Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean. http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly. https://youtu.be/wUpnETSm6_k https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean] https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
If remote control is working properly, the fault is with the infrared sensor circuit inside the TV. Check and replace the infrared sensor.
seems its display and micro receiver r not working .kindly contact to your local repair man to replace remote receiver And display. Hope answer the question
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. http://electronicshelponline.blogspot.com/
If the remote control works fine, replace the infrared sensor inside the TV.
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
TV off
Bring remote within 3 feet of TV
Push Pairing button (Paper Clip or other pointed object in button hole)
Turn on TV
Should be paired. Try remote channel or other buttons.
If not, try 2 more times.
If still not working, push RESET button first and repeat Pairing.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
make sure the sensor bar is plugged in and oriented properly. If thats all ok I would be inclined to believe its the sensor bar, but you might try nintendo customer support before you go out and buy one.
replace the IR sensor...I don't have a part number for it..but I have
seen IR sensors grow either weak..or fail totally..also you'll want to
verify that the remote is working...you can buy an infrared detector
strip from radio shack for a couple bucks...all you do is push power on
the remote continuously..and hold the detector strip up to the front of
the remote..if you see a red flashing on the strip..the remote is
transmitting..if not..the remote has low battery..or has taken a dirt
nap.......
