Question about Motorola Talkabout T5950 (7 Channels) 2-Way Radio
Motorola t5950 two way raido
All settings the same but raidos wont talk to each other?
    Problem Solver:
  • 5 Answers
I do not have any experience with that model, however, i tried a cheap set a short while back, i noticed that if i tried to talk to the other portable while holding it, it would not work. i set the portable down and walked away from it, and it started to work.
maybe?
Posted on Feb 26, 2008
I recently bought a used hyundai 2004 elantra but the faceplate was stolen so can you tell me what sort of faceplate is compatible so that I can buy the faceplate only?
first off is it an oem raido we are talking about or is it an aftermarket raido if it is oem you can try the dealer but if its aftermarket you are better just buying a hole another raido and lertting a pro installing it for you
Aug 14, 2011 | Hyundai Electronics Hyundai Elantra 2004...
T5950 talk about
Check your frequency, code and Qt filter settings. All must be identical. For basic operation set the code and Qt filter to off (zero). Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/T59xx_User_Manual_E.pdf
Best regards.
Feb 06, 2010 | Motorola Talkabout T5950 (7 Channels)...
I had to get a new battery and now my radio wont
YOUR RAIDO HAS A CODE # TO PREVENT THEFT, YOUR DEALER CAN GIVE YOU THE CODE. WHEN YOU REMOVED BATTERY RAIDO THEFT CODE WAS SET OFF IN RAIDO.
Feb 01, 2010 | 1999 Buick Regal
CAN YOU CHANGE THE RAIDO WITH OUT HURTING SECUITY
no, you have to know the code if you want to use the factory radio again, if you switch to an aftermarket radio, you wont have to worry about messing up the security settings
Dec 19, 2009 | 1999 Oldsmobile Alero
Repeater channels
Are you certain you are near a GMRS repeater in your area? If you have your radios set for the GMRS repeater channels the radios will not talk to one another unless you are in close proximity of a GMRS repeater. To talk radio-to-radio you would need to set your radio to one of the simplex frequencies available in the radio.
If you know you are close to a GMRS repeater, you might double check the Tx and Rx frequencies of the repeater to be certain they match the settings in your radio. Also, you will need to be certain your interference code is set to zero (the off position) to be used with the repeater. I didn't read up on the T7200, but if it has a Qt filter, set it to zero also.
Jul 26, 2009 | Motorola Talkabout T7200 (22 Channels)...
T5950 Talk abouts
They are probably not programmed to match one another. There are 3 key settings on these radios: Frequency, Interference Eliminator and Qt Filter. If you walk through the programming instructions for each of these and set them identically, they should communicate.
Feb 03, 2009 | Motorola Talkabout T5950 (7 Channels)...
Cobra 29 LTD classic when turned on it shuts off
Well I hope you didn't clip D12. D11 makes sense to me. If you clip that you are disabling the AMC, automatic modulation circuit. This will allow the radio to modulate at full modulation all the time, which isn't always good. You can over driver your final and possibly blow it.
Most of the time you can just turn up VR4. thats the AMC adjustment. It will raise your modulation to the max but will not over modulate it.
You probably blew the final and or more components as well. Your going to have to take it to a radio tech. This is no simple fix.
Jan 26, 2009 | Cobra 29 LTD CB Radio
Pair of radios won't talk to each other
Have you checked the QT filter? The T5950 have an addtional interference filter called the QT filter. It filters out other radios and allows Motorola radios to speak only to other Motorola radios with the filter. Check the QT setting on both radios by pushing the menu button 6 times, the QT setting will show. If it shows a straight line on the display the filter is not on. Now push the + button (beside the menu button), to turn the QT filter on (a Y will show on the screen when on) or the - button to turn it off (the line will show when filter is off). The radios have to match all channels and all filters to talk to each other.
Dec 09, 2007 | Motorola Talkabout T5950 (7 Channels)...
Motorola Talkabout T5950 (7 Channels) 2-Way Radio Logo
183 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
