I dont know how to start itmaybe code,maybe something else. just received crysler car from may cousin,and have no music in it :( aint suppoused to turn on,by pressing pwr button?
SOUNDS TO ME LIKE YOUR STCOK RADIO IS PROBABLY FRIED JUST BUY A AFTER MARKET DECK AND THE CORRECT WIREING HARNESS THAT SHOULD FIX U UP BUT FIRST C IF THE RADIO FUSE IN BLOWN THATS ALWAYS THE FIRST THING TO CHECK IN UR SITSUATION
check fuel pressure it maybe returning to the tank after the car sits or if it runs bad for a little bit once the car starts it maybe a leaking injector
I doubt this helps but my vehicle which is not a VW but my vehicle will not start it just clicks? Maybe a fuse or something?? I have a cousin and her hisband works for VW in Kansa City,Kansas I can always ask him?? Let me know if I need to or your problem is already solved?
All you have to do is go to the location where it was set... and turn the unit on... it should not ask you for the PIN and then you can go into the menu and change/delete the PIN.
Actually I believe the code has something to do with fuel.. the P0237 means Powertrain (P), the 0 means its a common code throughout all vehicles not manufactur specific and the 2 means Fuel , the 37 is the specific code and says the problem usually that i dont know off hand but if theres like a lack of power or you know this is creating a misfire i would start out by checkin fuel pressure [pressure, pump, rails] and then fuel delievery [injectors].
hope that gets you started or an idea maybe
ps a turbo is something you usually install yourself so the car shouldnt be equipped with a turbo sensor...i dont think that exists
ok remove the back where the battery is and u will see the slot the card is suppose to go into if u cant open the back search along the edges for a silver button press down and the back should open
