Question about Nokia 3110 Cellular Phone
USB or viruses
Actually, i just want to try if there is a way that i could protect my usb from viruses when i insert it to computers. i am still in college and i have a computer class. i badly need to connect my usb to those computers filled with viruses.
Posted on Mar 03, 2008
My USB is write protect
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
hope this helps you
Jul 13, 2011 | Kingston Digital DataTraveler 4000 8 GB...
I have a transcend pendrive wen i insert it it shows drive has to be format but wen i m tryng to format its not formattingl08305
It is possible that the memory was damaged or is infected with a strong virus malware that does a block on detection to the PC. try the same on another PC which has a good protection and if this works there are faults on your port or the PC is infected.
If the drive is still not detected then the memory is faulty even after you try to format on any PC.
Jun 14, 2011 | Transcend (589307) Media
I CAN NOT COPY OR DELETE THE FILES OF MY USB
Your USB flash drive is either infected with a Virus or your Drive is Write Protected.
Scan your flash drive for Mal-ware and Viruses using an Up to date scanner.
Be sure to check that the drive is not on Write Protect mode.
However under Write Protect mode you should be able to copy file from your USB flash drive.
Also try the drive in another computer just to be sure it's not the drive that faulty.
damnor01 out!
Apr 06, 2011 | Computers & Internet
Cant format my son
VIRUS OR TROJAN INFECTIONS:
Virus or trojans can run some process that keeps running in background. This not only harms the computer, but also prevents the pen drive from formatting as it shows that the drive is in use. Remove and re-insert thepen drive, don't double click on drive and cancel autorun operations if it starts automatically. Run a virus scan on pen drive, this will help fix the issue. Now format the pen drive.
Always take precautions while using pen drives on other computers. See the some of our posts below on protecting your pen drive from viruses:
CORRUPTED FLASH CHIPS ON PEN DRIVE:
If the pen drive is not detected at all, or shows a less capacity, then there are high chances that its a chip corruption. Flash chips are the actual hardware components that save the data. A physical or electrical or electromagnetic damage to these chips make the pen drive faulty. This can happen because of voltage fluctuations and faulty USB ports. In such case, get the flash drive replaced if its under warranty as it can not be fixed otherwise.
FAKE PEN DRIVES:
Sounds a bit un-believable but true. There are a lot of pen drives in the market which are of very cheap quality which are fake copies of some known brands. Beware of such pen-drives. Always purchase pen-drives or memory-cards from a reliable source with bill and warranty to avoid any mess later.
Dec 28, 2010 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
I want to format my USB data traveler but it is always shows a write protected error......how can i remove the write protection error?
there many me malicious Trojan or a virus so just scam you pen drive and your entire PC to fins the virus and the Trojans and then try to format if this don't work
Right Click on My computer
> Manage
> Disk Management
> Select the Drive and
> Right Click on your Device
> And Click Format
then you can format your drive
if not use this link and download software where you can format your drive safely http://www.kingston.com/india/tools/assessor/default.asp
Aug 19, 2010 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
HOW TO FORMAT A WRITE PROTECT USB DRIVE?
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
write-protection-registry
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
disable-write-protection
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
Aug 15, 2010 | Kingston Technologies 512MB DataTraveler I...
How to remove write-protection
Dear Friend,
  • There is a write-protection tab on the mini sd card HOLDER. Every time you insert this into your PC or card holder, this tab slides to the write protect position. Either keep resetting, inserting & reinserting until it doesn't slide or tape it down.
  • There is nothing wrong with the mini sd card. Simply locate the write protection key and push it.
  • The mini sd card has some error: Go for a low level formatting.
  • The card has virus: Remove the virus.
  • Change the Usb Port(Recommend you to Use Backside Port)
  • Change the Cable
  • Restart PC
  • Still have Problem Change Card Reader..
Hope this Helped you..Thanks for Contacting FixYa...........
May 14, 2010 | PNY 2GB microSD Memory Card
I try to answer this even it is late.
If this doesn'thave any movable switch. Actually very small switch on part of it. You got virus in it. Usually it is hidden, and usually name AUTORUN.INF. run scan to your usb drive.
Jan 10, 2009 | Electronics - Others
Computers restarts on inserting usb pendrive problem
The reason is simple,once some virus has infected the pen drive and has created autorun entries, it can run any-kind of task through auto-play feature.
So to fix it, we first of all need to Disable Autoplay on all removable drives. see the following link http://www.troublefixers.com/how-to-protect-your-computer-from-virus-in-pen-drives/
After this, Insert the pen drive, do not open the drive or double click on it, simply insert it. Now its time for some cleaning by removing Virus created autorun entries, see this following link for removing autorun entries.
http://www.troublefixers.com/scan-and-remove-suspicious-autoruninf-with-autorun-eater-virus-removal-tools/
That is it, its done. But if you still face problem with the drive, format the pen drive. We hope you find it useful.
Please vote if it is helpful
Dec 31, 2008 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Nokia 3110 Cellular Phone Logo
23 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
