Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Replacement stand... Where can I get a replacement stand for the drive? (The little black plastic stand that clips to it allowing it to sit vertically rather than horizontally.)
  • Anonymous Mar 31, 2008
    I can not find one either
    Champion:
  • 230 Answers
Ebay ?
Posted on May 15, 2008
The mullion is broken in my Lg refrigerator
I have a related question. My lower spring broke and I have the replacement spring. How do I put it into both plastic fittings at the same time. One arm on the spring goes on mullion while the other arm goes into a fitting on the door. Please help!
Aug 15, 2012 | LG 4-door French Door Refrigerator...
How to replace the air filter on a 2006 tundra
the procedure is as follows:-- Of the top center of the engine is a black plastic intake tube. Follow this tube over to the square plastic air cleaner box assembly. There are snap clips that hold the upper half of the plastic cover on unsnap these clips. The upper half of the air cleaner box will separate allowing you to remove the air filter. The other style has a small lid with two metal snap clips by popping these two metal snap clips back the lid lifts up and the air filter is in place vertically pull up on the air filter and it will come out.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 11, 2010 | 2006 Toyota Tundra
How do you replace a headlight on a 2006 lincoln town car (low beam - left side)
Open the hood. Remove the black plastic grill assssembly ( Laying horizontal between the radiator and front bumper). There will be a couple of plastic screws (or some other fastening system) for this part remove and set aside. There is another black plastic grill assembly standing vertical. Remove similar fastening devices and set aside. IF DURING THIS ENTIRE PROCESS there is ANY part that does not come off freely after removing a fastening device (plastic screw, metal screws, hex bolts, bolts) LOOK FOR A PLASTIC CLIP - unclip that as a final step in each of these processes. To continue, Each headlight is attached by three hex or phillips screws.- Remove them and set asside. There is a major clip attaching the headlight at the top. Unattach this and gently remove the entire light housing. The housing will be the unit containing all parts high beam, low beams, side lights, and blinkers. It is a nice tidy unit. To continue, look for a black plastic removable panel on the back allowing access to the back of the bulbs. Remove the 5 screws and set asside. You now have access to the bulbs. The bulbs are attached by a solid plastic clip. Grab the back of the plastic bulb housing and turn about a half of an inch to remove the bulb. Unattach the clip from the wirering harness and you will have the bulb removed. CAREFULLY remove the new bulb making sure not to touch the glass portion of the bulb with hands directly. Skin oils or other debris is not recommended to get on the bulb. Deliberately refasten the bulb wiring harness and replace to the back of the reflection housing. Reassemble all devices. Rinse wash repeat for the other side :)
This seems complex for the task at hand and it is. But from the perspective of repairing a front end after a minor collision is is wonderful. Enjoy...
Jul 23, 2010 | 2006 Lincoln Town Car
My tv screen is black and nothing i do helps it..i have good volume and channels change ok, there is just no visual.what can i do ? ive tried turning it off then back on, ive turned it on and let it sit,...
Sounds like the vertical deflection has dropped out which would shut down the three CRTs but still allow audio to work. The vertical output IC may need replacement.
Jul 08, 2010 | RCA HD52W56 52" Rear Projection HDTV
Ogio Stand Bag - Broken "H" Clip
Mine slide up and down the legs. Not a good design since the weight broke 1 of them. I have not found a replacement part for this yet.
Dec 08, 2009 | Ogio Golf Stand Bag
Where is the turn signal flasher located?
The flasher sits above the gas pedal behind a small, black panel . The panel is held on with one star bolt and is situated between the gas panel arm and the bottom of the plastic molding that sits below the steering column. the flasher should be be green and clipped to a small, cube shaped harness and attached to the inside wall by two plastic clips. You will need to use a very small flathead to pry the two pieces apart.
After removing the part you can verify that you have the correct replacement by comparing units, often times without opening the packaging on the replacement. Secondly you can verify that you did remove the flasher by putting your keys in the ignition, turning the on and then using your turn signals or hazards.
Nov 10, 2009 | 2000 Chevrolet Cavalier
I just purchased a 52 inch phillips tv and the stand that the tv sits on adds 2 inches which doesn't allow the tv to fit in my entertainment center. What can I do?? I need a shorter stand...
Just take off the stand altogether if you can lay the TV close enough to a solid vertical support.
My 47'' Philips spent about a year without a stand sitting on a desk and leaning on a wall.
It's heavy enough and as you approach to completely vertical position its main force will be pointing down, not forward.
If you can't lean it on anything solid or if it doesn't sit well while in an entertainment center...not sure what I'd suggest....short of adjustable wall mount stands...
Nov 07, 2009 | Philips 52PFL3603D/27 52 in. LCD HDTV
How to replace fuel-pump.. The pump sits in bottom
locate a black plastic cap. tak it off. then you can see the pump. twist it against the clock.(the upper part) dont be afraid using some force. usally sits hard.when twist--> drag up. sorry bad english:)
Aug 30, 2009 | 1992 Volkswagen Passat
Can't find replacement parts for Magic Chef MCBR445B
take out one of the legs and carry it to appliance part store
Apr 07, 2009 | Magic Chef MCBR440 Compact Refrigerator
How to Fit a Cabin Filter
Hiya...the cabin air filter is located below the front passenger/windshield area.
It's only accessible by standing outside the Equinox with the hood open.
Here's how to do it...(before you pop open the hood)
1) Stand outside at the front-right door area.
2) Just below the front windshield area, pull up a few small black plastic clips that's on the black windshield wiper cowl area- a small flat screwdriver or a special clip-remover tool is handy.
3) Raise the hood up.
4) There may be a triangular-shaped hard foam sound damper at the left side nearby the hood hinge...pull it off if it allow you to work around it with ease.
5) Continue to find a few black plastic clips around the black windshield wiper cowl area.
6) Gently pull up the black windshield wiper cowl cover with care not to bend it too hard during removal.
7) You should see the cabin air filter inside that's held in place by a black rectangular box inside.
8) There's 2 black tabs that holds the cabin air filter in place.
9) Insert your finger or tool to pry the cabin air filter away from the tabs.
10) Remove old cabin air filter.
Remember to reinstall the clip parts back into place when you're finished.
Nov 12, 2008 | 2006 Chevrolet Equinox
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
