Question about Yamaha RX-V800 Receiver
Yamaha RX-V 800
I have a yamaha RX-V800 and it cant turn on,I sent it to the dealers and they told me that they cant fix it because the parts are discontinued,i really need to fix it,I just need a schematic diagram,Please help me.
  • kiwical Mar 23, 2009
    3 years old, just out of warranty, relay clicks when turned on, no display, no sound. Have tried unhooking all wires to be sure its not a speaker short, so just the unit by itself, same problem.
  • Rob Galayda May 11, 2010
    You can get schematics from Yamaha.....last I checked they were $10 canadian each.....define "cant turn on"....is it stone dead?....does it turn on and turn off right away?.....be descriptive !!!........Good luck....Rob
    PS....I have repaired MANY yamaha's, usually it is a blown channel and it is Definitely NOT for the novice Do-it-yourselfer. The '800 is a very nice unit.......R
    Novelist:
    Champion:
  • 236 Answers
Go to yamaha service direct they should have the parts. impossible for this model to be phased out. this is a model about 6 years ago only. they still have the parts for that. Power output and driver transistors are industry standard, replaceable too byt other newer model. you just need to find a real good techie for yamaha... i mean yamaha expert
Posted on Mar 19, 2008
Give me more details of trouble... let me give you advise if it can be done. 800 does not have industry standard parts mostly by yamaha only or made to order by yamaha. I have the same unit before, i have the manual too.
i use to work with yamaha service saudi arabia 6 years
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
I am looking for a replacement remote.
Description: REMOTE CONTROL TRANSMITTER FOR RAV222 RXV800/1000/HTR5280 Only Numbers are allowed Model#: HTR5280-exploded view Availability: Pre-Order Price: $82.68 (USD) Part#: V6283501
The remote for the RX-V800 is the same as for the HTR5280.
Please contact the manufacturer for ordering, or contact one of their distributors, whose info is listed below.
Hope this helps!
Page link:
https://www.yamaha24x7.com/yamahaoms/ViewSchematic.aspx?ModelNumber=359096&SearchString=HTR5280
Distributor Ordering Information: HERMAN ELECTRONICS
7350 NW 35th Terrace
Miami, FL 33122
Phone: (800) 938-4376
Fax: (305) 477-8087
URL: http://www.hermanelectronics.com/OEMSearch.asp?Manufacturer=yamaha
VANCE BALDWIN ELECTRONICS
7060 State Road 84, Building 12
Fort Lauderdale, Fl 33317
Phone: (800) 432-8542
Fax: (800) 552-1431
URL: www.vancebaldwin.com
Jan 05, 2010 | Yamaha RX-V800 Receiver
Rx-v800, have a problem when i swtich the input mode, it will turn off. after leave it for few months, now no problem but not sound.
Test an audio source like "DVD" connected to the "Direct" input with left,center,right,rear,andsub input. put the receiver in "Direct mode" if you get audio, the main DSP chip is bad, get an estimate first since it can only be verified by bench testing the unit. It's not a cheap repair 400-500 range. Most new Yamaha receiver's in the modest range run 500-800- new. Hope this helps
Nov 08, 2009 | Yamaha RX-V800 Receiver
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
Need yamaha codes to program into uverse tv ir remote
(I have the RX-V659). Because the Yamaha remote has TWO SEPARATE buttons - power ON and power OFF (standby). This problem can't be fixed. There's a code to choose power ON and another code for power OFF. But one button can't be two buttons. Bad engineering\ design by Yamaha in my opinion
Jan 09, 2009 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Remote Control
email me .... redrivera0314@yahoo.com... ill send
you a copy of the codebook page... but let me try and locate it first, i have the same unit before. Yamaha code books are the same also to other models.
Reden
Mar 17, 2008 | Yamaha RX-V800 Receiver
Yamaha rx-v800 remote control's damaged
it can be accessed via the main unit controls but you need to go through your manuals. Maybe you can get your remote repaired still... maybe not badly damaged caused by corrosion.
Feb 04, 2008 | Yamaha RX-V800 Receiver
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
Rx-v800 shuts off after few seconds
Hi, You should try to see, on main board, the ground G2(TP00385), just to make sure if the screw is too tight. Its location on Schematic Diagram (Main) is E8. All the best, Rasgador
Oct 27, 2006 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Receiver Logo
941 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
