborn than other), gently tweeze it out. Even the coarsest hair is removed with a lasting effect by the Emjoi Beauty Forever's unique epilation treatment.
These helpful tips will assure extra-effective epilation!
The shorter the hair, the better the results. Preferably, hair should be no longer than 2-3 mm (1/10 in.)
Your skin should be completely clean before treatment.
To make skin more supple and relaxed, wash with warm water and gently massage.
Make sure no radios, TVs, or cordless phones are operating during treatment since they may interfere with RF transmission.
If a hair remains after 3-4 consecutive treatments, tweeze it. It has been sufficiently treated. There are some hair roots that need more treatments, particularly those that are dark and thick, or near throat, chin, lips, thighs and bikini lines.
Mar 08, 2010 | Emjoi Beauty Forever Epilator
Can you get replacement heads for emjoi body bare ultimate?
This is a test by FixYa Staff.
MODS - DO NOT REMOVE
Thank you!
Sep 20, 2009 | Emjoi AP98R Epilator
Ironman triathlon solar
HI Certype,
Welcome to the wonderful world of watches (my daily life and I love it).
OK I can assume you know how to take the back off of the watch?
Yes take the small black cover off the top of the battery (its actually a insulator) then with a pair of tweezers and a manifigying glass look for a the letter "AC" on the inside the watch in front of you.
When you see it you'll probably see a little gold point near it, press one end of the tweezer there gently and the other on the top of the battery and hold gently for 5-10 seconds.
Replace battery cover and you should have done the trick and back case screws etc.
Jun 02, 2009 | Casio Atomic Timekeeping WV58A 9AV Watch
Are there any replacement heads out there?
If you go to http://www.jr.com/emjoi/pe/EMJ_AY5S/
they have your razor and it's a rechargable one for only 34.99 plus 6.99 shipping but you might want to check out that sight
Apr 16, 2009 | Emjoi AP98R Epilator
Emjoi Head AP98R
i have the same problem, I have had this replaced once already. It has just happened again for a second time!! Contacted Sunbeam and they do not sell parts and will not touch as it is out of warrantee!! Sorry
Dec 14, 2008 | Emjoi AP98R Epilator
Emjoi Gently Gold Caress AP-9GAR Epilator Logo
278 people viewed this question
Top Emjoi Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Marvin
Marvin
Are you an Emjoi Health and Beauty Expert? Answer questions, earn points and help others
