Question about Refrigerators
I have an RL33SBSW fridge freezer, for the last week the lights on the control panal have been flashing & the fridge has been freezing all the food. I was told it needed a PCB which I purchased and fitted, the lights have stopped flashing and the fridge has stopped freezing but now it isn't getting cold in the fridge. The outside of the fridge freezer used to get warm too and that is also not happening now. The appliance is only 13 months old, please help.
  • 1 more comment
  • shj1 Feb 26, 2008
    I have the same Samsung RL33SBSW fridge-freezer. It is only a few months old. The lights on the control panel started flashing about a month or so after purchaing it. I have turned the power on and off on a couple of occasions. This has stopped the lights for a brief period, before they start flashing again.
    I presume I should call the Samsung engineers to fix this problem, given that it's still under warranty?
    Thanks,
    Sanjay
  • Semtro Sep 04, 2008
    I have the same problem. The lights are not the issue - But has started to freeze for the fast week or so. No frost at the back of the fridge yet BUT - YES the fan seems to running every time you close the fridge or Press the light button by hand..
    Help any one.. ?
    the changing the PCB sounds complicated.
  • chris aube May 11, 2010
    do you have any air coming through the vent in the refrig ? is the fan in the freezer running? do you have frost accumulated on the back wall of the freezer?
  • 21 Answers
Good day..
I would Double-check the part.. before I did anything else.
I would recheck my model no. just to make sure I was right.... I would want to find out if the part I was sent is the one it is supposed to be... it probably is.... It may seem silly, but it happens more often than it should.
When a Refrigerator doesn't defrost like it should, a common condition would be to hear that some foods in the frig side freezing, why, is because the control which cycles both freezer and frig, is located in the Fresh food side, there is not enough air movement to cycle the thermostat, so it runs all the time. Cold air drops, and usually the freezing occurs down below in the veg. drawers and/or vent ports involving air transfer between the two compartments... as more time passes... ice on evaporator thickens, air flow circulation reduces even more, now conditions begin to reverse.. and exactly what you state above begins to occur... look inside your Freezer, the back wall... you'll see ice (like a snow-cone) forming.. if so... you could have a defective PCB, I doubt it.. 95% probability, it's the bi-metal termination thermostat.. the other 5% would be your def heater. I have found more PCB prone to be at fault under these circumstances then that the thermostat.. I wouldn't toss out that PCB... If you keep this unit for a long time, it will be the likely thing to be needed, in the next round..
Posted on Feb 25, 2008
FRIGIDAIRE SIDE BY SIDE FRIDGE SIDE TOO WARM
adjust the temp on the freezer setting where it links up with the frig'...
Feb 03, 2013 | Refrigerators
My fridge side is not cooling,but my freezer is freezing
seems like you have a defrost issue, with this unit, its more than likely the adaptive defrost control found in the upper right hand corner of the fridge. You have to take down the lights and control....
You can find your part on any of the Parts websites for around 75.00..
IMPERITIVE unplug the fridge before replacing the board..
Aug 01, 2012 | Maytag MSD2756G Side by Side Refrigerator
The fridge & freezer has started to get warm it was 8deg above the recomended temperature & then the light starts to flash,we have cleaned all around it,taken food away from the outlets in the...
it can be a defective thermistor,a defective cold control or compressors short cycling(not running long enough) or the evaporatorin the freezer is frozen up and cant keep temps constant
Aug 03, 2011 | Refrigerators
Control panal is not working.
Hold Energy Saving & Lighting buttons simultaneously for 10 seconds! Panel dispaly resets.
Mar 31, 2010 | Samsung RF265AA Bottom Freezer French Door...
Fridge not staying cool, freezer still freezing
The defrost thermostat on the defrost heater is probably bad, it's a good place too start.
Mar 18, 2009 | Maytag MBB1956GES Bottom Freezer...
Servis frostfree fridge freezer
Hi, I had that last year - It was the control board!
Oct 24, 2008 | Freezers
Samsung Fridge Freezer
Possible bad defrost timer.
Mar 08, 2008 | Refrigerators
Refrigerators Logo
505 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
