Question about Calvin Klein Watches
How do i take the back off my k22221 watch to replace battery
K22221 Watch
  • 7 Answers
SOURCE: resetting watch after battery replacement.
http://www.timex.ca/en/instructions/085Instr.pdf
Posted on Feb 06, 2008
  • 29 Answers
SOURCE: Opening back of watch for battery replacement
Turn the watch sideways & look around the edges of the back of the watch. You may have to use a magnifier to do this. Look for an area that has a gap. Put the knife there & pry it open. Hope this helps.
Posted on Mar 01, 2008
SOURCE: technomarine watch battery replacement
If you plan on doing this yourself, find a nice heavy pair of needle nose pliers and put the ends in the knotches on the casing back. Have them as far apart from each other as you can and turn counter-clockwise. If you still have problems opening, put the watch in a vise with the lugs in the teeth of the vise. DO NOT tighten too hard or you will snap the lugs. It dosn't have to be tight , just enough to hold the watch while you turn the back. If you still have problems please let me know and we will find another way of doing this.Good luck!!
Posted on Sep 29, 2008
SOURCE: to replace battery of pocket watch
My son has a Timex pocket watch-I just got the back off with a very tiny flat-head screwdriver- the niche or indent you're looking for is almost indiscernible; look very closely, the edge of the back barely deviates from where it meets the edge of the front piece. Looks more like a flaw than an intentional point of entry
Posted on Nov 20, 2008
SOURCE: how to replace battery in polar f4 watch
HOW TO REPLACE BATTERY IN MY POLAR TARGET WITH A TS1 TRANSMITTER
Posted on Nov 28, 2009
Removing back of irish collection ladies watch for new battery
Replace Your Watch Battery Yourself With Household Tools ...
? 7:32
https://www.youtube.com/watch?v=L4Y7pDonkmk
Aug 15, 2013 - Uploaded by tsbrownie
How to replace a watch battery yourself using common household "tools". Covers both snap back and screw ...Missing: irish
How to Change a Watch Battery with Normal Tools - YouTube
? 9:18
https://www.youtube.com/watch?v=gFmV7NIjVsw
Sep 1, 2011 - Uploaded by RichsMethods
I also show how to polish the metal portions of your watch. ... of how not to take the back off and remove ...Missing: irish
Dec 21, 2015 | DG Watches
Change the battery
You need to remove the back of the watch to get to the battery. If the watch is a water proof watch then the back is screwed on. After removing the back take care not to damage the gasket.
If you cannot remove the back of the watch then take it to a watch repairer, they can replace the battery and it won't be expensive.
Mar 09, 2013 | Watches
I have a pocket watch i bought in paris but the battery ranout and i cant get the back off to get the battery out. what should i do?
Hi Josh, I do apologize for the inconvenience.Please try the below steps which should be helpful for you to remove the back of the watch and also replace the battery.
  1. Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
    (OR)
    Find the small groove on the back of the watch right above the hinge,place the tip of the screwdriver (the small kind used for the screws in glasses) into the groove and gently pry off the back of the watch.
  2. Remove the circular watch battery out of the back of the watch.
  3. Take the battery to any department store or watch store and purchase a new replacement battery.
  4. Insert the new battery into the back of the watch.
  5. Screw on or push on the back of the watch. Set the watch to the correct time.
The above should be of help for you to have the battery on the pocket watch replaced and have the watch working once again.Best wishes for your effort and thank you for your time and patience.
Nov 12, 2010 | Fossil VT2654 Pocketwatch
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    I have a Majestron quartz pocket watch. How do I replace the battery?
  • Flip over your pocket watch. Remove the back of your watch. The back of watches are either screwed on by four small Phillips head screws (unscrew them) or the watch has a press inserted back (slide a thin knife blade under the edge of the back of the watch and pry it off).
  • Remove the circular watch battery out of the back of the watch.
  • Take the battery to any department store or watch store and purchase a new replacement battery.
  • Insert the new battery into the back of the watch.
  • Screw on or push on the back of the watch. Set the watch to the correct time.
  • Aug 23, 2010 | Watches
    How to open the back of Kenneth Cole KC3434 watch to change the battery?
    BASIC WATCH BATTERY CHANGE
    Get a replacement battery for your watch. Some watches have the battery information stamped on the back plate. If yours doesn't, you'll have to wait until you've removed the old battery to see what kind of replacement watch battery you'll need.
    Lay your watch face down on a non-scratching, non-skid surface. It may help to clamp the watch to the surface.
    Remove the back from the watch. You might be able to pry it off with your fingernail, but you'll probably need a stiff, thin tool like a knife or screwdriver. You can also buy watch repair kits, which have the perfect tools for the job. Check the watch back for a small notch to insert your tool, but not all watches have these.
    Remove the battery from the watch once the back is off. You might need to tip the watch over to let the battery fall out.
    Insert the new watch battery into the proper space, first double-checking its size against the old battery to make sure it will fit. Press lightly into place.
    Replace the back on your watch. Make sure you press firmly to get the back seated snugly.
    If this doesnt work, then take to a local jeweler/watchmaker who is equipped with the right tools to assist you.
    Best regards.
    Aug 17, 2010 | Kenneth Cole KC3434 Wrist Watch
    I want to change out batteries
    1. Lay the watch upside down on top of a towel or cloth on a flat workspace. Use a small flat head screwdriver or blade to pry under the watch backing, then lift the backing from the watch. Slide the battery cover to the side to access and remove the battery.
    2.Take the battery to any electronics store to purchase a replacement. Bringing the old battery will ensure you install the correct type of battery in your Fossil watch.
    3. Replace the battery and the battery cover. Apply pressure to the backing until it "pops" back into the watch.
    THANK YOU FOR VISITING FIXYA
    Aug 05, 2010 | Fossil Dress - Analog Glitz Red Dial Watch
    Battery replacement
    do you mean you want to replace the battery for your watch?
    This isn't a difficult task to carry out. Simply get a small flat screw driver, use the screw driver to open the back cover of the watch, then you will see the battery of your watch. Remove the battery and replace with a new batter, cover back the watch and that's all.
    Note that you will apply force with the screw driver when you are trying to open the back cover of the watch.
    Good luck.
    May 18, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
    How do I replace a battery on a kenneth cole watch and square fossil watch
    Open watch case back, then release the metal contact covering the battery. Memorize battery's polarity (+ up and - down), then take the battery out. Memorize the combination of letters and numbers on battery (should be something like: CR 3216 or similar). Make does not matter - Seiko is as good as Maxell, Panasonic2_bing.gif and other reputable makes. Buy new battery with identical combination of letters and numbers and put in your watch. Replace back contact, gasket and case back. Set your watch and enjoy. Rate me, please.
    Feb 28, 2010 | Kenneth Cole KC4232 Wrist Watch
    Watches Logo
    300 people viewed this question
    Top Calvin Klein Watches Experts
    Joseph Hoffmann
    aravind shet
    aravind shet
    Are you a Calvin Klein Watch Expert? Answer questions, earn points and help others
