Question about Dell Latitude C610 Notebook
Dell Latitude C610 Issues
Hello, I have a Dell Latitude c610, I had upgraded it to Xp and haven't been using it as i have a few computers at home, I pulled it out about a month ago, and it wouldn't start, the 3 lights up the top and the lights on the side would come on for about 2 seconds and the go back off, the screen itself wouldn't have anything on it just stayed black, so having another one exactly the same here I transfered everything from it but kept the same mother board, put it back together and start it up and presto it works, the next day I go to turn it on and I have encounted the same problem from before, I was starting to think that it could be the BIOS battery so have disconnected it from the mother board and tried it and it works again, so could anyone be able to tell me how to fix this from happening again in the future? Many thanks.
  • Simmy Feb 25, 2008
    Hello again, I let it have a good nights charge over nite and still a no go, am getting the same 3 lights up the top and the lights on the side that come on for about 2 seconds and switch back off again, tomorrow I'm going to open it up again and see if theres anything that I can see that may be the problem, the machine itself is clean but I'll have a look around on the mother board as that seems to be the problem, other then that thanks again.
    Brigadier General:
  • 6,966 Answers
My compliments for having done all that. Not that many users would be inclined to go so far.
In any case on to your concern. Having been in storage for some time, it would be normal for the battery (and the memory battery) to have drained out. Initial powering of the unit from the storage would entail the battery gobbling up all the juices that the adapter can put out. What I would suggest is simply let it charge for a considerable length of time, say overnight.
You can try running the PC without the main battery. it it works normally then you have just verified that the main battery was consuming at least initially so much power that the charger/adapter has none left to power the laptop.
If even without the battery and the unit still fails to powerup, then next course of action would be to check for the section/area where the power drops off. This could include the connector/jack where the adapter plug comes in, the regulator connectors and/or the regulator circuit
At times, this could also be due to some corrosion or dirt in the jack and or connectors. it is also possible that the battery might have leaked "a bit" and has affected the board or the contacts/connectors.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa..
Posted on Feb 24, 2008
4 Suggested Answers
Pyrhyc
  • 2028 Answers
SOURCE: dell latitude c610 primary or administraitor password unlock
I believe I can help you. Is this a Windows password after it boots up, or is this a bios power on password before it boots? The bios password on a Dell is generally on a white screen when it's first powered. Get back to me, and I'll get you thought this.
Posted on Aug 30, 2008
pastorm
  • 98 Answers
SOURCE: dell latitude c610 has dead screen.
First of all, try to connect an external monitor to the laptop and see if you gen any video out.
Posted on Nov 30, 2007
lolita
  • 385 Answers
SOURCE: Dell Latitude C610 PC Notebook pct2304wt modem driver
The modem driver can be found at this link. try the PCTel driver first, more than likely that's the one it uses.
Lolita
Posted on Feb 02, 2009
Restore default settings on a dell latitude C510/C610
http://en.kioskea.net/faq/4189-dell-laptops-restore-factory-settings
Jan 15, 2013 | Dell Working Latitude C510 C610 Laptop...
Can I Upgrade from USB 1.0 to 2.0 on Dell C610
No. To do so would require changing the hardware, namely the motherboard. It is not a "software" upgrade.
Instead, buy a PCMCIA-to-USB2 adapter, and insert it into the PCMCIA slot in your laptop.
Oct 29, 2009 | Dell Latitude C610 Notebook
Question about graphics cards of Dell Latitude C610 laptops
Actually, the Dell Latitude C610 is one of those rare cases where the video card can be remove. It is a separate chip. I know because I'm looking at it right now. The only problem with upgrading is actually finding a video that actually fits and it better than the 16MB stock card.
Robert Falden http://www.digitalnewwsite.com
Apr 19, 2009 | Dell Latitude C610 16MB ATI Mobility Video...
Dell Latitude C610 PC Notebook pct2304wt modem driver, downlod c610
Lolita
Feb 02, 2009 | Dell Latitude C610 Notebook
Can't load windows xp onto my dell c610
when you are trying to install xp what method are you using
how are you doing it
Jan 20, 2009 | Dell Latitude D600 Notebook
Clean XP Pro installed -- now NIC disappeared!
Well once you did a clean install over all of Dell drivers etc etc. You wiped out the restore artion that was on the computer. You have to go to Dells website and under the support tab look for the Nic card that you have inside the computer.
Feb 08, 2008 | Dell Latitude C610 Notebook
Cover stripe damaged
sure they are the same on the c510 and c610 laptops.
i see them on ebay all the time for $5-$10.
look for c610 power button on ebay.
Dec 16, 2007 | Dell Latitude D600 Notebook
Dell Latitude C610 Notebook Logo
Alun Cox
