Question about D-Link AirPlus DI-524 Wireless Router
Cannot connect to internet through DI-524
Hello Everybody,
I used to connect to internet through DI-524. But recently I am unable to connect through it but if i connect the cable which comes directly from the DSL modem to my pc the internet works. What is the solution to this problem? I am unable to solve this. Temporary i have connected my net connection directly to my pc and through another lan card i am sharing the net to other computers.
Please help
  • 9 more comments
  • flingerkiloe Feb 25, 2008
    I have the same problem and have tried rebooting the router several times. What is my next step?
  • problem001 Mar 18, 2008
    i got the same problem, what should i do?
  • Anonymous Jun 04, 2008
    i plugged in the dsl cord to the di-524 in the wan slot and another cord from slot # 1 to my laptop but nothin and i want to go around the house and use it but it wount coneect to the internet
  • Mr_Catshit Jun 06, 2008
    Yup !!! I have the same problem. I have booted the modem repeatedly over the past 1 1/2 days. Same issue.
    The WAN LED (light) flashes quickly. I understand from the D-Link site that this means the modem and router are / can not talk.
    I replaced the DI-524 router with a D-Link WBR 1310. It does the exact same thing; quickly flashing WAN LED. I tried this modem out at another house and it worked.
    NOTE: A slow flash means there is traffic. A Quick flash indicates problem. Steady on is for connection.
    My ISP (after a couple of hours on the phone) decided I needed to call the manufacturer and get instructions on bridging the two. Ya, riiight !!!
    I don't know the make of modem as it is supplied by the ISP.
    I am currently connected directly from modem to a computer. Not the way we want to live.
  • Anonymous Jun 07, 2008
    i have the same problem iused to conect wire less until power outage happened and i canot conect any more
    Router cuts out ~ once a month.  Used to be able to reconnect.  Must connect modem directly to computer in order to get internet service.  Can not use wireless. THis router is ****.
  • irvicanos Sep 09, 2008
    i can connect to internet for 2 or 3 minutes -- then it stops working. i have to connect directly to modem to connect again.
  • tommelissa Sep 09, 2008
    I lost my internet connection today, but my Ethernet light was on. Called ISP, they had me reroute the Eth. cable to the modem and change the connection configuration. That worked.
    I then went back and configured my Dl-524 again, changed the connection config back to bridged Ethernet, and turned everything off and on again. Still no connection when connected thru my router, but modem connection works fine.
    What's the life span of routers? Can they just stop working, or might there be some other problem?
    Thank you!
  • Anonymous Sep 16, 2008
    Ihave exactly the same problem. My solution buy another router which is not D-Link
  • Anonymous Jan 03, 2009
    I have the same problem. It seems like the router doesn't allow my internet through, unless I reconnect the Ethernet back into my modem. I have an installation CD, but the internet can never get through, so the connection test always fails. I use a surfboard broadband modem.
  • John  Savage
    John Savage May 11, 2010
    Hey there,
    My first question is what if anything has changed between the time it was working and now, configuration, cabling, etc? Secondly (these may sound dumb but I have to ask) have you rebooted the router and or have you tried to reset it back to factory defaults?
    J
Try this exactly as written.
Disconnect ALL cables from the modem and router: internet cable, power, and ethernet. At your option you can leave the computers on but if this doesn't work the first time, try it with the computers off.
Connect the modem, cable, ethernet, and power. Wait until modem has botted up.
Connect power on router,
then ethernet from modem,
then one by one connect the computer ethernet lines to the router.
If necessary, turn of your computers.
If this doesn't work, get religion and start praying.
Posted on Jun 06, 2008
After you've rebooted your wireless router...make sure you reboot the cable-company (or DSL) modem while the router is connected to it and on. The modem seems to recognize the router properly only in this way.
Simply unplug the power to the cable-modem and plug it in again.
If the cable-modem has a battery back-up you'll want to remove that as well.
Posted on Mar 22, 2008
All you need to is to reboot your router everytime that there is no internet connection...
follow this instruction if you dont exactly how to do that:
1. type in 192.168.0.1 on your web browser
2. log in by typing your username and password..if you dont know your username and password just type in Admin in the username box and hit enter.
3.once your in,click on Tools.
4.click Misc.
5.and click Reboot.
6.wait for it to reboot.
7.Now check your internet connection.
8.If doesnt owrk,reboot your router again.(you might reboot 2 to 4 times)
9.if it still doesnt work, just "Buy" a new router
Posted on Dec 18, 2008
This product is discontinued i hear so maybe there is a problem with it cuz mine doesnt seem to work anymore either and everyone seems to have problems with it...
Posted on Sep 20, 2008
Respected sir,
how to configure and instal the routter dl-524.please help me
Posted on Sep 17, 2008
  • kishorshrine Sep 17, 2008
    I dont know to instal the routter
  • 3 Answers
Okay this is wat i did its not the best solution but i recommed that you do it becuase of the simple fact it works....
step 1. find a small screw driver
step 2. unplug the router (power and data)
step 3 .unscrew the 2 screws at the back of the router
step 6 .take the cover off the router so you can see everthing on the inside
step 5. Leave to cool down
step 6 . plug everthing back into the router just leave it to start up (approxmently 2 min)
step 7. make sure that the nothing touchs the inside of the router
the reason for doing all this is because this wireless router overheats alot if it is used alot .... this should sovle all your problems (4 your info this may void your warrenty ... but at least it will work
Posted on Sep 15, 2008
I have the same problem can not connect to internet through Di-524
Posted on Feb 25, 2008
  • 76 Answers
Usually if this happens it means that you have either disabled your internet on your PC or the router and modem need to be restarted at exactly the same time. Hope this helped =)
I have router DI-524 and am unable to connect to internet thru this router. But it says, it is connected
I would do a hard reset by pushing the small button on the back. You will need a small pen to push it. Push and hold down button till the lights flash I would/ say 10-15 seconds should be good enough. Once it's reset try setting up all of your settings again. Remember if you have dsl you will need you username and password to be inputed in some cases. If it is broadband most likely you will not have to bother with username and pass hope this helps.
Nov 30, 2009 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 router won't allow me to connect to the internet
hello, make sure their is network subscription on the router, remove the wep. you can look at the back of the router and see if their is a reset button, reset the router if necessary.
Aug 08, 2009 | D-Link AirPlus DI-524 Wireless Router
I have a D link DI 524 802.11g/2.4GHz wireless router which I've
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
You do not need the disc. Using you browser, login into the router using the default IP 192.168.0.1 unless this has been changed and you should be able to configure your router.
Jun 14, 2009 | D-Link DI-524 4 Port Wireless-G Router -...
DI 524 and airport express
Yes, that is possible for as long the DI524 is already properly setup and can provide already internet connection everything should be working fine there....
Nov 10, 2008 | D-Link AirPlus DI-524 Wireless Router
Dlink di-524 connect to RV042
Hi.
You need to cascade the Dlink wireless router to your RV042.
Suppose your RV042 has a default IP Address of 192.168.1.1, and the DLINK IP uses 192.168.0.1. Your Physical connection is from the regular port of the RV042 going to the WAN/Internet Port of the DLink wireless router.
Once you do that, your Dlink router should automatically obtain an IP from the main router. If it did, configure your wireless settings and you should be able to connect via wireless.
This is just one way to cascade your router to another router.
For more information, click here.
Jul 21, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless
here you get the manual sir:
ftp://ftp.dlink.se/Products/di-products/di-524/Documentation/DI-524_manual.pdf -
or
www.amazon.com/D-Link-DI-524-Wireless-Router-802-11g/dp/B0001PFQ08 - 256k -
or
reviews.cnet.com/routers/d-link-di-524/4505-3319_7-30839580.html - 79k -
thanking you
Jul 09, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 connection
Hi jyothikry firest u configure your madam go to web page and access your ip address 192.168.1.1 then go to in said configure your madam
Jun 25, 2008 | D-Link AirPlus DI-524 Wireless Router
Connecting a DI-524 to a DI-604
This shouldn't really be any problem simply use a short "Uplink" ethernet cable to join the routers thru the uplink port, or any port really, and that way ya should be able to wifi and access the net, set ya router that connects to the net for DCHP and disable that setting in the Wifi router and ya should be good to go?
Jan 30, 2008 | D-Link AirPlus DI-524 Wireless Router
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Connect to wireless D-Link and Westell6100
I am assuming that you have a functional LAN cable connecting the Westell and the DI 524, right? If you are unsure, replace it with a cable you know is good.
If the 524 is turned on downstream of the Westell modem, it should find what it wants. You may try rebooting the Westell and seeing if the 524 finds it, and you maybe should reboot the 524.
Sometimes, when the world gets jiggered up I have to work pretty hard to get my DI-524 resync'd to my DSL modem.
Oct 26, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
2,177 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
