Question about Hitachi G1000 Pocket PC
Stuck on align
I just got this phone last week, and I still can't get past the align screen. I know this is an older model phone, but it was new, I just can't figure it out.
  • Hitachi Master
  • 13,433 Answers
The touchscreen is most likely damaged if your unable to point and click on the spots it tells you to.
would need to be replaced. ofcourse first a reset and a hardreset should be done to make sure its not a software problem.
Posted on Mar 28, 2008
LENOX MINI SPLIT HAS A F8 CODE ON THE SCREEN
Cycle the power to the outdoor unit. F8 is a low or high line voltage fault. Not likely a real error if the unit has worked in the past. Possible power surge or something.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Jun 01, 2017 | Heating & Cooling
Screen not aligned
Ref. HP ipaq hx4700: "Align screen" after hard reset or battery loss. I know others have had trouble getting past the "align screen" setup; I saw a suggestion somewhere that said the points were registered incorrectly (maybe in some, but not all of this model?); and they had to tap at locations other than the center of the cross symbol. I tried a variety of combinations, and found that if I tap ABOVE the center (but still on the vertical centerline) for the middle, top left and top right locations; and tap BELOW the center (but still on the vertical centerline) for the bottom left and bottom right...it worked. That brought me to the "Stylus" setup screen...which I also became "stuck" on. So far, I haven't found a solution to THAT issue yet. Gee, why can't they make these things simpler?
Feb 13, 2012 | Computers & Internet
Align screen problem
Sep 21, 2011 | HP iPAQ HX4700 Pocket PC
I have an older Lowrance, Model X65, which until a few weeks ago worked as if still new. I hadn't used the boat for the past few weeks and when I did the Lowrance screen now has a large brown spot in...
You need to contact Lowrance about the repair.
My really older, but loved, unit failed and Lowrance pointed out that techonlogy is SERIOUSLY imporved, and convinced me to upgrade to a new unit. I disliked the price, but LOVE THE unit. TONS easier to read, even in bright sunlight, depth sounder portion much improved...twin beams really makes accurate reading, and fast readings (unlike older units).
May 08, 2011 | Lowrance Boating
My touch screen stopped working on my samsung impression so i put the rest code in and the phone reset then its now stuck on the calibration screen and the touch screen wont respond
Dont kno if "Impression" is similar to "Omnia" but 'REMOTE SCREEN ALIGNMENT' program installed on PC skips 'align screen' on your phone. Also "welcome.not" (made in notepad) & pasted into your root files. A REGISTRY EDITOR will allow you to input the touchscreen configuration numbers manually. Of course, none of these will be much good if you dont have 'Windows" phone or cant access your Registry!!
If all this fails, ASK 'XDA DEVELOPERS', or 'MoDaCo'.
Oct 29, 2010 | Samsung SGH-A877 Impression Cell Phone
My toshiba pocket pc is stuck on the pop up menu screen - I can't navigate around it.
The unit will not go past the alignment screen until it gets a good calibration alignment. Be sure to click as close to the little + marks with the stylus as you can. If the click is to far from where it thinks it should be then the alignment will fail and start over.
I hope this helps, if not let me know
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of PC and printer support/repair
http://www.wireless.att.com/support_static_files/manuals/ATT_Tilt.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Jun 29, 2009 | Computers & Internet
I have HTC P3450 phone
so just do it carefully click between the cross hairs of the plus sign at five points one after another with a pointed object carefully then it will move on to the next screen for further setup ,
but if u r stuck at this point and u are gettin this alignment screen again and again in a loop then my friend its a hardware fault basically it is a faulty digitizer or touch panel u can say the front screen where u click with ur stylus it became faulty u need to replace it other wise it will stuck on this screen alignment process and will not go past, u need hardware replacement it is around 60 to 70 $ cost to replace just take to the service centre in ur area or find it on www.htc.com or tell me if u have somethin else to ask.........pls lemme know if it helps
Feb 22, 2009 | HTC Touch P3450 Smartphone
Touch screen not responding.
Any chance you are using screen protectors and that the edge may have shifted under the case? If yes you have what I call a wedgie and it's causing a phantom tap in a non-accessible area. Remove screen protector.
Any chance there is some dirt/detritus wedged just under the edge of the case pressing on the digitizer? Fold the corner of a piece of copier paper to form a scoop and go around the perimeter of the screen no more than 2.5mm under the case to dislodge (not push in) anything stuck there. This method solved this same problem on my HTC phone
Nov 04, 2007 | Computers & Internet
XDA Mini II won't advance past the align screen
refert to this, it may help: http://forum.brighthand.com/showthread.php?t=217656
Sep 14, 2007 | O2 Xda II mini
Hitachi G1000 Pocket PC Logo
49 people viewed this question
Top Hitachi Computers & Internet Experts
Alun Cox
Marvin
Marvin
Are you a Hitachi Computer and Internet Expert? Answer questions, earn points and help others
