Computers & Internet Logo
Anonymous Posted on Feb 24, 2008
Formating memory card
I amd have china brand moble. 256 MB memory card installed on the moble. I formatted tha same with PC and now it is showing only 60 MC card. What is the solution to recover all memory back
Anonymous
Level 1:
Problem Solver:
  • Contributor 12 Answers
  • Posted on Mar 03, 2008
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
12
Questions
Helped
14669
Points
20
U probaly cant.once u lose data u lose it.
1helpful
I have AMD Sempron 140 on ASUS M2N68-AM SE2 motherboard, Strontium 1GB PC800 DDR2 RAM. But in system properties, the RAM is showing as 768 MB instead of 1024 MB (WinXP 32 bit). The dealer is saying the RAM...
Yes the dealer is correct that the 256 MB of your RAM is allocated to the video card of this computer since the unit has a built in NVIDIA GeForce 7025 Shared video memory (UMA)that uses 256 MB of your RAM , so if you like to maximize the use of your RAM you need to install a expansion video card.
Kingston 2 gb i cant format showing insert a disk and then try again i want format how
sir if you are using adaptor of memory card for connect it with pc then i think this error occurs so use card reader and then insert the memory card in it..........the right click on the removal disk and click format when you click on format then click quick format then o.k if this error occurs again then scan the device or go to device manager and then check whether the property of usb is enable or disable if error still continue then mail me at [email protected] i will help you again take care
2answers
Memory card eror
go back to who that formated your memory card and tell him whats wrong he will take care of it from there its not suppose to charge anything
GeForce 6600 AGP 8x 256 MB in Asrock 7s41gx
get another hard disk and do a fresh install of xp then the drivers and the game see if its all ok
if it is then its your drivers get them out and replace them
with the latest from nvidia. or format and go again
hope this helps
2answers
How to format memory card
in most lgs u can go to the menu and then settings then memory and then go into card and select format then it shud b good
Memory Card Corrupt
Hi abhi.
Try formatting your card.
This should help.
Regards
Faraz
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
Memory Card!!!!!!!
format a memory card through DOS mode
GO on command prompt then go on drive of memory card e.g. remove device f
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
