Question about Epson Stylus Photo R300 InkJet Printer
Cd tray my printer will not take my cd tray help
    Genius:
  • 2,985 Answers
Tell us more about the difficulty?
Here are some tips.
1. ensure there is enough clearance between the back of printer and the wall- The tray travels a considerable distance through the machine.
2. Check the front edge feeder tags for damage that would prevent proper engagement.
3. If this an early model an improved version is available from Epson and E-Bay
4. pose the question- with more detail of the trouble to
www.fixyourownprinter.com
Posted on Feb 25, 2008
Canon MP810-CD-R Tray loading-printing problem
I am trying to print on DVD with Canon MP810 but the image won't line up - seems to be taking the tray too far in and printing some of the image on the F tray! Help.... it's driving me nuts
Jun 02, 2009 | Canon PIXMA MP830 All-In-One InkJet...
R220 printing on cd tray instead of disk
double check how you are inserting the tray into the printer. It should be with the cd in the holder, facing upwards and cd in first.
Gremlin11
Dec 10, 2008 | Epson Stylus Photo R220 InkJet Printer
Wont print
I think it might be the rollers of the printer are going bad. since its need to be in timing correctly, what i do is this.
when the printer start taking the cd tray in a bit push it in aq bit while its going in. DONT FORCE it in just push it in as it goes in, the roller are not catching the CD tray properly, its not the tray itself as youve found out, the rollers are going bad or are to dirty.
try cleaning the area of the CD tray with alcohol, then see if that helps.
good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/david_92c86cbc79e9b552
Dec 04, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Epson 220 not printing cd labels anymore
Clean the white areas on the tray with a light solvent cleaner like windolene/windex liquid. Also try giving the tray a helping hand as it is started to be fed into the printer
Nov 08, 2008 | Epson Stylus Photo R220 InkJet Printer
Epson stylus r1800 problem with printing on cd/dvd
Try this :
Disconnect the printer from the computer.
Turn it off & make sure the CD/DVD tray is closed then turn it back on.
Here's generic instruction for you:
If you are receiving an error pertaining to the CD TRAY NOT BEING INSERTED CORRECTLY, please do the following:
Recommendations:
-Don't force the CD/DVD tray into the printer.
-Make sure your printer is powered on, and the output tray is in the upper position.
-Please ensure there is at least 3 inches of space behind the printer, or the CD tray may eject.
Included, are the correct CD/DVD loading instructions. Please follow the instructions below:
CD/DVD LOADING:
1. Ensure the printer is powered on. Remove any paper from the sheet feeder.
2. Push in the paper support extension on the printer, and close the paper support.
3. Push in the output tray extensions, but leave the tray open.
4. Lift the output tray. Place one hand on the top of the printer, and pull up on the output tray until it stops. Lay the tray down in the upper position.
5. Place the CD or DVD into the CD TRAY with the white (or printable) side facing up. Note: To print on small 8cm CDs, please place the small CD ring on the tray first, then place the CD inside the ring.
6. Slide the tray into the tray guides located in the output tray. Push in the guide until the arrow on the tray matches up to the arrow on the tray guide.
7. Press the PAPER button to load the CD/DVD into the printing position. The CD is correctly loaded when the printer's POWER button stops flashing.
General tips for CD and DVD printing:
-Burn data/video/images onto CDs or DVDs before attempting to print on them.
-Do not use thermal-printable or regular CDs or DVDs in the printer.
-Moisture or fingerprints on the printable surface of the CD may cause marks or smearing to appear after printing.
-All printable inkjet media is different. Some surfaces will absorb ink better than others. If output appears banded, faded, or streaky, print a Nozzle Check pattern to confirm that all colors of ink are printing completely. If the ink does not completely dry or smears after 24 hours curing time, you may need to use the Epson Print CD tools to adjust (lower) the print density.
-The only supported resolution for CD/DVD printing is 1440 dpi (aka "Photo")
-Borderless printing and printing on the "inner circle" (plastic around central hole) of CDs is not supported.
-Do not use the "print preview" feature provided by the Epson printer driver as it will only show the image on a blank field and does not offer a clear indicator of where the image will print.
-The Epson Print CD software works best with JPG images and may not import some TIFF images.
Sep 26, 2008 | Epson Stylus Photo R1800 InkJet Printer
Epson stylus r200
(1) Check you have about 6 inches clearance at the back of the printer
(2) When loading the CD Tray, Align the arrows then when the printer starts to feed the tray, give the tray a gentle push towards the back of its direction of travel. That seems to help on my R200
Nov 28, 2007 | Epson Stylus Photo R200 InkJet Printer
Ip5200
cd tray, as in the bottom tray,or the back feed one?
no worries, check for up to date printer drivers here
Nov 27, 2007 | Canon PIXMA IP5200 InkJet Photo Printer
Cd tray not feeding
I had the same problem. My printer was sitting too far back in the cabinet and the cd tray was hitting the back wall when it was pulling it throuh. I moved the printer forward and the obstruction in the back was no longer an issue. It started printing all cd's just fine.
Jul 17, 2007 | Epson Stylus Photo R220 InkJet Printer
Epson Stylus Photo R300 InkJet Printer Logo
41 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
