Why the word ton used for airconditioner.
I wanted to know that why the word ton is used in measuring the capacity of the airconditioner, why the word ton is only used for aircontioner not for any other appliance
how the word ton was decided to be used while the word aircondition or the product was invented.
what is the formula of calculating the tonage, what is EER, BTU.
  • Anonymous Mar 30, 2014
    need to fine out the tons on the aircondition
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 146 Answers
Hi there..
this what i found for you...
The unit ton is used in refrigeration and air conditioning to measure heat absorption. Prior to the introduction of mechanical refrigeration, cooling was accomplished by delivering ice. Installing one ton of refrigeration replaced the daily delivery of one ton of ice.
  • In the United States, a standard ton of refrigeration = 12,000 BTU/h = 200 BTU/min ≈ 3,517 W. It is approximately the power required to cool 1 short ton of water by 1 °F every 10 minutes; or the power required to melt one short ton (2,000 lb) of ice at 0 °C in 24 hours.
  • A ton is also a unit of energy equal to that power for a period of a day, or 24 h × 12,000 BTU/h = 288,000 BTU ≈ 303.9 megajoules.
  • A less common usage is the power required to cool 1 long ton of water by 1 °F every 10 minutes = 13,440 BTU/h ≈ 3,939 W.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 24, 2008
Mitsubish AC Model FDC 51 BA Q.1: what is capacity of this AC in tons? q.2: what is running current in amps?
Here is a YouTube video that helps you calculate tonnage of an AC.
The only way to know the running current if it's not on the AC info plate with all the other info is to measure it.
Calculating tonnage of your air conditioner
Oct 12, 2017 | Heating & Cooling
Q.1 : Mitsubishi AC model FDC-51BA how much capacity this AC has in tons Q.2 : What is running current in amps
Oct 12, 2017 | Mitsubishi Heating & Cooling
Dump truck sizes
A dual axle dump truck (ten wheels) is normally rated at 10 cubic yards (270 cubic feet) load capacity.
A single axle dump truck (six wheels) is normally rated at 5 cubic yards (135 cubic feet) load capacity.
These are volume measures not weight measures.
Oct 09, 2017 | Cars & Trucks
What is the rule of thumb for computing the capacity of horsepower of air conditioner in terms of area, e.g. square meters
Horsepower does not necessarily matter. Horsepower is not computed to capacity. Amounts of btu/ heat removal, is measured capacity. 12,000btus which equals 1 ton of cooling will cool a maximum of 500 sqft depending on the heat load. Obviously a brand new home with updated insulation vs a closed in lanai with a wall of windows...you get the idea
Jul 22, 2017 | Heating & Cooling
What is the cubic ft capacity of this old model
If you no longer have the manual that came with it, you can always measure the dimensions internally and do the math to calculate the cu ft capacity. Do do this multiply all the measurements together. Then write that down. Take and multiple 12*12*12 and write that number down. Take first number and devide second by it. That should tell you the cu ft capacity of your oven or whatever you want to determine.
Nov 26, 2014 | Kitchen Ranges
DO NOT HAVE BTU LISTED ON AIRCONDITIONER FOR SERIES LP 109755 319Y SERVICE# M6X08F2A-B
Hi, I am not sure what you are wanting to know? If you want to know the size of the a/c tonnage wise, its 5,000 b t u's short of being a 1 ton unit. There is 12,000 b t u's of cooling per each ton. 2 tons would be 24,000 b t u's, 30, a 2 1/2 ton unit and so on. If this is not what you needed to know, please get back to me and let me know. Sincerely,
Shastalaker7
Jul 03, 2010 | Maytag Chassis Built-In Air Conditioner...
What is the cargo capacity of my toyota Truck
They are basically a 1/4 ton truck. So you can safely haul 1/4 ton. Or 500 pounds.
Jun 21, 2010 | 1993 Toyota Pickup
One horsepower is how many ton? I want to know how many tons of refrigerant is equivalent to one horsepower capacity of a cooling system.
1 to 1...
1 hp. equals 1 ton or 12,000 BTU's....at least in round numbers...
this can vary just a bit depending on the combination of condensers and evaporators...
heatman101
May 25, 2010 | Carrier 30HXC096 Indoor Water-Cooled Screw...
NewAir AirConditioner on "Dehumidifier" Mode Only
I have a 3 ton a/c system that removes about 5-6 gallons of water from the air per day. Most portable dehumidifiers/air-conditioners rate at approx 1/2 to 3/4 of a ton. Your water output is pretty much normal.
Jun 23, 2008 | NewAir Heating & Cooling
Heating & Cooling Logo
264 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
