Question about Motorola Mobility HS850 Consumer Headset
MICROPHONE I am having problems with the microphone on this item i can hear the other person, but theycannot hear me, also i cannot use the voice commands on my phone. can anyone help please mike
  • Anonymous Mar 13, 2008
    I have successfully paired my HS850 with a new blackberry pearl. I cannot initiate voice calling. When I use the phone itself to dial rather than the HS850, I can hear the other person, but they cannot hear me.
  • mikeinnj Apr 26, 2008
    Me too. I'm thinking it's a hardware problem. This unit is about 3 years old.
Yep .. same problem here
Posted on May 08, 2008
Skype-microphone is faulty-others cannot hear me
The microphone may not be configured properly in Skype.
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
Mar 12, 2012 | Acer Aspire 5738Z-423G32Mn Notebook
Tip
SKYPE MICROPHONE PROBLEM If the person cannot hear you then, either your...
If the person cannot hear you then, either your microphone driver was not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
on Oct 23, 2010 | Computers & Internet
In my laptop hp compaq cq45 with os windows xp microphone is not working plz solve my problem...
Mar 04, 2012 | Computers & Internet
On skype i can hear my friend but she can not hear me
Feb 12, 2012 | ASUS Computers & Internet
Cannot hear my voice in microphone
These instructions are for Skype 4.2 for Windows or below. Before continuing, we strongly recommend that you upgrade to the latest version. For Skype 5.0 and above, refer to these instructions. If you're not sure which version of Skype you're using, it's easy to find out.
If the person you are talking to in a Skype-to-Skype call cannot hear you there are a number of steps you can take in order to help you set up your system correctly so that others can hear you.
Try calling Echo123. If you can hear your own recorded voice then your playback device (headphones, speakers, etc) and microphone are set up correctly and the problem might stem from low internet bandwidth, or that the person you are calling has not set up their sound devices properly.
If you cannot hear your own voice in Echo123 check that your microphone is on.
Test Echo123 again to see if the microphone now works..
THANKS.
If none of these steps work you might need to adjust your computers sound setup. Have a look at our Sounds Setup Guide.
Also check out our Troubleshooter for more help with common sound setup issues.
Apr 28, 2011 | Skype IM
My audio is not working well i can hear the voice on the other line but the person I'm talking to cant hear me.......need an advice how to solve this problem....thank you in advance.
What are you using? If you are using skype, you need to check your microphone connection in their program. otherwise, follow these steps.
  1. Go to "Start" open "control panel."
  2. Go to "sound"
  3. In the tabs, select "Recording"
  4. You should see one or two items for microphones, snap your fingers in front of the microphone you are trying to use.
  5. One of the microphones should display a green bar in its volume monitor (to the right side of the window.)
  6. Select the microphone that showed green and set it as default.
This should help.
Best of luck!
Feb 28, 2011 | Computers & Internet
I got sound system problem in chatting
go to control panel and click on sound icon. there you will see speaker and microphone properties check on microphone voice level. if it is very low or mute other party cant listen to ur voice so increase it a bit little. this can solve ur problem
Apr 13, 2010 | Sony VAIO VGN-CR220E/P Notebook
Problem with microphone of presario c 700
hi no need of any drivers.. see to that both the ouput pins from ur head set microphone is connected to ur system audio port.. if only one pin is connected the other person cant hear ur voice.. try connecting both the pins..
thank u rate me!!
Feb 07, 2009 | Compaq Presario 700 470024-192 Notebook
Hello, when using my built in microphone on my laptop compac#6120 to talk with another person , I can hear the other person clearly but they cannot hear my voice, they can hear everything else background...
If they can hear your breathing that means that you are not speaking in to the microphone, do a microphone test on the computer and see if you hear your own voice. If you don't the program that your using is set to use wrong sound input and the settings will have to be changed.
What program do you use to speak with others?
Feb 02, 2009 | HP Compaq nc6120 Notebook
Microphone setup
are you sure that you microphone is working properly?
if yes then there must maybe some problems with your microphone port in your pc..
but try this though :
in the volume control menu ensure that the microphone is not set to mute
what else u can try is u can try the mic with the other port and still if it doesnt work,the other person is still not able to hear then try and do the voice chat with some one else and if the other person on the different chat will be able to hear u then definately the prob is with the other person's computer it is not with ur computer.
Jan 21, 2009 | HP G60-120US Laptop
Motorola Mobility HS850 Consumer Headset Logo
70 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Lawrence Oravetz
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
