Question about SanDisk Sansa e260 MP3 Player
Delete Songs from e260 sandisk
I couldn't able find a single mp3 file in my device, but I have around 2GB of songs in my device. how to delete them ( few or all). what is the editor I have to use?
  • chennoju Feb 24, 2008
    I didnt get any option like this, I find two modes in the device, 1. Raphsody and 2.playfor sure. If I select the first option, I could able to see the FM,Voice Rec, images but If I select the section option (playfor sure) I can't able to see anything in my computer.
    I just want to delete some of my songs from the device. Please let me know the correct approach to achieve this.
  • irvinc Apr 18, 2009
    i just want to be able to delete some songs from the device
  • 20 Answers
You don't have to use an editor to delete songs on your mp3. when you put the mp3 cable on your computer just go to "open folders to view files" den go to my music and you can now add or delete songs.
Posted on Feb 24, 2008
Im trying to delete songs on my sandisk model e260 mp3 player so i can put new songs on it. do i need some type of software to do this? the mp3 player was a gift and i dont have software or directions or...
Not a problem vonbeen...if you have the player and the computer then your good to go.
Just follow these instructions.
Deleting Files,Pictures,Videos,Audio Books, etc. from MP3 Player
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
BE CAREFUL AND DO NOT DELETE FILES NEEDED TO OPERATE YOUR MP3 PLAYER.
Please rate me
Jan 15, 2011 | SanDisk Sansa e260 MP3 Player
How do you delete songs from e260 mp3 player?
Please rate me
Jan 06, 2011 | SanDisk Sansa e200 MP3 Player
Hello, the problem that I have with my SanDisk 2 GB MP3 player is that now, whenever I try to put songs on it, I get a message that "the device has stopped responding" or "the device does...
Try and reset the player first, If this does not fix the problem, Click this link to down load the Sandisk updater program to run a firmware update...Updater... Resetting the device: 1. Press and hold the Power/Menu button for approximately 20 seconds. 2. Release the Power/Menu button. 3. Press the Power/Menu button again to turn on the player.
Next time you need to delete files heres how. --
There are two ways to delete files on your Sansa player. You can delete them from the player directly or using a PC.
METHOD 1 - Delete files directly on the device 1. In playback mode, press the Submenu button. 2. Select Delete.
METHOD 2 - Delete files using a PC For all other Sansa players: 1. Connect your device to the PC. 2. Select Open device to view files using Windows Explorer on initial connection. 3. Locate the folder where your files are stored. 4. Click to select the files you want deleted and delete the files.
NOTE: If songs still exist after deleting, you may need to switch USB modes from MTP to MSC or vice versa. See this tip HERE
Capacity issue This error occurs when a Sansa player is almost filled to capacity. A Sansa player can NOT be filled to full capacity. (i.e. you can't put 2GB worth of songs into a 2GB player)
The player needs the extra capacity to create and maintain a "database", a database holds all the information such as playlists, recordings, song information, etc. The larger the amount of songs, the larger the database gets.
To resolve this capacity issue, you have to delete contents on your Sansa player using a PC.
STEP 1 - Delete files on your player 1. See first note on how to delete files on your Sansa player using a PC.
FAT corruption This error also occurs when there's a file system corruption in your Sansa player.
To resolve this issue, run error-checking to fix errors in your device using a PC
STEP 1 - Connect the Sansa player to the PC in MSC mode
STEP 2 - Run Error-checking to check and fix errors 1. Double-click on My Computer (Computer for Windows Vista). 2. Right-click on the drive letter associated with your Sansa player and select Properties. 3. Click the Tools tab and select Check Now. 4. Click both check boxes under Check disk options. 5. Click Start
If an error occurs while plugging in the player to the PC and some files are missing in the player, the database might be corrupted. To resolve this, you will need to format your player.
NOTE: Formatting will delete all files in the device. Your data (music, photos etc) is NOT recoverable.
Nov 16, 2010 | SanDisk Sansa e260 MP3 Player
How do I delete music off my e260
Books, etc. from MP3 Player/Ipod
Hold the left click down and drag it across all the files/songs that you
do not want this will highlight the files/songs you do not want, release,
Now you mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck, I hope this helps
Please rate me, Thank You
May 11, 2010 | SanDisk Sansa e260 MP3 Player
Cannot erase songs from sandisk sansa e260 (4GB) mp3 player
Try this method of Deleting Files,Pictures,Videos,Audio
Good Luck,
I hope this helps
Please rate me,
Thank You
Mar 25, 2010 | SanDisk Sansa e260 MP3 Player
Delete songs from mp3
1) Go to Settings/USB Mode and change to MSC mode which make it works as a flash drive/memory stick 2) In Windows explorer, you should see two drives in My Computer, one for the unit, one for the card slo 3) As for a 'normal' PC, you can now just delete any files/songs from your Sansa directories in either drives! (you can also move existing or add new files). note: if your normally use SanDisk Media Converter program or Windows Media Player, you must change the USB mode setting on your Sansa back to 'MTP' before those programs can see your device.
Dec 20, 2009 | SanDisk Sansa e260 MP3 Player
My Sandisk Sansa e260 wont let me delete songs
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
Mar 18, 2009 | SanDisk Sansa e260 MP3 Player
My player deleted songs
Several options:
1) You can delete the songs from the computer itself using Windows Explorer. Be careful to only delete music files, not system files.
2) Use the format option on the player itself - will erase everything.
3) Delete the songs using Windows Media Player
After selecting one of the 3 options, you can then reload only the songs that you want onto the player.
-Tha Mp3 Doctor
Jan 07, 2009 | SanDisk Sansa e260 MP3 Player
Deleting songs
I have the e260 4g. To delete songs I use the MSC mode, so I can see the player as a regular windows folder and then select the songs that I want to delete
Just follow the steps as indicated in
How to delete music files from your sansa mp3 player
Dec 08, 2007 | SanDisk Sansa e260 MP3 Player
Double Songs?
you go to computer than go to sansa e260, than you will see music after that you delete the songs that are doubled.
Dec 05, 2007 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e260 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
