Question about Leadtek Winfast PVR 2000 (663001C) Video Capture
WinFast PVR2000 - recorded video has no sound
I've was using my PVR2000 without problems until I decided to upgrade my machine. I installed a new WinFast K8M890M2MA motherboard and 2GB of RAM. Now my PVR2000 audio and video works fine when I watch TV but when I record a TV program I get video without sound. All the TV shows I recorded before I upgraded still play back fine. Only the new recordings are affected.
Please help,
Thanks,
Neil Cooke
I have installed the WinFast K8M890M2MA motherboard, too, but it doesnt show my hard drive on the 3rd IDE channel (S-ATA).
What can I do ?
Posted on May 27, 2008
Doral61
Go with rabbies. Even if you have the right hardware setup sometimes it's best to check software compatabilities and setup with system configurations. Small terms go into audio devices and enable it.
Posted on Mar 25, 2008
    Master:
  • 474 Answers
I agree, it must be an Input problem, It may be plugged in to the wrong port, or if you have onboard and a sound card, you need to plug it into the whichever one you have in use. If you installed the sound card and windows is set to use it in the audio settings, then plug it into the card, if its set to the mainboards built in audio, then you need to plug it there. But since you got the sound card u got the sound card you might as well use it and set windows to use the sound card and plug in the audio into there.
Posted on Feb 26, 2008
    Problem Solver:
  • 7 Answers
Check the software configuration for the tv card to see if it using the correct audio device
Posted on Feb 25, 2008
I 've had my canon vixia hf100 for about 2 years and it starts to malfunction during video recording. when the machine is cold, meaning it has not been used for a while, i can start and record video for...
Since upgrading your firmware would be the easiest and cheapest method to attempt to fix this issue, I would do that first and see if it helps.
If it's a hardware issue then deciding whether it would be "worth" fixing or not is more up to your preferences and pocketbook than any other consideration really. If the firmware upgrade doesn't fix the issue then I'd get an estimate on doing a hardware fix. You can decide from there whether to just get a new camera or fix the one you have.
Mar 22, 2017 | Canon VIXIA HF100 Flash Media Camcorder
Can i use microphon on winfast pvr 2000 on audio in?
No , you cannot use microphone on WinFast PVR2000 . The two audio jack is for audio input ( L & R).
Thanks
Please rate me if you got a satisfied answer
Mar 20, 2011 | Leadtek WinFast PVR2000 Video Capture
I can't reinstall divre for tuner pc card
first install the software/driver. make not to connect the tuner card.
next, insert the card then let it detect by itself. if it doesn't work then ask for a new driver. also be aware of your driver is match with your operating system.
Apr 10, 2010 | Leadtek WinFast PVR2000 Video Capture
Cpu upgrade for Winfast n15235 currently AMD 3600+ 2.0ghz, GSA h40n opitical drive , 750g WD,ROXIO 2009 Cineplayer,Realtek HD audio,nVidia 7200 , Vista occasional stop...
To be quite honest you do not need all that for watching a good quality movie! Your processor is good enough! As long as you got a nice upgrade on your video card and sound! A nice Player and enough Ram you will have great video playback.... I hope this helps you decide.. Good luck to you!
Oct 17, 2009 | Computers & Internet
HOW T DO I CONECT A VHS VIDEO RECORDER TO MY WINFAST TV 2000XP EXPET TV CAPTURE CARD ?
Your VHS recorder has a Coaxe output! So does your card the sound will be replicated there as well, now it would not hurt to get a capture card that has those plugs as you rendering would be much more prestine. Pluag you VHS into the coaxe input on your card set the channel to 3 and you got it bud!!!
Rulds2008
May 25, 2009 | Leadtek WinFast TV 2000 XP Expert...
No sound from WinFast PVR2 tuner card
i looked at my windows xp winfast and i discovered that the audio was working only with the realtek hd audio
now the link is here and u can chose the driver:D:
http://www.realtek.com.tw/downloads/downloadsView.aspx?Langid=1&PNid=24&PFid=24&Level=4&Conn=3&DownTypeID=3&GetDown=false
May 08, 2009 | Leadtek WinFast PVR2000 Video Capture
Using TV card on PC video perfect no audio
SOme PVR cards need a small cable from PVR card to the Sound card input to play sound via the sound card.
Jan 16, 2009 | Leadtek WinFast PVR2000 Video Capture
Audio only capturing through one speaker
Check the mixer and make sure that the recording source used for capturing is enabled and that the channel is set for stereo by making sure that the balance is in the middle.
Aug 04, 2008 | Leadtek WinFast PVR2000 Video Capture
Play tv on pc
Please post a little more information, your question is more along the lines of: My father stopped breathing, what could the problem be.
Jun 07, 2008 | Leadtek WinFast PVR2000 Video Capture
No sound
It uses your computer's standard sound card. You should plug the audio output from the TV card into the Line In on your computer's sound hardware.
Dec 09, 2007 | Leadtek WinFast PVR2000 Video Capture
Leadtek Winfast PVR 2000 (663001C) Video Capture Logo
729 people viewed this question
Top Leadtek Televison & Video Experts
Are you a Leadtek Televison and Video Expert? Answer questions, earn points and help others
