Audio Shelf Systems
Problem for Audio Shelf Systems
Generic problem for all Audio Shelf Systems
Panasonic SA-AK57 problem
By sannitig on Feb 24, 2008
I've already gotten a response to this. I'm not saying he's wrong but i would like a second opinion. I get a huge BANG!! out of my SA-AK57 mini-system then it shuts off with an F61 error. It happens only when the unit is first turned on, after the bang happens i can turn it up as loud as i want cause i know it won't happen again, untill the unit rests for a while. sometimes i get a slightly softer bang and it doesn't turn off....i'm pretty sure one day its just gonna not work. I really love this thing awesome sound, really loud and clear...I'm hoping that the fix isn't too much money
Same Problem
Dec 17, 2008
-   ughgh the speakers work good cause i tryed it on another stereo but it wont sound wit this stereo and they tha same speakerz that came wit it it doesnt turn off but u can here the bang right before tha speakers go silent again -   SLINKY69
Solution #1
posted on Feb 24, 2008
Not Rated)
Compurepair
Rank: Wiz
Rating: 84%, 784 votes
This sounds like a power disconnection problem.
you have a large amount of components, on the motherboard that charge up with being used. ( namely fets/capacitors et,c ) when your system is powering off the instant disconnection of mains power, can cause a Bang or Pop to the speakers.
I,d suggest trying swapping the speakers over from right to left and vice versa. see if the errors still there.
Also try turning the volume right the way down, before switching off. is the bang quieter ?
Check the mains cable ( plug end ) see if theres a broken or loose wire at the plu ( causing an arc ) finally check that the plug ( cable grip ) plastic tang that holds the cable, has,nt been overtightened and damaged the cable underneath it.
I hope any of this helps you to a self diagnostic rectification of the problem listed. Also try without speakers is a suggestion.
Mike @ Compurepair.
Was this helpful?
Yes
No
Popular Solutions for Audio Shelf Systems
Questions and Unsolved Problems for Audio Shelf Systems
Answer
Does the Sharp CD C602 have a light in the main window?
Answer
how to fix my mx-g500 subwoofers dont work?
Answer
I have an Aiwa cx-nma545 that I just hooked up to a Westinghouse SK-32h640g. The sound is very... (More)
Answer
glass door will not open and cd player will not rise to place cd in position
Answer
RCA 1285 5 disc CD changer, will not open, spin, or play? any suggestions? And yes it is plugged in... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Audio Shelf Systems:
Top Audio Shelf System Experts
Rank: Guru Guru
Solutions: 764
Experience: 30 Years of professional repair and design.
Ask Me
Find more Audio Shelf System Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
