Question about Fuji FinePix S2 Pro Digital Camera
The Camera Fuji FinePix S2 Pro1 is not starting up
As we have no manual please do inform us what is the error message for low battery
  • PUSCHY Jun 08, 2008
    I HAVE A PROBLEM WITH THE BATTERY LIGHT FLASHING ON THE LCD MONITOR EVEN WHEN NEW THEY ARE A ENERGIZER ALKALINE BATTERY FOR DIGITAL CAMERA AND ALSO WHEN YOU BUT THE CR 123A BATTERY IN IT SHUTS THE CAMERA DOWN CAN YOU HELP ME PLEASE
  • Teresa2002 Nov 27, 2008
    camera will come on but it will not take a picture
    Genius:
  • 2,985 Answers
This can be a graphic of a battery in red.
or it may be a text message.
If you have the software disk the manual may be on the disk in PDF format
Posted on Feb 25, 2008
  • 3 Answers
Generally, in indicator on the back display shows empty battery; sometimes after a short a message Err on a display
How to reset to factory settings , my fuji finepix s2 pro. the auto-focus function is not working. Camera can only be focused in the man mode. can you help?
Please try to download the manual in this website it can help you on how to reset the setting of your FUJI Fine Fix S2 PRO
http://downloads.fotosource.com/public/camera_manuals/Fuji/DigitalCameras/FinePixS2Pro.pdf
Thanks
May 09, 2011 | Fuji FinePix S2 Pro Digital Camera
My fuji finepix S2 pro camera can not turn on when i put 2 cr batteries into its grip, when i remove 2 cr batteries it's turn on and work but i can't using flash, error no cr batteries found. Please show...
This is an old post but if you haven't found your solution yet here is the solution.
The Fuji FinePix S2 Pro uses two sets of batteries one set located in the camera body grip and another set in the battery grip itself. If you are experiencing the problem you are then the batteries in the camera body are dead and need replacement. here is a diagram. Replacing the batteries in the camera body require removing the grip.
Diagram
Jan 06, 2011 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro won't turn on
I had a very similar problem a couple of years ago. Found intermittent power from AA source when battery tray was moved slightly while shooting. I ordered a new AA battery tray from Fuji ($50 I think), problem solved, no trouble since. The tray must hold the batteries tightly against the contacts inside the camera. Camera had only shot about 5000 frames when the problem arose. Hope this helps.
May 01, 2009 | Fuji FinePix S2 Pro Digital Camera
Error message is F--
Well, it looks that FE message means that the camera is confused. I saw this message when I put a non-D lens and automatic TTL flash  (which does require D lens to measure a distance). Usually putting the camera (or flash in my case) into manual mode got rid of the error.
Jul 03, 2008 | Fuji FinePix S2 Pro Digital Camera
Err message on my S2 Pro
Try removing the lens, the memory card, and the lithium batteries. With freshly charged AA batteries, turn the camera on. If it comes on without the "err" message in that case, your problem lies with the memory card, the lens, or the lithium batteries. Turn off the camera and add these things until you encounter the problem again.
For a lens, check to make sure the electronic contacts are clean and that the lens gets fully twisted into place, and that if there is an aperture lock, that the aperture is set to the smallest possible aperture (22 or 16, usually).
For the memory card, reformat it elsewhere if it is causing problems. The Fuji S2 is notorious for being picky about memory cards.
Lithium batteries that are slightly run-down can cause all sorts of issues. Your S2 doesn't need to use lithium batteries, except for the built-in flash. You can add an extra AA battery pack to replace the lithium batteries, and that will improve the camera's reliability.
Jun 13, 2008 | Fuji FinePix S2 Pro Digital Camera
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
Error
Here is where you can download a copy of the manual from:
Fuji S2 Manual
This is what the manual says about your error:
If FEE in in top display: "CPU Nikkor lens other than G-type
is not set to its minimum aperture. Fix: Set lens to minimum aperture."
If FEE is in viewfinder: "Attached flash is not set at TTL
Auto Flash in “P” mode. Fix: Set the external flash mode to TTL, or set the camera’s exposure mode to “S”, “A” or “M”."
Are you using a flash that attaches to the camera?
If not, then the problem is with the aperture setting. It looks like you would have to set the camera dial to M, for Manual, and use the ring on the lens to set the aperture.
The low battery symbol looks like a battery, all black when charged, half-black as power goes down.
This looks like a nice camera, hope I was able to help.
Feb 24, 2008 | Fuji FinePix S2 Pro Digital Camera
Error msg fuji s2
couple of things:
I take it that "Err" shows on the display ? This can be caused by a number of things, including the aperture ring on the lense being in the wrong position. Make sure its set to the orange number. The 'err' message isnt generally shown for a power problem. If you have a DC power lead, attach that and see if you can get the camera to work.
Batteries are a nightmare for the S2.
Firstly, if looking for rechargeable AA's, you need at least 2300mAh. Maplin are doing a good deal till the end of the month on them; http://www.maplin.co.uk/Module.aspx?ModuleNo=46414
If you have the small lithium batteries in, then take them out. If the camera senses that they are in there, it will try and use them -even if they are depleted.You can replace them with CR123a batteries, but unless you want to use the on-camera flash, I wouldnt bother. DONT BUY RECHARGEABLE CR123A s !! They do not have anywhere near enough power.
Summary; Check aperture ring remove/replace CR123a (High quality replacement) Use high power AA's
let us know if this works
Nov 12, 2007 | Fuji FinePix S2 Pro Digital Camera
Error
Before the heart attack, check your lens. I believe its the D series lenses that need to be set to all the way open. I get this "err" alot, and then look down to see that Ive rotated the appature.
Sep 12, 2005 | Fuji FinePix S2 Pro Digital Camera
Fuji FinePix S2 Pro Digital Camera Logo
245 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
