Question about Philips Magnavox 20MS3442 20" TV
Shut down mr.techman.please help me to solve this problem for magnavox tv#20ms3442,tv shut down in 2 second when press on. 5v present standby , 95v in horizontal. hopefully would get you help!!!!!!
    President:
  • 3,130 Answers
Sorry, I do not know that set.
Posted on Feb 24, 2008
My Magnavox MWR20V6 DVD VCR Combo shuts down, after 5-10 seconds, following start-up (on/standby button). I saw "E1(rear)," on the TV screen, just before it shut down the last time. I suspect...
Before anything, I would attempt to see what the E1 code signifies. But usually when those things just shut themselves down it is because of a serious problem in the power supply. I think it is time to go shopping.
Sep 16, 2017 | Philips Magnavox MWR20V6 DVD Recorder/VCR
The TV will not come on, it acts like there is no power. I have the back off the TV, how can I troubleshoot the power supply? I do not see any test points
Look at the connectors on the dc output side for the 5vdc standby voltage, most good power supply maker will label the voltages on the connector pins. You should hook up the TV while you are working it through the GFCI outlet because of high voltage is present. Look for bad capacitors, burnt parts, poor solder joints. The 5V stnadby is needed for other circuits to work, so start with that first.
http://en.wikipedia.org/wiki/Capacitor_plague
Nov 10, 2009 | Philips Magnavox 42MF521D/37 Television
I need a magnavox power injector m178dpi can you help
do not know what you mean by a power injector, can you explain where it isw and what it looks like and are there any numbers on it also what model number please!!!
techman
Sep 03, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Standby light red
my precission tv model ptv1444 ic lock i dont have the original controll, quetion how cai i unlock the tv, thanks
Nov 27, 2007 | RCA F19426 19" TV
Convergence is off
Starts up with black raster, then shuts down with LED blinking 4 times
This is the micro telling you that the auto grey-scaling procedure has failed. Change resistors R909, R913 & R922 (180k, 1%) on crt base PCB. You will probably find that all these have gone high
Standby only
Check R101 (4.7ohm), TR102 (C6180) and C126 (47uF, 16V)
Tv turns on automatically. Power supply works well, +5V present but seems that CPU (7700) does not (no standby mode), no remote or control on the front of the set
After replacing CPU (TMP47C434) and crystal 1770 (4.0MHz) both control worked intermittently. Replacing transistor 7674 (BC548) solved the problem
Will not work, standby (red) LED flashing
C604 in the 12V line is bad
Int going into standby
Replace C454 a 22nF smd, located near the Frame o/p ic.
Nov 24, 2007 | JVC AV-56WP30 56" Rear Projection...
Sony KV-32S22 32" TV Problem
Intermittent dead with red standby light on, but won't switch back on, comes back on it's own, won't respond to remote or local controls
Low 5v standby supply due to diode D869 faulty, check by replacement
Nov 23, 2007 | Sony KV-32S22 32" TV
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
2 Problems
1st problem-reduce the supply voltage on the power supply to the recommended 95v.if prob does not clear change suspect capacitors around the line output transformer. 2nd problem-check;continuity of av-cables ;dry joints on av inlet sockets of the tv card.
Aug 24, 2007 | Philips Magnavox 27MS343S 27" TV
Philips Magnavox 20MS3442 20" TV Logo
111 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
