Telly turns itself off
Our Samsung CW21A 113V telly switches itself off completely after varying amounts of time. Sometimes it lasts for about an hour, sometimes less. When it turns itself off we have to go to the telly, switch it off and back on again. First I thought it is due to overheating, but I doubt it that it can overheat in about 10mins. That problem started about 2 months ago and for some reason sometimes it works better than at other times and when you switched it back on about 10 times it stays on (nothing to do with the room temperature). It's not an old telly, too, maybe about 2 years and it is well annoying.
    Scholar:
  • 135 Answers
Hi there!
Have you checked for loose connection on the mains plug wires or perhaps a faulty mains adaptor. Otherwise it can be dry joints in the power supply or perhaps capacitors which have failed. If not sure refer to a repairer. Good Luck,JUS004
Posted on Feb 29, 2008
What is wrong with my telly if it is stuck on standby all of the time.
Fault with main board. Damaged component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
Sep 13, 2014 | Televison & Video
Mitsubishi WD-62725 62 in PC input Noise issue
There could be a problem with the connector it self or try your default settings here is a usefullink that could help
http://boardreader.com/t/Rear_Projection_Units_16082/Official_Mitsubishi_WD_XX833_Owners_Thre_899744.html
and this one
www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
you can try servicing or changing the connector your self
THIS IS THE HTML LINK
http://72.14.205.104/search?q=cache:Z1FFmuoMqjAJ:www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf+Mitsubishi+WD-62725+pc+input+noise&hl=en&ct=clnk&cd=18&gl=tt
you can download your service manual for the Mitsubishi WD-62725
and attempt repairs your self or take it into a profession.
REGARDS
Jan 03, 2008 | Mitsubishi WD-62725 62" Rear Projection...
??? My LG 50PN4500 TV has a strange one-time issue, I turned it on last night (was on standby) and a full screen "shadow" pattern of squares appeared? They were gray but I could see the colour...
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Mar 12, 2017 | Televison & Video
I turn on tv. There is sound but no video.
hi, if you have a device plugged into the telly that gives you the picture such as sky or cable then the best thing to do is disconnect this device from the back of your telly then switch the telly and this device off at the mains, then re-fit all the cables making sure they are connected properly then switch it all on.
now check if you have sound also make sure the tells is on the correct input for that decice and also make sure the mute button has not been pressed on the telly remote or on the remote of the device you use to watch telly, if after doing all that it still dont work then the chances are something has blown on the amp in the telly.
make sure you double check all the leads going into the telly to rule out a faulty lead causing you the problems
Jul 13, 2010 | Televison & Video
Does not turn on new battery in the remote. sensor light on telly blinks all the time.
Now,telly power LED light indicator on the LCD telly panel blinks all the time now?Yes,than the telly power supply board is dead.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.U in a European countries right?Talk to the customer service,before u buy that refurbish power supply board.Make sure it work for European cofigeration set,like 240v power supply.
Jul 19, 2010 | Samsung LE37R72B 37 in. HD-Ready LCD...
Telly on but no sound orpicture
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL2100 you can find it here http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173 .Have a blessed one!
Apr 20, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv switches off
set goes on 20 seconds it goes off
Feb 24, 2008 | RCA TruFlat 27F520T 27" TV
Birghtness 100 Popup
sounds like your "brightness" button may be stuck. try pushing it and see if it feels the same as the other buttons (should feel it "click" a bit). Also see if any of the other buttons work, because if it IS stuck, they probably won't work...
Nov 29, 2007 | Samsung 710N V2 17" LCD Monitor
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
