Question about D-Link AirPlus DI-524 Wireless Router
Problem with startup wizard
Hi just bough a DI-524 router have connected cables went to the web to set up wizard typedin th numbers and it say logon screen will come up and it dose not so i cant use it
  • gudi Mar 17, 2008
    I have done this before . Firs I turn the router then I open an Internet brouser and write http://192.168.0.1/ but nothing happends. I can get in. Please help me.
    Sincerely
    Luis Gudiel
  • Jeffrey Pemberton
    Jeffrey Pemberton May 11, 2010
    Are you using a DSL modem? If you are I think I know your problem.
    Sniper:
  • 67 Answers
For security reasons some wireless routers will not allow access to their setup pages via wireless unless some settings are changed.
you have to connect to the router from your computer with a ethernet cable into port 1,2,3 or 4 (ports at the beck of the router)and go to the website
http://192.168.0.1
A logon pop-up screen will appear. Type "admin" for the username and leave the password field blank.
make sure you plugged the "internet" ethernet cord into the internet or WAN port at the back of the router.
Posted on Feb 24, 2008
I have a D-Link AirPlus DI-524 i want to use it wired only for to comps running win 7 i had a friend set up a wireless network before but had falling out so i need help to set it up as wired
For a wired network, the easiest way is using the Wizard mode (There's a botton named Wizard at Home tab), basically you'll have to configure connection with cable modem (WAN part) and check DHCP settings (LAN part), this one should be enabled for having automatic IPs.
Feb 21, 2011 | D-Link AirPlus DI-524 Wireless Router
Forgot my DI 524 setup password, pushed RESET button, what next?
You will need to login as admin and set it up again. Connect per ethernet cable, open a browser and enter 192.168.0.1 You should see a router welcome screen or logon dialog login as admin the default password maybe one of several things depending on the particular revision/edition blank/null 'admin' 'password'
Support for this model is available at http://www.dlink.com/products/?pid=DI-524&tab=3 manual at ftp://ftp.dlink.com/Gateway/di524/Manual/DI-524_manual_06292005.zip
Once you're in you will have to set up an ISP connection which may require your ISP username / password and selecting a protocol particular to your ISP and setting up the wireless WEP key
Jan 08, 2011 | D-Link AirPlus DI-524 Wireless Router
Hi I have the D-link DI-524 but i can only connect 3 items wireless when i secure it on wep?
1. Go to the D link page in the router and check the if there is a firmware update.
2. check to see if there is a set number of device that can be addressed by the router.
3. Your D Link web site can give you this information.
Apr 18, 2010 | D-Link AirPlus DI-524 Wireless Router
Hi, DI-524
The final solution is a factory reset of your router. You can do a factory reset by logging into the router using you browser. Go to the settings and perform a factory reset
If you forgot the router password, you ill have to do a factory reset by locating a small hold on the back of the router and insert the tip of of paper clip for about 10 seconds while the power is on. The router will be reset to out of box status and then you can ssets-up form scratch.
Dec 29, 2009 | D-Link DI-524 4 Port Wireless-G Router -...
I am having problems installing the d'link di-524 wireless router. I don't know how to install it.
Ok go to the Dlink web site and download the setup disks for your router and follow the instructions...
Basically, ya connect up the router to the PC via a Ethernet cable, (or USB sometimes). open IE and get into the routers setup.. usually 192.168.0.1 OR maybe 10.1.1.1 a window should ask for logon password use ADMIN & ADMIN. Then run the wizard entering your details IE: Logon Name and Password... and then follow the instructions ... reboot and ya should be up and running.. good luck
Apr 10, 2009 | D-Link AirPlus DI-524 Wireless Router
Wireless status says i'm connected but cant load any web pages.
You need to go into it's set up and configure it right.
Using a Ethernet cable plug into the back of it with it on and type in http://192.168.0.1 start its setup wizard in your case.
Mar 28, 2009 | D-Link AirPlus DI-524 Wireless Router
Network problem
Hi there!
Let me try and help you out.
Please describe your cable connections from the modem going to the router. What specific port from the modem goes into the Dlink router?
May 04, 2008 | D-Link AirPlus DI-524 Wireless Router
Install g54 di-524 wireless router to wireless laptop
Feb 07, 2008 | Computers & Internet
DI-524 wireless router as wireless switch
You need to disable the DHCP server on your "slave" wireless router ( the di-524 ). In D-link routers this might be called configuring it to be an "Access point".
When this happens, connecting to the second wireless router should cause your computer to obtain an IP address which is in the range of the first router (that is to say, it will use the first router's dhcp server).
You should be able have your laptop connect with an automatic IP address and have it work.
Jan 24, 2008 | D-Link AirPlus DI-524 Wireless Router
Cant connect
Hi purplegarion,
hook up the router per instruction in manual and your particular internet connection.  With the Di524 powered up, use the end of a paperclip to depress the reset button located in a little hole beside the power connection.   open internet explorer and type in 192.168.0.1 and press enter.  The password is admin. once th screen appears, click on Wizard.  Follow the wizards directions carefully.
For simplicity of security click on the wireless button while in the  wireless screen.  Set radio to on.  Enter a SSID like purplegarion. Set to open system.  Set Security to WEP.  Wep to HEX.  64bit.  Enter into Key one a 10 digit number you can remember like 1234567890.  Click apply.  Change your password to a personal password other than ADMIN.
Any device that attaches will need to enter the WEP 64 Bit hex Security key 1234567890, or whatever 10 digit number you put in the router.
Internet connection will require powering down you modem, and the DI-524 router.  power up the modem first and let it go through the start up, then power up thte DI 524.  you may need to make sure your DHCP is set to Automatically assign an IP address.
Oct 07, 2007 | D-Link AirPlus DI-524 Wireless Router
D-Link AirPlus DI-524 Wireless Router Logo
102 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
