LG INTELLO WASHER WM-11150FB
HOW DO I REMOVE THE OLD DOOR GASKET AND REPLACE IT WITH A NEW ONE>
CHEERS
  • bjmvh9 Jun 13, 2008
    I'm replacing the gasket on my LG WM1814CW and can't seem to get the gasket back on the drum to connect the spring etc. I've spent ours and tried numerous things ti get the new gasket on, any helpful hints???
  • Anonymous Mar 14, 2014
    How to fix door handle kit on LG intello washer D
    WM-14225FD, what way does the spring go?
    President:
  • Washing Mach... Master
  • 2,651 Answers
The bellow or door boot is what i assume were talkin about.and needs replacing cause its ripped correct? peel back front rim of bellow and is secured by a spring clampremove clamp and it is then attached by a larger clamp to outer tub assy, might be some work but youl get it
Posted on Feb 24, 2008
Lg tromm washer leaking from front door
We have the same problem with our LG washer. Don't think the door can be adjusted but I'm not for sure. I think the gasket is wore out but haven't checked on fixing the problem yet because it barely leaks.
Sep 29, 2012 | LG WM-2277HW Front Load Washer
Model - LG F1480FD. Need to replace drain hose. Please advise best way to get in to replace drain hose (? from bottom side etc.)
underneath......
drag maching to outside door and let old hose hang outside
this will drain alot of water out of machine then upend it to replace old hose with new 1
cheers
Mar 27, 2011 | LG WM-1480FHD Front Load Washer
Needing a part# for the door gasket on my lg wm2016cw front load washer. we bought it used and the seller didn't have the manual.
I have this washer, and the owner's manual. There are no part numbers listed anywhere. I need to replace my door gasket as well :(
Feb 07, 2011 | LG WM-2277HW Front Load Washer
Replace door gasket lg wm2277hw
Hiya,
you can find spares for this machine on espares i think the gasket will be a universal one but here is a link for you to check
http://www.espares.co.uk/parts/lg/p/0/81?k=wm2277hw+door+gasket
Please note i have not used this site before but i have noticed that they will deliver to most countrys & im sure they will be able to help with a fitting tool issue if you contact them.
Hope this helps
Apr 20, 2010 | LG WM-2277HW Front Load Washer
The gasket at the front door collects water and turns to dark slime in our other wise nice LG front loading washer What is there to be done about this dirty & slimy problem
you may need to replace the door gasket .. it may be sealing properly. that green slime you speak of i s called algea, same fungus found in swimming pools.. you can use algicide to remove it . Pleas were gloves
Oct 11, 2009 | LG WM-2277HW Front Load Washer
LG Washer leaks from front door
search the parts stores on internet then check ebay i find many times the common parts such as door gaskets can be had cheaper on ebay
Sep 29, 2009 | LG WM-2277HW Front Load Washer
Lg intello washer error code cl
fault code "cl".you have your child lock function on.push the two child lock buttons together on the control panel,hold them for a few seconds till the "cl" icon dissapears
Jan 29, 2009 | LG WM-2277HW Front Load Washer
LG front door washing machine gasket, how to replace it ?
how do i replace the door seal on my intello LG washer the old one is torn
Jan 05, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG intello WM12235
SE error code means a communication problem between the display controls and the main control board.  You will need a qualified LG technician to locate and repair the problem.
Jun 09, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
291 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
