It seems like you're experiencing an issue with your Panasonic microwave oven NNT551. If the clock button is not responding and you only see two dots when pressing the stop button, there might be a few things you can try to troubleshoot the problem:
Power Cycle the Microwave:
Unplug the microwave from the power outlet.
Wait for about 30 seconds.
Plug it back in and try setting the clock again.
Check for Child Lock:
Some microwaves have a child lock feature that can prevent certain buttons from functioning. Check your manual to see if your model has this feature and how to disable it.
Reset to Default Settings:
If there is an option in the manual or settings to reset the microwave to its default settings, try doing that.
Inspect for Physical Damage:
Ensure there is no physical damage to the control panel or any other part of the microwave that may be affecting its functionality.
Does the power panel have anything on it?? If not. it probably has a burnt fuse inside the unit, one year old should have a warranty on it Check out places that work on microwaves.
Disconnect the microwave from the power source while the power is still
out. If the microwave is a built-in, turn off the circuit breaker.
Otherwise, unplug the microwave from the wall outlet. This prevents a
power surge from damaging the magnetron tube when the power is restored.Turn on the circuit breaker or plug the microwave into the outlet only
when you are sure that the power is permanently restored. If there are
still storms in the area, the power may be disrupted again.
Reset the clock on the microwave. Microwaves vary slightly on how to set
the clock, but usually there is a clock button you press. Use the
number pad to input the correct time and press the clock button again to
set it.
Test the microwave by heating some water to ensure that it is still in good operating condition.
locate the microwave's power supply cord.Remove the power supply cord from the wall outlet.Wait one to two minutes.Re-insert the power supply cord into the wall outlet. The microwave is now reset.
TO MAKE YOUR MICROWAVE WORK AS REQUIRED BY YOU.TAKE THE RESET STEP
4 Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
5 Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
no reset button. if you are getting lights that means you are getting power and all your fuses are good. you may have a bad control board caused by the surge
Press
the "Off/Clear' button to cancel anything on the display, and reset the
microwave. This is a soft reset and will simply get you out of any
program you have started. Press it when the cooking complete reminder
appears on the display.
Perform
Reset
Check to see if you have a "reset" button on your microwave, or even just by pressing the "clear" button first. Check to see if you have a "master" or "red" reset or "test" button nearest to your microwave on a light switch and reset that if applicable. You could also check to see if your unit has a fuse and replace that. It's possible when you tripped the fuse in the house you might have blown the fuse in the microwave.
The "RESET" indicates that there was a power failure. You should be able to push the clear/reset button and then set the clock and be on your way.......
