Question about Lexmark X5150 All-In-One InkJet Printer
Color not printing
I have installed 2 new cartridges in my printer. The color cartridge is very light and will nto print any darker. I have cleaned the cartridges and done an alignment and it still will not print color
    Master:
  • 619 Answers
Hi, try to head cleaning at least 4 times then after nozzle check you can determine the color complete it mean good and clean head.
Posted on Mar 01, 2008
Have an HP PSC 1510 printer. I put in a new genuine HP Tri-Color (93) printer cartridge as I usually do and the "Check Printer" cartridge started flashing. Also flashing on the printer is the...
Problem After you install a print cartridge, one of the following messages appears on the color graphics display:
  • Incorrect Print Cartridge
  • Incompatible Print Cartridge
  • Problem with the Print Cartridge
  • Remove and Check [color / black or photo] Cartridge
  • [Tri-color / Black or Photo] Print Cartridge Inserted Now is Not Intended for Use in This Printer
NOTE: In the procedures below, the "problem" cartridge is the one identified by the message on the color graphics display. If the message does not specify a cartridge, perform the procedures on both cartridges. Step 1: Remove, inspect, and reseat the problem cartridge The print cartridge may not have full electrical contact with the printer. Removing and reinstalling the cartridge may help.
NOTE: HP cannot guarantee the quality of remanufactured or refilled cartridges.
  1. Make sure the printer is on. Press the Power button if it is not lit.
  2. Open the printer cover, then wait until the print cartridge carriage is idle and silent.
  3. Press down lightly on the end of the problem cartridge to release it. Figure 1: Removing the tri-color cartridge
  4. Slide the cartridge out and inspect it:
    CAUTION: Do not touch the copper electrical contacts or the ink nozzles. Figure 2: Electrical contacts and nozzlesc00211537.gif 1 - Copper electrical contacts 2 - Nozzles
    • Check the electrical contacts for debris.
    • Make sure all the clear nozzle protective tape has been removed.
      CAUTION: Do not attempt to remove the copper electrical strip! Figure 3: Removing the clear nozzle protective tape
    • Look at the number on the print cartridge label and make sure it is compatible with your printer. Compatible print cartridges are listed in the Printer Reference Guide supplied with your printer.
  5. If the cartridge is compatible, reinstall it in the printer:
    • Cartridges marked with a triangle go into the left carriage slot.
    • Cartridges marked with a square or pentagon go into the right carriage slot.
Step 2: Clean the problem cartridge contacts
  1. Gather the following items to clean the cartridge and carriage:
    • Clean distilled water. Use bottled or filtered water if distilled water is not available. Tap water can contain contaminants that damage the cartridge.
    • Clean cotton swabs or any soft, lint-free material that will not stick to the cartridges (coffee filters work well).
    • Sheets of paper or a paper towel to rest the cartridge on during cleaning.
  2. Open the product cover and wait until the carriage is idle and silent.
  3. Remove the cartridge and place it on a piece of paper with the nozzle plate facing up.
    NOTE: Clean the contacts quickly so that the cartridge is not outside of the product for more than 30 minutes. If the cartridge is outside of the product for too long, the ink can dry and clog the nozzles.
  4. Unplug the product from the electrical outlet.
  5. Dip a swab in the clean water and squeeze it to remove most of the moisture. The swab should be only slightly damp.
  6. Clean the cartridge contacts.
    CAUTION: Do not touch the ink nozzles.
  7. Clean the contacts in the carriage, inside the product.
  8. Either let the cartridge sit for 10 minutes to allow the cleaned area to dry, or use a new swab to dry it.
  9. Reinstall the cartridge.
  10. Reconnect the product to the electrical outlet.
  11. Close the product cover.
Step 3: Repeat reseating and cleaning steps If the problem is not solved, repeat the reseating and cleaning procedures above.
Call HP if the cartridge is covered under warranty to replace the cartridge
or its time for a new printer
Apr 04, 2011 | HP PSC 1510 All-In-One InkJet Printer
Even with a new cartridge inserted, the printer does not print properly. The printer does not indicate that a new cartridge is needed. How do I clean the printer head? It is a HP Photosmart C3180 al in...
Step one: Complete the alignment process If you have already installed new print cartridges, follow these steps to complete the alignment process.
  1. After installing a new print cartridge, wait at least 20 seconds for the print cartridge alignment process to start.
  2. Wait for the print cartridge alignment process to fully complete.
  3. Make sure that the alignment page has printed on plain, white paper that has no other printing on it. If you need to create a new alignment page, load the tray with letter or A4 unused plain white paper and turn the product off and on again to create the page.
If an alignment page does not print when the product is turned on or off, the issue is resolved. If an alignment page continues to print when the product is turned on or off, you should replace the cartridges with new HP cartridges. Continue to Step two: Remove the print cartridges. Step two: Remove the print cartridges Follow the steps below to remove the cartridges. NOTE: When you remove and install the same print cartridge, the unit will not align the print cartridge as the unit remembers the alignment values for that print cartridge.
  1. Press the Power button to turn the product on. The Power button is lit when the unit is on. Figure 1: Power button lit c01336350.gif
  2. Make sure that the paper tray is down, and letter or A4 unused plain white paper is loaded in the paper tray.
  3. Lower the access door until it stops. Make sure that the print carriage moves to the right side. Figure 2: Lower the access door c01336351.gif
  4. Wait until the print carriage is idle and silent, and then using your thumb, lightly press down on a print cartridge to release it. Figure 3: Print carriage c01336352.gif
    • If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left.
    • If replacing the black or photo print cartridge, remove the print cartridge from the slot on the right.
    Figure 4: Proper position of the print cartridges c01336353.gif 1 - Tri-color print cartridge 2 - Black or Photo print cartridge
  5. Pull the print cartridge toward you and out of its slot.
Step three: Install the new print cartridge
  1. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. Figure 5: Remove the tape c00312625.gif 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections.c00312564.gif
  2. Slide the new print cartridge forward into the empty slot. Then gently push on the upper part of the print cartridge forward until it clicks into the socket.
    • If you are installing the tri-color print cartridge, slide it into the left slot.
    • If you are installing a black or photo print cartridge, slide it into the right slot.
    Figure 6: Print cartridge locations c00652788.gif 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print cartridges
  3. Close the print cartridge access door. Figure 7: Closing the print cartridge door c00652789.gif
  4. If you installed a new print cartridge, the print cartridge alignment process starts after about 20 seconds.
  5. The unit aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
If you have completed all the steps listed above and are still experiencing a problem, service the product. Cause The product aligns the print cartridges every time at cartridge installation or replacement to ensure the highest-quality prints. The alignment page continues to print when the product is turned on or off, or when a print job is started, for any of the reasons below.
  • The automatic alignment process is not complete.
  • The ink cartridges are not properly installed.
  • One of the ink cartridges is defective.
  • One of the ink cartridges is low or out of ink. Black and all three colors must be available.
  • Protective tape on a new ink cartridge has not been removed.
  • Contacts on the ink cartridge are not meeting the contacts in the carriage correctly.
  • Cartridge is remanufactured or refilled. Refilled or remanufactured ink cartridges may have been damaged during the refilling process or have clogged ink nozzles.
  • The product needs to be serviced.
Aug 28, 2008 | HP Office Equipment & Supplies
I changed the printer cartridges in a hp officejet 4315 and now it won't print-flashing error meesage "Cartridge Error:refer to device documentation to trouble shoot" What do I do? i
Good Day Sir, hope this will help you.
print cartridge troubleshooting for hp officejet 4315 :
1. Remove the black print cartridge from the slot on the right. Do not touch the ink nozzles or the copper-colored contacts. check for possible damage to the copper-colored contacts or ink nozzles.
2. Reinsert the print cartridge by sliding it forward into the slot. Then push the print cartridge forward until it clicks into the socket.
3. Repeat steps 1 and 2 for the tri-color print cartridge on the left side.
4. If the problem persists, print a self-test report to determine if there is a problem with the print cartridges.
5. If the self test report shows a problem, clean the print cartridges.
6. If the problem persists, clean the copper-colored contacts of the print cartridges.
7. If you are still experiencing problems with printing, determine which print cartridge is experiencing the problem and replace it.
have a nice day.
7.
Jun 22, 2010 | HP Officejet 4315 All-in-One Printer
I attempted to print but the ink is not working. I recently installed new ink cartridges and the color indicator shows that both color and b/w are full
Hi, the is a problem of dry ink on the cartridge. you must remove the cartridge and try cleaning with a soft cloth, preferably damp. after cleaning, you should see ink coming out the cartridge when you simply press/bring the cloth near the passage. Last option, immerse only the lower part in warm water for 2 mins.
Jan 26, 2010 | Kodak EASYSHARE 5100 All-In-One Printer
HP Deskjet F4180 Color changes and lines in photo printing
HP always recommend that ink cartridge should be replace by original ink.
As this kind of scenario will occur if the ink will just be replace by a refill ink.
Sep 21, 2009 | HP Deskjet F4180 All-in-One InkJet Printer
Hp photosmart 2610 not recognizing new color printer cartridge (97)
Print cartridge
When the print cartridge contacts are dirty and the printer cannot detect/communicate with print cartridge.
Clean the contact points on the cartridges with a dry, lint-free cloth.
1. Open the top cover of the printer.
2. Remove the print cartridges.
3. Clean the copper-colored contact points on the cartridges with a damp, lint-free cloth. Use a dry, lint-free cloth to remove moisture from the contacts.
5. Insert the cartridges back into the printer.
6. Close the top cover.
7. Try printing again.
If you still cant communicate try with new cartridge .
Aug 19, 2009 | Office Equipment & Supplies
Hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t print/installed new color'' Let our Experts solve your ''hp 5510 io keeps stating to check color cartridge/3 lights blinking/won t...
hi..
try to install and reinstall the printer cartridge...and also clean the tab circuit of the cartridge and tab circuit of the printer carrier..
if the problem still exist..
rebreak the printer by full-out the power supply...to reset the settings and then turn it back...
Apr 01, 2009 | HP Officejet 5510xi Printer
Printing very light
I am not sure your printer cartrige with head or not, and it is color or black, it there any color lost, in general you may try
1) if the cartridge seperate print head, find a cartridge spacial clean liquor or steam water and take out the ink cartridge, put a little into the ink hole and back the ink box test it,
2) if printer ink with head, take out and put in team water (just touch water surface to the head hole for 1 Hr. and then put back and test.
3) check printer manu adjust darkness to darker.
Dec 28, 2008 | Lexmark X75 All-In-One InkJet Printer
HP DESKJET 1180C
HP Deskjet 1180c and1220c Professional Series Printer and HP Deskjet 9300 and 1280 Printer - Troubleshooting a Blinking Print Cartridge Light Introduction The Print Cartridge light continues to blink with both cartridges properly installed and the Access Cover (also known as the top cover or lid) closed. Instructions The blinking Print Cartridge light may be caused by a faulty cartridge, the plastic case of the printer being dislodged or slightly out of position (which prevents the Access Cover from seating properly), the Access Cover sensor (also known as the top cover sensor or lid sensor), or by the actuator on the Access Cover. Follow the steps below to resolve the issue.
  1. With the printer turned on, open the Access Cover. The carriage will move out of the capping station and stop at one of the cartridge status icons located inside the printer under the Access Cover. The yellow arrow on top of the carriage will point to one of the cartridge status icons to indicate a good, empty, or faulty cartridge. See Figure 1 below.
    1. If the carriage stops in the cartridge’s OK position, indicated by the happy face in Figure 1, continue with Step 2.
    2. If a problem is indicated with one of the cartridges, remove the cartridge and verify that the cartridge part number is correct. The black cartridge part number is 51645A and the color cartridge part number is C6578A or C6578D.
    3. If the cartridge part number is correct, clean the electrical contacts on the cartridge with a soft, lint-free cloth. Do not touch or wipe the nozzle plate.
    4. If a faulty cartridge is still indicated after verifying the cartridge part number and cleaning the contacts on the cartridge, replace the cartridge.
    5. After replacing the cartridge, turn off and then turn on the printer to clear the cartridge error from the printer's memory. If the cartridge error cannot be cleared, the printer will require repair. If the carriage stops in the cartridge’s OK position, indicated by the happy-face in Figure 1, continue with Step 2. NOTE: The printer checks the status of both print cartridges before printing. Both the black and color cartridge must be functional and installed in the printer in order to print.
    Figure 1: Cartridge status icons c00001225.jpg Icon/Drawing Problem identified by the symbol Solution c00001226.jpg The color cartridge is missing, improperly installed, defective, or the wrong print cartridge is installed. 1. If there is no color cartridge in the cartridge cradle, insert a color cartridge.
    2. If there is a color cartridge in the cradle, remove the color cartridge and firmly reinsert it.
    3. Check to make sure the color cartridge is appropriate for the printer.
    4. If the problem persists, replace the color cartridge. c00001227.jpg The black cartridge is missing, improperly installed, the wrong print cartridge, or is defective. 1. If there is no black cartridge in the cartridge cradle, insert a black cartridge.
    2. If there is a black cartridge in the cradle, remove the black cartridge and firmly reinsert it.
    3. Check to make sure the black cartridge is appropriate for the printer.
    4. If the problem persists, replace the black cartridge. c00001228.jpg The color print cartridge is running low on ink. Replace the color print cartridge with a new color print cartridge. c00001229.jpg The black print cartridge is running low on ink. Replace the black print cartridge with a new black print cartridge. c00001230.jpg None. The print cartridges are working correctly. None. The print cartridges are working correctly.
  2. Close the Access Cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, remove the Access Cover by following the steps below:
    1. Open the Access Cover and hold it open.
    2. Dislodge the Access Cover from the hinges with a sharp blow to the hinge area of the Access Cover and then remove the Access Cover.
  3. Install the Access Cover by following the steps below:
    1. Align the hinges on the Access Cover with the hinge pins on the printer.
    2. Push down firmly on the Access Cover until the hinges snap into position.
  4. Close the top cover and wait for the printer to initialize. If the Print Cartridge light is still blinking, the printer case may be dislodged or slightly out of position. To restore the printer case to the proper position, squeeze the printer by applying pressure to the front and back pressure points shown in Figure 2. Figure 2: Pressure points c00006497.jpg Firmly squeeze the pressure points on the printer case as shown in Figure 3. If the Print Cartridge light continues to blink, continue with step 5. Figure 3: Squeezing the pressure points c00006498.jpg
  5. If the Print Cartridge light is still blinking, push down firmly on the center of the Access Cover (the extra pressure may engage the sensor). If the Print Cartridge light quits blinking, remove the pressure from the Access Cover to see if the Print Cartridge light starts blinking again. Re-apply the pressure to the center of the Access Cover to see if the Print Cartridge light stops blinking again.
    1. If the Print Cartridge light quits blinking with pressure applied, the Access Cover is faulty and should be replaced.
    2. If the Print Cartridge light continues to blink even with pressure applied, the Access Cover sensor may be faulty and the printer will require repair.
Oct 18, 2007 | Office Equipment & Supplies
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
Lexmark X5150 All-In-One InkJet Printer Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
