Question about Vacuums
Overheating indicator comes on straight away
Miele HEPA TT 2000.
The overheating indicator comes on as soon as it is switched on.It did have an intermittent problem with the motor cutting out when the cable was pulled a certain way,
but does not now work at all.
Any suggestions?
Many thanks
Ray
  • 27 Answers
You could have a bad heat relay.
Posted on Feb 26, 2008
Blows hepa filter from mounting
I have seen generic filters do this. Be sure to use original Miele filters. The generics are a few dollars cheaper to buy but you end up with an inferior quality filter that could cause other problems by continued use. same is true with bags.
A clogged filter may also do this. Miele vacuums are very tightly sealed, the exhaust air has to come out. If the filter is clogged, the pressure could pop the filter out, HEPA filters are suggested to change out about every 50 hours, for most people this is between 1 - 1.5 years.
We had a Miele come in for service the other day with the same complaint, installed filter was a generic, customer said it was a new filter just installed. We replaced with an original filter and problem ceased.
If you need any help feel free to contact me.
Tim
TheVacCenter.com
Mar 16, 2013 | Miele CatAndDog700 Bagged Canister Vacuum
Where do you put the prefilter on a miele canaster vaccuum
Hi If the power head isn't working it may be clogged. Try taking it apart to see if threads and general dirt has got in at the sides. Also without the power head if the Miele still isn't working then its a possibility that the on switch wiring is either loose or check the plug at the end of the power cord.
Sep 11, 2012 | Miele S514 Solaris Electro Plus Vacuum
Kenmore progressive vacuum not starting
1) test the power cord for open wires or break
2) test the switch for open or defective
3) test the motor for winding burn or overheating or bearing worn
God bless you
Jun 19, 2012 | Kenmore Vacuums
I have a miele S712 (2 yrs old worked fine yesterday) - I had been doing some diy work inside and had the vac on just to reduce some of the dust in the air - after a while the vacuum fizzled out. I...
you have got dust in the micro switch and it is not latching on, if you look at this and clean it, that will solve your problem, however blowing the motir has probably wrecked the motor bearings.
Jun 02, 2011 | Miele Vacuums
Miele vacuum cleaner keeps overheating and shutting off. It is only possible to use for about fifteen minutes at a time
Hi Lauren, how do you know if it is the circuit board? (the speed control buttons still work).
Mar 13, 2011 | Miele Vacuums
Using my miele 4211 without a bag
You did what??? That really is asking for trouble! If it cut out from overheating then yes, it will come back to life when it has cooled. If it doesn't recover, you'll need professional help. I've no idea what country you're in, but in the UK Miele offer a fixed-rate repair service including collection and return delivery and new filters and a bag (!), which will almost certainly be cheaper than getting an independent service centre to do the job.
May 25, 2010 | Miele S 4210 Bagged Canister Vacuum
When turned on the sound is like its screaming. It appears to be coming from the filter compartment. It all seems to work ok.Thanks
I suggest checking the filter. If it's coming from the HEPA filter area, the filter might be out of position or possibly you have the wrong kind of filter. Miele uses 2 different types of HEPA filter so that could be the problem.
Aug 23, 2009 | Miele Cat Dog Plus S511 Bagged Canister...
Disassembly of Miele red star?
First remove the lid by opening it and pulling straight up while using a screw driver to pry on the black hinges that go straight down into the unit. After that there are two silver screws on the black pedal assembly pull up and back to remove this assembly . Remove the HEPA filter. Remove the screws under the pedal assemble and pull straight up. What ever you do do not remove the cord winder assembly it wil spring and you will have to replace it. For any parts,filter or bags for this or any other unit visit www.stevessewandvac.com
Aug 12, 2008 | Miele Vacuums
Vacuums Logo
459 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
