Problem for Motherboards
Generic problem for all Motherboards
Multimedia audio controller
There is no sound in my computer..In device manager it shows no drivers for multimedia audi controller....When i try to check out the motherboard model number there is no information...on seeing the properties of my computer it just shows 228Mb of RAm..although its 256Mb...please help
Same Problem
May 15, 2009
-   I hve the same problem the cd provided with the MB doesnt load the correct drivers i have Windows XP lite sp3 can any one help me?
coolnathan Feb 13, 2009
-   Please sent me the driver of AUS P4P800 pentium motherboard-
rith143 Feb 01, 2009
-   i have no sound-
sue373 Jan 29, 2009
-   Intel D865perl motherboard
kingphilip Dec 23, 2008
-   no audio-   Guest
Best Solution
posted on Feb 24, 2008
Rank: Guru
Expert
Rating: 88%, 121 votes
This is a very common problem. You may connect your PC to internet and select update driver. The required Driver will beautomatically downloaded. If you don't get the required material, give me the Model of your Motherboard and the Operating system you are using, I will give you a detailed solution for the problem.
The second thing, you are getting the right memory, rest of your memory has been shared for Graphics.
Was this helpful?3 people thought this was helpful
Solution #2
posted on Oct 30, 2009
Rank: Apprentice
Rating: 0%, 0 votes
On Acer Veriton 7500 PC with Windows XP, when trying to upgrade Multimedia Audio Controller with Audio Realtek driver, system displays message Driver could not be found.
Popular Solutions for Motherboards
ASUS P4P800 SE (890552603657) Motherboard
1 Solution
Biostar NF61S MICRO AM2 SE (NF61MICROAM2SE) Motherboard
3 Solutions
Questions and Unsolved Problems for Motherboards
compaq presario mother board, what should I replace it with
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this...
(More)
ms-6577 v2.1 motherboard need location of pwsw and reset sw from atx case to board ms-6577 v2.1 this case came with 4 fans plus pw sply. is this too much for this bd . I smell alittle toasty but it all turns on ok if i connect a fith to the middle. not the cpu fan . ihave a 500 watt pw sply.i want to make sure the wires are connected right and that what i smell is just too much so i can disconnect and just get me a newer bd with instructions...thanks. if icould view a pit .would be great..
Will new micro atx boards fit inside of a hp pavilion 4550z case? I am trying to overhaul my old hp...
(More)
Will new micro atx boards fit inside of a hp pavilion 4550z case? I am trying to overhaul my old hp pavilion 4550z with a new os and new motherboard as well as processor. My problem is I am not sure that the micro atx motherboard I plan to get will fit properly in the old hp pavilion 4550z case.
Planned new motherboard: GA-M61PME-S2P
my usb doesn't detected by computers since i plug it to one computer... please somebody help me...
Hi the front fan connection has come off on my asus p5vd2-x motherboard and I'm not sure if it...
(More)
Hi the front fan connection has come off on my asus p5vd2-x motherboard and I'm not sure if it should be connected to the cha fan connector or the pwr fan connector? and both those sockets on my motherboard have 3 pins whilst wiring fron fan only has 2 wires pls help thanks paul
12 Other Users Have The Same Problem - Continued
Comment by lwjohnston, posted on Dec 17, 2008
I too have the same problem. Asus P4P800S-X. I have tried two different Creative lab drivers. Sometimes get no sound card found. Other times sound just stops. When it is "kind of " installed I get sound but with a constant crackling in the speakers. Also I have tried using the original install disk and XP when I try to point it to the CD drive with the install software says it can't find the drivers there. The card worked in the box but I had to do a reinstall of XP and also upgraded to SP3.
Comment by jaredbelch, posted on Nov 21, 2008
I have a sound blaster audigy 2 value card (SB0400) that won't install. I'm running XP Pro with SP3. The hardware installer keeps trying to install a "multimedia audio controller" but fails to find drivers.
I downloaded the appropriate drivers from Sound Blaster, but when I run the install file, it tells me there is not compatible sound card in the mobo. I've tried 3 different drivers from sound blaster, as well as moving the sound card to all of the different pci slots... Now I'm stumped, any help would be greatly appreciated.
Thanks
Comment by Guest, posted on Nov 21, 2008
I have a sound blaster audigy 2 value card... When I booted it attempted to install the hardware calling it a "multimedia audio card" but failed. It has failed every time I've tried to install the drivers. I downloaded the drivers from sound blaster, but when I run the install, it returns an error saying it can't find the specific audigy card. I've tried it in different pci slots, I have check my bios, and there is no way to enable/disable the audio, and now I'm stuck.
Comment by Guest, posted on Oct 04, 2008
Does not recognize audio device.
pcChips A13G+ v3.0 motherboard
Comment by Guest, posted on Sep 27, 2008
same
Comment by Guest, posted on May 01, 2008
Same prob. No sound, system drop down says device not configured properly but can't find new driver.
Comment by kier, posted on Feb 28, 2008
need help with the same problem
