Question about Epson Stylus C66 Inkjet Printer
Epson printer my epson will load up with the black ink
  • come 1 May 11, 2010
    my c66 printer will not load up with the ink what can i do and the ink it is new.
    Sergeant:
    Champion:
  • 322 Answers
Sounds like your coluer jets are blocked all you need to do is clean them for this you will need a suringe and a bottle of nail varnish remover put the suringe on the top of the nozzels then slowly push suringe you can tell if there clean as it will be easer to push
Posted on Feb 29, 2008
My epson sx215 wont use my new black ink
Help me please my Epson Stylus SX215 black ink won`t print. I cleaned the head 3-5 times and the nozzle but it still wont`t print black , it is brand new.Is it because the printer didn`t work maybe 2 months. Yesterday i bought all inks and the other are working , the black no :[ please help
Aug 04, 2012 | Epson Stylus Multifunction Inkjet Printer/...
EPSON SERIES L200 PRINTER DOES NOT PRINT BLACK COLOR
To everybody having issues with black not printing on the L200, I just got off the phone with Epson, and these steps solved it for me:
1.- Open the ink containers (lay flat and open carefully to avoid ink spillage).
2.- Run the Clean maintenance procedure from the Epson control panel
3.- Try printing a page with black features (still with the ink containers open)
3.- If it still won't print, try the Full Clean (it uses more ink, but in my case it was necessary)
4.- Try printing a page again (at this point it worked for me).
5.- Close the ink containers and put back on the side of the printer.
According to the Epson representative, this is the most common cause for printing issues with the L200 because the initial ink load creates a high vacuum and then the ink can't flow.
May 23, 2012 | Canon PIXMA Office Equipment & Supplies
Hello, I have the Epson SX510W and even though all of the ink cartridges are loaded, it doesn't use the black ink.It shows it does in the program for refilling it, but on the paper, the parts that are...
Epson printers have replaceable ink tanks but the firing nozzles are permanently built into the printer. The firing nozzle for the black ink is most likely blocked. Try the nozzle cleaning process via the supplied software, although this will waste a lot of ink and will not guarantee 100% success. If it is under warranty I would recommend returning it to the shop and buying a different make. These printers are not reliable and often require you to replace ink cartridges even though there is ink still in them, due to built-in chips which report the ink levels incorrectly.
Feb 16, 2011 | Epson Stylus CX5400 All-In-One InkJet...
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
Red light on steady
If the ink light is on steady red, that means the black or color ink cartridge is nearly empty. Obtain a replacement black or color ink cartridge. To know which cartridge is out of ink, check the ink levels using EPSON Status Monitor 3 (Windows) or EPSON Status Monitor (Macintosh). If you just replaced the cartridges before you got the error light, that means that the replacement cartridge is not recognized by your printer. Please reseat cartridges. Then turn the printer on and off. The cartridges maybe bad also.
If the paper light is on steady red, try to reload 10-20 sheets of regular paper into your printer. When printing on CD/DVD, CD/DVD tray is not inserted in the printer. Insert the CD/DVD tray in the printer and press the paper button.Could also be that the printer has loaded more than one sheet of paper at a time. Load paper in the sheet feeder, and then press the paper button to resume printing. If the CD/DVD guide is open, close the CD/DVD guide, load paper and then press the paper button.
May 17, 2009 | Epson STYLUS R230 InkJet Photo Printer
Black ink will not print
You have submitted this problem in the Epson R220 area - it is unlikely to produce a response here. Try again putting it in the HP 990 area.
Jan 30, 2009 | Epson Stylus Photo R220 InkJet Printer
Epson stylus c45
epson.com, actually you can print using black ink only, but you have to reset the color ink for it to register as full. :) or you can freeze the ink counter using the ssc service utility before the other ink rans out. :)
Jul 17, 2008 | Epson Stylus C46 InkJet Printer
Epson 1280
Go on line and down load this utility www.ssclg.com When program is installed- double click on the the icon in the lower task bar and select the printer type. Then right click on the icon in the lawer task bar- there you will see a range of tool to manipulate the printer ink system- try -reset black.
May 08, 2007 | Epson Stylus Photo 1280 InkJet Printer
Epson Stylus C66 Inkjet Printer Logo
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
